Re: [OpenSCAD] Need help on Render
N
Neon22
Fri, Aug 28, 2015 8:48 AM
That is beautiful :)
The problem seems to lie in the amount of time needed to do the difference
with that enormous spherical shell.
So I put a render in a different place and tried it with the smaller value
and it came out in a minute (reduced range).
Without the render it never starts (0/1000). With the render it went 22/1000
very quickly and came back with an object in a minute.
Cheers...
http://forum.openscad.org/file/n13625/mesh_disc-OpenSCAD_001079.png
module mesh(size=40, top=61,  bot=50) {
k =1.1;
for (x = [0: size])  {
for (y = [0: size]) {
// render()
rotate([(y2cos(30)k)-(202cos(30) k) + (cos(30) (x%2)k), (x1.5k
)-(201.5k), 0]) {
polyhedron (
points = [
[0.5,cos(30),top],[1,0,top],[0.5,-cos(30),top],[-0.5,-cos(30),top],[-1,0,top],[-0.5,cos(30),top],
[0.5,cos(30),bot],[1,0,bot],[0.5,-cos(30),bot],[-0.5,-cos(30),bot],[-1,0,bot],[-0.5,cos(30),bot]
faces = [
[0,1,2],[0,2,3],[0,3,4],[0,4,5],
[0,6,7],[0,7,1],[1,7,8],[1,8,2],[2,8,9],[2,9,3],[3,9,10],[3,10,4],[4,10,11],[4,11,5],[5,11,6],[5,6,0],
[6,8,7],[6,9,8] ,[6,10,9],[6,11,10]
module rim(rad=59, res=200) {
//rim
translate([0,0,cos(30)*rad]) {
cylinder(h = 2, r=32, center = true, $fn=res);
cylinder(h = 3, r=30, center = true, $fn=res);
module dome(rad1=60, rad2=59, res=200) {
render(); // had to add this to get it capable of doing F6
intersection()  {
difference()  {
sphere(rad1, $fn=res);
sphere(rad2, $fn=res);
cylinder(h = 100, r=30, $fn=res);
difference()  {
dome(60,59,100);
mesh(9,61,58);
//rim();
View this message in context: http://forum.openscad.org/Need-help-on-Render-tp13624p13625.html
That is beautiful :) The problem seems to lie in the amount of time needed to do the difference with that enormous spherical shell. So I put a render in a different place and tried it with the smaller value and it came out in a minute (reduced range). Without the render it never starts (0/1000). With the render it went 22/1000 very quickly and came back with an object in a minute. Cheers... <http://forum.openscad.org/file/n13625/mesh_disc-OpenSCAD_001079.png> // module mesh(size=40, top=61, bot=50) { k =1.1; for (x = [0: size]) { for (y = [0: size]) { // render() rotate([(y*2*cos(30)*k)-(20*2*cos(30) *k) + (cos(30)* (x%2)*k), (x*1.5*k )-(20*1.5*k), 0]) { polyhedron ( points = [ [0.5,cos(30),top],[1,0,top],[0.5,-cos(30),top],[-0.5,-cos(30),top],[-1,0,top],[-0.5,cos(30),top], [0.5,cos(30),bot],[1,0,bot],[0.5,-cos(30),bot],[-0.5,-cos(30),bot],[-1,0,bot],[-0.5,cos(30),bot] ], faces = [ [0,1,2],[0,2,3],[0,3,4],[0,4,5], [0,6,7],[0,7,1],[1,7,8],[1,8,2],[2,8,9],[2,9,3],[3,9,10],[3,10,4],[4,10,11],[4,11,5],[5,11,6],[5,6,0], [6,8,7],[6,9,8] ,[6,10,9],[6,11,10] ] ); } } } } module rim(rad=59, res=200) { //rim translate([0,0,cos(30)*rad]) { difference() { cylinder(h = 2, r=32, center = true, $fn=res); cylinder(h = 3, r=30, center = true, $fn=res); } } } module dome(rad1=60, rad2=59, res=200) { render(); // had to add this to get it capable of doing F6 intersection() { difference() { sphere(rad1, $fn=res); sphere(rad2, $fn=res); } cylinder(h = 100, r=30, $fn=res); } } // difference() { dome(60,59,100); mesh(9,61,58); //rim(); } -- View this message in context: http://forum.openscad.org/Need-help-on-Render-tp13624p13625.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Fri, Aug 28, 2015 11:09 AM
Neon22:
Your use of render() confuses me.  The manual says
render() {
some geometry
While you just say
render();
How does that work?
I have to say that I tried to use render() at one point and simply gave
up from confusion.  If it always renders (does an F6) for the specified
geometry, then how does it save time?  Or does the render only occur if
the source code in that geometry has changed since the most recent
render?  The documentation would benefit from a better example, IMHO.
Cheers...
k =1.1;
// render()
)-(201.5k), 0]) {
polyhedron (
points = [
faces = [
//rim
intersection()  {
difference()  {
difference()  {
dome(60,59,100);
mesh(9,61,58);
//rim();
Checked by AVG - www.avg.com
Version: 2015.0.6125 / Virus Database: 4409/10525 - Release Date: 08/27/15
Neon22: Your use of render() confuses me. The manual says render() { some geometry } While you just say render(); How does that work? I have to say that I tried to use render() at one point and simply gave up from confusion. If it always renders (does an F6) for the specified geometry, then how does it save time? Or does the render only occur if the source code in that geometry has changed since the most recent render? The documentation would benefit from a better example, IMHO. Jon On 8/28/2015 4:48 AM, Neon22 wrote: > That is beautiful :) > > The problem seems to lie in the amount of time needed to do the difference > with that enormous spherical shell. > So I put a render in a different place and tried it with the smaller value > and it came out in a minute (reduced range). > > Without the render it never starts (0/1000). With the render it went 22/1000 > very quickly and came back with an object in a minute. > Cheers... > > <http://forum.openscad.org/file/n13625/mesh_disc-OpenSCAD_001079.png> > // > module mesh(size=40, top=61, bot=50) { > k =1.1; > for (x = [0: size]) { > for (y = [0: size]) { > // render() > rotate([(y*2*cos(30)*k)-(20*2*cos(30) *k) + (cos(30)* (x%2)*k), (x*1.5*k > )-(20*1.5*k), 0]) { > polyhedron ( > points = [ > > [0.5,cos(30),top],[1,0,top],[0.5,-cos(30),top],[-0.5,-cos(30),top],[-1,0,top],[-0.5,cos(30),top], > > [0.5,cos(30),bot],[1,0,bot],[0.5,-cos(30),bot],[-0.5,-cos(30),bot],[-1,0,bot],[-0.5,cos(30),bot] > ], > faces = [ > [0,1,2],[0,2,3],[0,3,4],[0,4,5], > > [0,6,7],[0,7,1],[1,7,8],[1,8,2],[2,8,9],[2,9,3],[3,9,10],[3,10,4],[4,10,11],[4,11,5],[5,11,6],[5,6,0], > [6,8,7],[6,9,8] ,[6,10,9],[6,11,10] > ] > ); > } > } > } > } > > module rim(rad=59, res=200) { > //rim > translate([0,0,cos(30)*rad]) { > difference() { > cylinder(h = 2, r=32, center = true, $fn=res); > cylinder(h = 3, r=30, center = true, $fn=res); > } > } > } > > module dome(rad1=60, rad2=59, res=200) { > render(); // had to add this to get it capable of doing F6 > intersection() { > difference() { > sphere(rad1, $fn=res); > sphere(rad2, $fn=res); > } > cylinder(h = 100, r=30, $fn=res); > } > } > > // > difference() { > dome(60,59,100); > mesh(9,61,58); > //rim(); > } > > > > -- > View this message in context: http://forum.openscad.org/Need-help-on-Render-tp13624p13625.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > Version: 2015.0.6125 / Virus Database: 4409/10525 - Release Date: 08/27/15 > >
N
Neon22
Fri, Aug 28, 2015 1:11 PM
Sorry, Jon, I just don't know. I should look at the source I suppose.
My assumption is that the object gets sent to CGAL for resolving.
Therefore its cached and used in a further stage.
But I'm guessing...
View this message in context: http://forum.openscad.org/Need-help-on-Render-tp13624p13629.html
Sorry, Jon, I just don't know. I should look at the source I suppose. My assumption is that the object gets sent to CGAL for resolving. Therefore its cached and used in a further stage. But I'm guessing... -- View this message in context: http://forum.openscad.org/Need-help-on-Render-tp13624p13629.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sun, Aug 30, 2015 3:19 AM
jon_bondy wrote
The manual says
render() {
some geometry
While you just say
render();
How does that work?
The manual is correct.
render(); is basically a null statement, render nothing. So I can't see how
it makes a difference, I doubt it does. Actually I just measured it, no
difference.
render() is usually good where some geometry either;
a. doesn't preview well, F5 sometimes has trouble with complex items, the
render() will show the geometry correctly,
b. is repeated many times, the render()'ed geometry, once cached, /may/ be
faster to paint than the CSG preview.
The other effect, is when render()'ed in preview, that cached bit does NOT
need to be re-rendered for F6, hence F6 /may/ be faster, where F5 included
render()'s.
CGAL, F6 & render(), are cached, with the values of the tree for that
geometry, so a sphere(r=10) if it occurs multiple times will have one
geometry, however if you have a for(i) loop with sphere(r=i) the different
sizes will be different cached geometry, there will be no cache performance
improvement.
Depending on the geometry, you should generally have a guess at the
convexity parameter too. Otherwise the render() can be useless.
AFAIK, yes, if the geometry parameters don't change, it doesn't render. But
not based on source code as such, but have a look at the CSG Tree (under
Design menu), if an item there has the same parameters, it only evaluates
once (in that context).
In conclusion tho, I doubt the design here benefits from render(). Each of
the 41 x 41 hex elements that form the mesh is a distinct, the polyhedron is
probably cached, but it then has to be modified 1600+ times...
View this message in context: http://forum.openscad.org/Need-help-on-Render-tp13624p13643.html
jon_bondy wrote > The manual says > > render() { > some geometry > } > > While you just say > > render(); > > How does that work? The manual is correct. render(); is basically a null statement, render nothing. So I can't see how it makes a difference, I doubt it does. Actually I just measured it, no difference. render() is usually good where some geometry either; a. doesn't preview well, F5 sometimes has trouble with complex items, the render() will show the geometry correctly, b. is repeated many times, the render()'ed geometry, once cached, /may/ be faster to paint than the CSG preview. The other effect, is when render()'ed in preview, that cached bit does NOT need to be re-rendered for F6, hence F6 /may/ be faster, where F5 included render()'s. CGAL, F6 & render(), are cached, with the values of the tree for that geometry, so a sphere(r=10) if it occurs multiple times will have one geometry, however if you have a for(i) loop with sphere(r=i) the different sizes will be different cached geometry, there will be no cache performance improvement. Depending on the geometry, you should generally have a guess at the convexity parameter too. Otherwise the render() can be useless. jon_bondy wrote > I have to say that I tried to use render() at one point and simply gave > up from confusion. If it always renders (does an F6) for the specified > geometry, then how does it save time? Or does the render only occur if > the source code in that geometry has changed since the most recent > render? The documentation would benefit from a better example, IMHO. AFAIK, yes, if the geometry parameters don't change, it doesn't render. But not based on source code as such, but have a look at the CSG Tree (under Design menu), if an item there has the same parameters, it only evaluates once (in that context). In conclusion tho, I doubt the design here benefits from render(). Each of the 41 x 41 hex elements that form the mesh is a distinct, the polyhedron is probably cached, but it then has to be modified 1600+ times... ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/Need-help-on-Render-tp13624p13643.html Sent from the OpenSCAD mailing list archive at Nabble.com.
N
Neon22
Sun, Aug 30, 2015 6:07 AM
@MichaelAtOz thanks for the clarity. I'm mystified then as to how the render
went from never completing ( in 10 mins) to completing in < minute for this
particular object. Clearly its not related to render() but just a
coincidence as Ive worked on the object.
My comment was based on my experience with this object and what I noticed
which was this:
  • in regular F9 preview mode, if the user gets close to the underside of the
    mesh where it intersects the spheres, the geo will flash in and out of
    visibility.
  • I believe this is due to the massive Bounding box of the difference
    operator (I see this all the time if a second object in the difference is
    very large compared to the first. In fact I try to make my  clipping objects
    as small as reasonable to avoid this visual side effect.)
  • So I "moduled" (not really a verb) the parts and then rendered
    (incorrectly) the spheres, hoping that what this meant was that the tree for
    this part would be cached at the module boundary and so speed up the whole
    process as opposed to being recalculated 40x40 times.
My thought process is clearly wrong but its still a mystery to me as to what
I did to make it speed up. Maybe it was simply turning aspects into modules
View this message in context: http://forum.openscad.org/Need-help-on-Render-tp13624p13644.html
@MichaelAtOz thanks for the clarity. I'm mystified then as to how the render went from never completing ( in 10 mins) to completing in < minute for this particular object. Clearly its not related to render() but just a coincidence as Ive worked on the object. My comment was based on my experience with this object and what I noticed which was this: - in regular F9 preview mode, if the user gets close to the underside of the mesh where it intersects the spheres, the geo will flash in and out of visibility. - I believe this is due to the massive Bounding box of the difference operator (I see this all the time if a second object in the difference is very large compared to the first. In fact I try to make my clipping objects as small as reasonable to avoid this visual side effect.) - So I "moduled" (not really a verb) the parts and then rendered (incorrectly) the spheres, hoping that what this meant was that the tree for this part would be cached at the module boundary and so speed up the whole process as opposed to being recalculated 40x40 times. My thought process is clearly wrong but its still a mystery to me as to what I did to make it speed up. Maybe it was simply turning aspects into modules ? -- View this message in context: http://forum.openscad.org/Need-help-on-Render-tp13624p13644.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sun, Aug 30, 2015 11:19 AM
Nice explanation.  If we can get content like this into the manual, I
think it would be helpful to others.
So, just to be clear, performance improvements can be expected if
  1. the same geometry is used repeatedly, since it will only need to be
    computed once; or
  2. F6 can be sped up after an F5 has computed the geometry initially
On 8/29/2015 11:19 PM, MichaelAtOz wrote:
jon_bondy wrote
The manual says
render() {
some geometry
While you just say
render();
How does that work?
difference.
render()'s.
improvement.
Version: 2015.0.6125 / Virus Database: 4409/10540 - Release Date: 08/29/15
Nice explanation. If we can get content like this into the manual, I think it would be helpful to others. So, just to be clear, performance improvements can be expected if 1) the same geometry is used repeatedly, since it will only need to be computed once; or 2) F6 can be sped up after an F5 has computed the geometry initially Jon On 8/29/2015 11:19 PM, MichaelAtOz wrote: > jon_bondy wrote >> The manual says >> >> render() { >> some geometry >> } >> >> While you just say >> >> render(); >> >> How does that work? > The manual is correct. > > render(); is basically a null statement, render nothing. So I can't see how > it makes a difference, I doubt it does. Actually I just measured it, no > difference. > > render() is usually good where some geometry either; > a. doesn't preview well, F5 sometimes has trouble with complex items, the > render() will show the geometry correctly, > b. is repeated many times, the render()'ed geometry, once cached, /may/ be > faster to paint than the CSG preview. > > The other effect, is when render()'ed in preview, that cached bit does NOT > need to be re-rendered for F6, hence F6 /may/ be faster, where F5 included > render()'s. > > CGAL, F6 & render(), are cached, with the values of the tree for that > geometry, so a sphere(r=10) if it occurs multiple times will have one > geometry, however if you have a for(i) loop with sphere(r=i) the different > sizes will be different cached geometry, there will be no cache performance > improvement. > > Depending on the geometry, you should generally have a guess at the > convexity parameter too. Otherwise the render() can be useless. > > > jon_bondy wrote >> I have to say that I tried to use render() at one point and simply gave >> up from confusion. If it always renders (does an F6) for the specified >> geometry, then how does it save time? Or does the render only occur if >> the source code in that geometry has changed since the most recent >> render? The documentation would benefit from a better example, IMHO. > AFAIK, yes, if the geometry parameters don't change, it doesn't render. But > not based on source code as such, but have a look at the CSG Tree (under > Design menu), if an item there has the same parameters, it only evaluates > once (in that context). > > In conclusion tho, I doubt the design here benefits from render(). Each of > the 41 x 41 hex elements that form the mesh is a distinct, the polyhedron is > probably cached, but it then has to be modified 1600+ times... > > > > > > ----- > Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. > > The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ > -- > View this message in context: http://forum.openscad.org/Need-help-on-Render-tp13624p13643.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > Version: 2015.0.6125 / Virus Database: 4409/10540 - Release Date: 08/29/15
Sun, Aug 30, 2015 9:06 PM
For your 1) case, that is for F5, but F5 also caches (different cache)
without render(), so it depends on the geometry I think. However, with
render() the first F5 will be slower...
As a general statement. Unless something doesn't display properly - like I'm
finding for text() - in preview (F5), don't bother with render().
Another technique some people use is to export the complex bits as a STL,
import() them, as they have been rendered hence that bit doesn't need to be
rendered again (if that part of the model is stable).
View this message in context: http://forum.openscad.org/Need-help-on-Render-tp13624p13648.html
For your 1) case, that is for F5, but F5 also caches (different cache) without render(), so it depends on the geometry I think. However, with render() the first F5 will be slower... As a general statement. Unless something doesn't display properly - like I'm finding for text() - in preview (F5), don't bother with render(). Another technique some people use is to export the complex bits as a STL, import() them, as they have been rendered hence that bit doesn't need to be rendered again (if that part of the model is stable). ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/Need-help-on-Render-tp13624p13648.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sun, Aug 30, 2015 9:08 PM
...and if you notice a laggie display refresh on preview, render() can help.
Compare the display responsiveness of a non-trivial model after F5 v's F6.
View this message in context: http://forum.openscad.org/Need-help-on-Render-tp13624p13649.html
...and if you notice a laggie display refresh on preview, render() can help. Compare the display responsiveness of a non-trivial model after F5 v's F6. ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/Need-help-on-Render-tp13624p13649.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sun, Aug 30, 2015 10:30 PM
BTW, your model renders, without render(), in 12m 55s on my 2.54GHz system.
It caches as it goes, so if you cancelled after 10m, then added the
render();, most of it was already cached so it just had to finish the rest.
View this message in context: http://forum.openscad.org/Need-help-on-Render-tp13624p13650.html
Neon22 wrote > I'm mystified then as to how the render went from never completing ( in 10 > mins) to completing in < minute for this particular object. BTW, your model renders, without render(), in 12m 55s on my 2.54GHz system. It caches as it goes, so if you cancelled after 10m, then added the render();, most of it was already cached so it just had to finish the rest. ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/Need-help-on-Render-tp13624p13650.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sun, Aug 30, 2015 10:41 PM
Large text() can create lots of vertices, so render() can help
with display performance in some cases.
If the display looks strange, that's more likely an issue with
unknown/wrong convexity, e.g.
cube([30, 30, 10], center=true);
linear_extrude(30, center=true) text("W");
produces lots of preview artifacts on my system.
Adding convexity=4 to the linear_extrude fixes that.
I guess it's pretty much model dependent if it's better to
just give the correct convexity or use render() to workaround
the display issue by forcing the mesh calculation.
On 08/30/2015 11:06 PM, MichaelAtOz wrote: > As a general statement. Unless something doesn't display properly - like I'm > finding for text() - in preview (F5), don't bother with render(). > Large text() can create lots of vertices, so render() can help with display performance in some cases. If the display looks strange, that's more likely an issue with unknown/wrong convexity, e.g. difference() { cube([30, 30, 10], center=true); linear_extrude(30, center=true) text("W"); } produces lots of preview artifacts on my system. Adding convexity=4 to the linear_extrude fixes that. I guess it's pretty much model dependent if it's better to just give the correct convexity or use render() to workaround the display issue by forcing the mesh calculation. ciao, Torsten.
