Module called too many times?
Tue, Feb 9, 2021 3:18 PM
I have some code where a particular Module "M()" is invoked 4 times, but
only one of those times is actually displayed, because I only put "!" in
front of one of the references; the other 3 should be ignored.  And yet
when I use echo() inside M(), it appears 4 times.  It seems that while I
have only asked for ONE of the invocations to be calculated, in fact all
four are.  One can hope that it is actually calculated only once, and
then pulled from a cache for the other 3 times, but this is not what I
expected.  That is, in the code below, I thought that modules A(), B(),
and C() would be ignored entirely.
Not sure if this is important or just a curiosity.  Not sure whether
there are performance issues lurking there.
module M() {
    cube(1);
    echo("hello");
module A()
    M();
module B()
    M();
module C()
    M();
A();
B();
C();
!M();
I have some code where a particular Module "M()" is invoked 4 times, but only one of those times is actually displayed, because I only put "!" in front of one of the references; the other 3 should be ignored.  And yet when I use echo() inside M(), it appears 4 times.  It seems that while I have only asked for ONE of the invocations to be calculated, in fact all four are.  One can hope that it is actually calculated only once, and then pulled from a cache for the other 3 times, but this is not what I expected.  That is, in the code below, I thought that modules A(), B(), and C() would be ignored entirely. Not sure if this is important or just a curiosity.  Not sure whether there are performance issues lurking there. Jon module M() {     cube(1);     echo("hello"); } module A()     M(); module B()     M(); module C()     M(); A(); B(); C(); !M();
D
dpa
Tue, Feb 9, 2021 3:47 PM
they are all there. You should translate them differently then you'll see
them all.
Am Di., 9. Feb. 2021 um 16:19 Uhr schrieb jon jon@jonbondy.com:
module M() {
cube(1);
echo("hello");
module A()
M();
module B()
M();
module C()
M();
A();
B();
C();
!M();
they are all there. You should translate them differently then you'll see them all. Am Di., 9. Feb. 2021 um 16:19 Uhr schrieb jon <jon@jonbondy.com>: > I have some code where a particular Module "M()" is invoked 4 times, but > only one of those times is actually displayed, because I only put "!" in > front of one of the references; the other 3 should be ignored. And yet > when I use echo() inside M(), it appears 4 times. It seems that while I > have only asked for ONE of the invocations to be calculated, in fact all > four are. One can hope that it is actually calculated only once, and > then pulled from a cache for the other 3 times, but this is not what I > expected. That is, in the code below, I thought that modules A(), B(), > and C() would be ignored entirely. > > Not sure if this is important or just a curiosity. Not sure whether > there are performance issues lurking there. > > Jon > > > module M() { > cube(1); > echo("hello"); > } > > module A() > M(); > > module B() > M(); > > module C() > M(); > > A(); > B(); > C(); > > !M(); > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Tue, Feb 9, 2021 3:50 PM
No, there's only one shown due to the ! (root modifier).
The root modifier only applies to display, not to evaluation,
so all the calls are done to evaluate the full script. That's
intentional at this point.
No, there's only one shown due to the ! (root modifier). The root modifier only applies to display, not to evaluation, so all the calls are done to evaluate the full script. That's intentional at this point. ciao, Torsten.
Tue, Feb 9, 2021 3:51 PM
Not true:
module M() {
     cube(1);
     echo("hello");
module A()
     M();
module B()
     M();
module C()
     M();
translate([3, 0, 0]) A();
translate([6, 0, 0]) B();
translate([9, 0, 0]) C();
!M();
On 2/9/2021 10:47 AM, dpa wrote:
module M() {
     cube(1);
     echo("hello");
module A()
     M();
module B()
     M();
module C()
     M();
A();
B();
C();
!M();
Not true: module M() {      cube(1);      echo("hello"); } module A()      M(); module B()      M(); module C()      M(); translate([3, 0, 0]) A(); translate([6, 0, 0]) B(); translate([9, 0, 0]) C(); !M(); On 2/9/2021 10:47 AM, dpa wrote: > > module M() { >      cube(1); >      echo("hello"); > } > > module A() >      M(); > > module B() >      M(); > > module C() >      M(); > > A(); > B(); > C(); > > !M();
D
dpa
Tue, Feb 9, 2021 9:29 PM
ah, well.. I have then probably misunderstood the question. That !M() only
outputs this one M() was so clear to me that I omitted it and the other 3
are just in the same place.
Am Di., 9. Feb. 2021 um 16:51 Uhr schrieb Torsten Paul <Torsten.Paul@gmx.de
ah, well.. I have then probably misunderstood the question. That !M() only outputs this one M() was so clear to me that I omitted it and the other 3 are just in the same place. Am Di., 9. Feb. 2021 um 16:51 Uhr schrieb Torsten Paul <Torsten.Paul@gmx.de >: > No, there's only one shown due to the ! (root modifier). > > The root modifier only applies to display, not to evaluation, > so all the calls are done to evaluate the full script. That's > intentional at this point. > > ciao, > Torsten. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
