When I F5 this code:
sd = 5; // snoot diameter
th = 3;
inches = 25.4;
ht = 5 * inches;
oid = 3 * inches;
ood = oid + 2 * th;
module torus(id, r)
rotate_extrude(convexity = 10, $fn = 100)
translate([id, 0, 0])
circle(r = 1, $fn = 100);
module snoot(sd) {
translate([ood/2 + sd, 0, 0])
cylinder(h = ht/2, d = sd);
translate([ood, 0, ht/2])
rotate([90, 0, 0])
torus(oid, sd);
snoot();
I get this error:
WARNING: undefined operation (number + undefined) in file , line 14
WARNING: Unable to convert translate([undef, 0, 0]) parameter to a vec3
or vec2 of numbers in file , line 14
If anything, "sd" is OVER defined, since I've defined it twice.
Can anyone see what is going wrong?
Thanks!
Never mind. I failed to supply the required parameter. I wish the
error message was less cryptic.
Sorry for the interruption.
th = 3;
inches = 25.4;
ht = 5 * inches;
oid = 3 * inches;
ood = oid + 2 * th;
module torus(id, r)
module snoot(sd) {
rotate([90, 0, 0])
torus(oid, sd);
snoot();
I get this error:
vec3 or vec2 of numbers in file , line 14
Thanks!
You can’t “overdefine”. The idea doesn’t make sense.
“module snoot(sd)” is likely the issue. You should to set a passing
variable to a default. In this case you are redefining sd, it isn’t the
same variable inside the module as what you defined at the top of the file.
There are a couple of things to do here. You don’t HAVE to, but I’d suggest
using a different variable name for sd inside the snoot module. It can save
you from the confusion you now face.
Next, set it to a default (not sure this is required, but is a good idea).
Make the default way different from a value you ever expect to use. This
helps debug if you forget to pass a value later.
Then, pass sd when you invoke snoot.
Since you redefine sd in the snoot module and don’t give it a default,
snoot() results in sd being undefined.
th = 3;
inches = 25.4;
ht = 5 * inches;
oid = 3 * inches;
ood = oid + 2 * th;
module torus(id, r)
module snoot(sd) {
rotate([90, 0, 0])
torus(oid, sd);
snoot();
I get this error:
WARNING: Unable to convert translate([undef, 0, 0]) parameter to a vec3 or
Thanks!
Changing the declaration to "module snoot(sd = sd) {" does what you want I
think - if a parameter is specified, it uses it, otherwise it defaults to
whatever "sd" is in scope (the global declaration at the top)
suggest using a different variable name for sd inside the snoot module. It
can save you from the confusion you now face.
th = 3;
inches = 25.4;
ht = 5 * inches;
oid = 3 * inches;
ood = oid + 2 * th;
module torus(id, r)
module snoot(sd) {
rotate([90, 0, 0])
torus(oid, sd);
snoot();
I get this error:
Thanks!
