Supposedly OpenSCAD has, in addition to the abstract syntax tree and
raw CSG output format, a TERM output; per the manual:
which is confirmed by the source code:
else if (curFormat == FileFormat::TERM) {
CSGTreeEvaluator csgRenderer(tree);
auto root_raw_term = csgRenderer.buildCSGTree(*root_node);
with_output(cmd.is_stdout, filename_str, [root_raw_term](std::ostream & stream) {
if (!root_raw_term || root_raw_term->isEmptySet()) {
stream << "No top-level CSG object\n";
} else {
stream << root_raw_term->dump() << "\n";
However, when trying to play with this, I get the “No top-level CSG
object” whatever the input is:
$ echo "sphere(10);" > a.scad; openscad-nightly a.scad -o - --export-format term
(I am quite confient however that this top-level CSG object is, in
fact, not empty !).
Is there a way to make this work?
I've been using OpenSCAD for very many years and have never come across TERM.
Where in the manual did you find it?
However, I have not tried this, if it is CSG & you are using command line,
try --preview to invoke OpenCSG.
https://github.com/openscad/openscad/commit/99f24241c5d8f4c09407e7986db30104ef44d0e4
Export TERM & command-line, seems very new, probably untested by the look of
it.
You could try the Development Snapshot:
http://www.openscad.org/downloads.html#snapshots
That is the Linux manual, very old.
I think that is what you get with GUI Display/Display-CSG-Products.
I'm intrigued. What do you recon the .TERM data can be used for?
Pretty rendering? Web preview? Something completely else?
I believe Michael is correct here.
It's not useful for much, aside from maybe diagnostics and debugging (and
specific to OpenCSG preview). You can't recreate anything with it since it
doesn't contain full geometry info like size and transformations. Nodes,
aka "terms" in the CSG boolean expression, are labeled based on their node
type and node ID such as "sphere2" etc.
Which is probably also why that output is apparently not covered by tests
at the moment either.
Hans
