I have a project where I am trying to model a involute curve. I have a
function which returns a list of points where one of the parameters is how
many points it should return. When it generates a few points the curve
actually looks smoother than when I generate lots of points. When I
generate tons of points (more than lots :) ) it actually doesn't display
anything at all.
Here is a screen shot of simplified code which demonstrates the problem and
the generated shapes:
http://forum.openscad.org/file/n16584/involute-curve.png
I'm a noob with OpenSCAD so I'm probably doing something stupid. Thanks for
any help!
View this message in context: http://forum.openscad.org/Passing-lots-of-points-to-polygon-results-in-lower-resolution-tp16584.html
This sounds like a known bug,
https://github.com/openscad/openscad/issues/999
anything at all.
for
any help!
So a suggested workaround is to upscale your scene by 100 or more.
View this message in context: http://forum.openscad.org/Passing-lots-of-points-to-polygon-results-in-lower-resolution-tp16584p16586.html
An involute curve with a specified number of points... that sounds familiar:
http://www.thingiverse.com/thing:195160
See the file 'gear_maker.scad'. I'm not convinced that I've got the involute
formula correct yet, but perhaps it might help you in working out how to do
this:
// note: pressure angle is not quite right. Max width is at a little bit
over 45 degrees
function involute(involute_angle) =
[(involute_anglecos(involute_angle)),
(involute_anglesin(involute_angle))];
function involute0(d_y, add_frac, p_ang, involute_angle) =
[d_y*(involute_anglecos(involute_angle))/((45+p_ang)cos(45+p_ang)2sqrt(2)),
d_y(((involute_anglesin(involute_angle)<=(90*add_frac))?
involute_anglesin(involute_angle):(90add_frac))-((45+p_ang)*sin((45+p_ang))))/((45+p_ang)*cos(45+p_ang)2sqrt(2))];
function make_tooth(d_y, add_frac=0.90, p_ang=0.2, n_pts=30, res=[]) =
(len(res) > n_pts) ? res :
make_tooth(d_y=d_y,
add_frac=add_frac, p_ang=p_ang, n_pts=n_pts,
res=concat(res,[involute0(d_y=d_y,
involute_angle=len(res)*180/n_pts-90)]));
myPath=make_tooth(20, add_frac=1, p_ang=0, n_pts=30);
polygon(points=myPath);
View this message in context: http://forum.openscad.org/Passing-lots-of-points-to-polygon-results-in-lower-resolution-tp16584p16590.html
Involute curves and gears:
I put quite some effort into a version for inkscape. Master repo is here:
One day I'll do a gearbox plugin that uses it.
View this message in context: http://forum.openscad.org/Passing-lots-of-points-to-polygon-results-in-lower-resolution-tp16584p16591.html
There is an involute gear library included in the OpenSCAD distribution.
include <MCAD/involute_gears.scad>
Read the source code on your local hard drive for details.
On 20 March 2016 at 04:52, David Eccles (gringer) <
how
familiar:
involute
this:
over 45 degrees
make_tooth(d_y=d_y,
Scaling up then down worked! Thanks for the help.
View this message in context: http://forum.openscad.org/Passing-lots-of-points-to-polygon-results-in-lower-resolution-tp16584p16648.html
