Project Help Needed - Harbor Freight storage boxes
TG
Todd Guill
Mon, May 24, 2021 11:04 PM
I have been looking at some of the objects on thingiverse for the Harbor
Freight storage bins.
Someone has made an SCAD file for customization and it works, however I
would like to change the design and change a few of the variables.
I have an idea of what I want and the rules/parameters that need to be
there but know nothing about openscad.
Would there be someone willing to take this project on? I'm willing to pay
if someone wants to quote this out.
Basically I want to combine:https://www.thingiverse.com/thing:2836113 for
the customizer (and add a few things)
with this:https://www.thingiverse.com/thing:3347925 for the actual bin
design
with a label option like this:https://www.thingiverse.com/thing:2084907 but
with some different variables
[image: IMG_4736.jpg]
Variables:
  • # of short side "units" [ct]
  • # of long side "units" [ct]
  • wall thickness [#mm]
  • # of subdivision "buckets" across short side [ct]
  • # of subdivision "buckets" across long side [ct]
  • height split [1/4, 1/3, 1/2, 2/3, 3/4]
  • top of stack [yes/no]
  • tolerance [#mm]
  • label [yes/no]
  • label position [short unit side/long unit side]
  • label text [abcd123!@&]
  • label text size [?]
  • label angle [#degrees]
  • rim [#mm]
Rules:
  • label can only go on top of stack
  • "bucket" walls must be flush with top if "top of stack = true" or
no selection for stack
  • "bucket" walls must only go to "C - G" if "top of stack = false"
  • all chamfers are 45 degrees
  • The split would be the C height split so that the boxes could nest
on top of each other. Great point about the F=12 not working in that
scenario. I had not thought of an appropriate rule for that. Does opens cad
have if/else type functions to limit you, so that if someone did choose the
1/4 or 1/3 option then the F value could not be greater than 2 or 3?
Formula points:
  • A = 54.5 (Default Unit)
  • B = 39.5 (Default Unit)
  • C = 46.5 (Default Unit)
  • D = 1.5 (variable) [Wall Thickness]
  • E = A - ((D*2) + (M*2))
  • F = 12 (variable) [rim]
  • G = F + L
  • H = 31.5 (default)
  • I = E - (D*2)
  • J = N - (D*2)
  • K = D + M
  • L = D + M
  • M = 0.5mm (variable) [tolerance]
  • N = B - ((D*2) + (M*2))
  • O = ~5.5mm
  • P = ~4mm
Appreciate you guys taking a look at this.
Todd Guill
toddbg@gmail.com
206-419-6163
I have been looking at some of the objects on thingiverse for the Harbor Freight storage bins. Someone has made an SCAD file for customization and it works, however I would like to change the design and change a few of the variables. I have an idea of what I want and the rules/parameters that need to be there but know nothing about openscad. Would there be someone willing to take this project on? I'm willing to pay if someone wants to quote this out. Basically I want to combine:https://www.thingiverse.com/thing:2836113 for the customizer (and add a few things) with this:https://www.thingiverse.com/thing:3347925 for the actual bin design with a label option like this:https://www.thingiverse.com/thing:2084907 but with some different variables == [image: IMG_4736.jpg] *Variables:* - # of short side "units" [ct] - # of long side "units" [ct] - wall thickness [#mm] - # of subdivision "buckets" across short side [ct] - # of subdivision "buckets" across long side [ct] - height split [1/4, 1/3, 1/2, 2/3, 3/4] - top of stack [yes/no] - tolerance [#mm] - label [yes/no] - label position [short unit side/long unit side] - label text [abcd123!@&] - label text size [?] - label angle [#degrees] - rim [#mm] *Rules:* - label can only go on top of stack - "bucket" walls must be flush with top if "top of stack = true" or no selection for stack - "bucket" walls must only go to "C - G" if "top of stack = false" - all chamfers are 45 degrees - The split would be the C height split so that the boxes could nest on top of each other. Great point about the F=12 not working in that scenario. I had not thought of an appropriate rule for that. Does opens cad have if/else type functions to limit you, so that if someone did choose the 1/4 or 1/3 option then the F value could not be greater than 2 or 3? *Formula points:* - A = 54.5 (Default Unit) - B = 39.5 (Default Unit) - C = 46.5 (Default Unit) - D = 1.5 (variable) [Wall Thickness] - E = A - ((D*2) + (M*2)) - F = 12 (variable) [rim] - G = F + L - H = 31.5 (default) - I = E - (D*2) - J = N - (D*2) - K = D + M - L = D + M - M = 0.5mm (variable) [tolerance] - N = B - ((D*2) + (M*2)) - O = ~5.5mm - P = ~4mm Appreciate you guys taking a look at this. Todd Guill toddbg@gmail.com 206-419-6163
