                Wed, Jan 25, 2023 7:57 PM
                            I made a fairly simple model using minkowski and discovered that I get a
CGAL error if I make $fn large, but not when $fn is smaller.  Why does this
happen?  I tried to make a BOSL2 independent example, but the problem
didn't occur---maybe it is triggered by the presence of the top edge
roundover?
include<BOSL2/std.scad>
minkr=1;
d=44.5;
h=8;
finger_d=14;
top_r=3;
intersection(){
down(h/2)cuboid(100,anchor=BOTTOM);
minkowski(convexity=10)
difference(convexity=10){
cyl(d=d-2minkr,h=h,rounding2=top_r,$fn=100);
zrot_copies(n=3)
right(17)cyl(h=h+.02,d=finger_d+2minkr, rounding2=0, $fn=40);
sphere(r=minkr,$fn=20);
roundover?
minkr=1;
d=44.5;
h=8;
finger_d=14;
top_r=3;
intersection(){
      cyl(d=d-2*minkr,h=h,rounding2=top_r,$fn=100);
      zrot_copies(n=3)
        right(17)cyl(h=h+.02,d=finger_d+2*minkr, rounding2=0, $fn=40);
                    K
                                            Ken
                Wed, Jan 25, 2023 9:15 PM
                            How large did you make $fn Adrian?
I tried it with $fn=128, it took 30 minutes, but rendered ok on my
system. I'm using openscad version 2022.12.ci12950.
I am currently trying it with $fn=360- but that is going to take quite a
while on my system, I will keep you posted.
It did give me a "warning: variable convexity not specified as parameter
in file, line 14" which is "difference(convexity=10)"
a CGAL error if I make $fn large, but not when $fn is smaller.  Why
does this happen?  I tried to make a BOSL2 independent example, but
the problem didn't occur---maybe it is triggered by the presence of
the top edge roundover?
minkr=1;
d=44.5;
h=8;
finger_d=14;
top_r=3;
intersection(){
      zrot_copies(n=3)
Our job as parents is to teach them to control all three.
> minkr=1;
> d=44.5;
> h=8;
> finger_d=14;
> top_r=3;
> intersection(){
>       zrot_copies(n=3)
Cheers, Ken
bats059@gmail.com
https://sstv.vk7krj.com/all_bands.html
                Wed, Jan 25, 2023 10:21 PM
                            The version I posted won't render for me.   But if I lower $fn=40 to $fn=32
then it renders.
I am not sure where to put the convexity argument to get it to work
properly, as I keep getting preview artifacts.
I tried it with $fn=128, it took 30 minutes, but rendered ok on my system.
roundover?
minkr=1;
d=44.5;
h=8;
finger_d=14;
top_r=3;
intersection(){
zrot_copies(n=3)
Cheers, Kenbats059@gmail.comhttps://vk7krj.com/running.htmlhttps://sstv.vk7krj.com/all_bands.html
then it renders.
> roundover?
> minkr=1;
> d=44.5;
> h=8;
> finger_d=14;
> top_r=3;
> intersection(){
>       zrot_copies(n=3)
> A baby can be defined as an ego with a noise at one end and a smell at the other.
                Wed, Jan 25, 2023 10:43 PM
                            I think convexity is only relevant to modules that promote 2D to 3D, like
linear_extrude() and rotate_extrude(), import of 3D objects and polyhedron.
If you get a CGAL error, and have done a preview, it is always worth
clearing the cache and trying F6 again without a preview. F5 can cache bad
results.
$fn=32 then it renders.
roundover?
minkr=1;
d=44.5;
h=8;
finger_d=14;
top_r=3;
intersection(){
zrot_copies(n=3)
results.
>> roundover?
>> minkr=1;
>> d=44.5;
>> h=8;
>> finger_d=14;
>> top_r=3;
>> intersection(){
>>       zrot_copies(n=3)
                Wed, Jan 25, 2023 11:44 PM
like linear_extrude() and rotate_extrude(), import of 3D objects and
polyhedron.
Generally, it's things that derive 3D objects through mechanisms other
than primitives, transforms, or the basic booleans (union, difference,
intersection).  In addition to the ones you mention, there's surface,
resize, minkowski, and render.
Hull would be one, except that hulls are always convex.
Render is a relatively easy one to demonstrate:
        cube(10);
        translate([5,5,0]) cube(10);
    cube(5, center=true);
    render() union() {
        cube(10);
    render(convexity=2) union() {
        cube(10);
> polyhedron.
            cube(10);
        render() union() {
            cube(10);
            cube(10);
                Wed, Jan 25, 2023 11:52 PM
                            No, the problem is not about caching.  I had previously seen it on two
machines, and I just now tried clearing the cache and I still cannot render
after preview.
The problem does seem to be related to rounding over the already rounded
top edge.  I took that rounding out, and the render error vanished.
results.
roundover?
minkr=1;
d=44.5;
h=8;
finger_d=14;
top_r=3;
intersection(){
zrot_copies(n=3)
after preview.
> results.
>>> roundover?
>>> minkr=1;
>>> d=44.5;
>>> h=8;
>>> finger_d=14;
>>> top_r=3;
>>> intersection(){
>>>       zrot_copies(n=3)
