John David
Wed, Feb 25, 2026 6:57 PM
I have a project where I set the alpha channel (via color("#RRGGBBAA")),
but later the alpha channel is reset to its default value of 0xFF. I see
that this is related to at least one known problem going back 14+
years ago. Are there any known tricks to work around this?
Also to note, this is happening incorrectly even in preview, I saw a note
that it sometimes works incorrectly in rendering.
Thanks in advance.
EBo --
Thanks in advance.
EBo --
Wed, Feb 25, 2026 7:22 PM
color("#RRGGBBAA")), but later the alpha channel is reset to its
default value of 0xFF. I see that this is related to at least one
known problem going back 14+ years ago. Are there any known tricks to
work around this?
note that it sometimes works incorrectly in rendering.
It wouldn't surprise me at all if there was misbehavior, but I don't
think this will be actionable without an example.
One known misbehavior is that, unlike everything else in geometry
handling, order matters when you're dealing with transparency. Worse,
there are cases where you cannot make it work. Ref issue #1390
https://github.com/openscad/openscad/issues/1390.
translate([0,4,0]) color("green", alpha=0.3) cube([10,1,10]);
color("red", alpha=0.3) cube([10,1,10]);
if you look at it from -Y, you see:
but if you look at it from +Y, you see:
Note that in the first the green is visible behind the red, but in the
second the red is not at all visible behind the green.
> work around this?
<https://github.com/openscad/openscad/issues/1390>.
Wed, Feb 25, 2026 7:32 PM
[ Sigh. Copying an image from Edge to Thunderbird did not copy the
image; it copied a link to the image... that didn't work. Let's try again. ]
work around this?
> work around this?
John David
Wed, Feb 25, 2026 8:30 PM
Sorry for not providing and example, and your example points out something
I did eventually find. Here are some of the details:
- model.color("RRGGBB",alpha=0.3) works. But model.color("RRGGBBAA") does
not. The alpha channel is overwritten. I have found the issue and have a
fix
I tracked down the problem to line 2358 of pyfunctions.cc. Here is a
snippet:
Vector4d col(0, 0, 0, alpha);
if (!python_vectorval(color, 3, 4, &col[0], &col[1], &col[2], &col[3])) {
node->color.setRgba(float(col[0]), float(col[1]), float(col[2]),
float(col[3]));
} else if (PyUnicode_Check(color)) {
PyObject *value = PyUnicode_AsEncodedString(color, "utf-8", "~");
char *colorname = PyBytes_AS_STRING(value);
const auto color = OpenSCAD::parse_color(colorname);
if (color) {
node->color = *color;
node->color.setAlpha(alpha); // This is the problematic line of code.
} else {
PyErr_SetString(PyExc_TypeError, "Cannot parse color");
return NULL;
I was able to fix the problem by adding "if (1.0 != alpha)" before
the node->color.setAlpha(alpha); It turns out that the call to
python_color_core had already properly parsed the color as RRGGBBAA, and
appropriately deals with RRGGBB, RGBA, and RGB as well. The only time you
need to overwrite the alpha is when it is passed in via a second argument,
ie: model.color(str, alpha=something).
If it would not be outright rejected, I'll post an issue on GitHub and
request a PR to fix it. The question is if the developers would accept it.
EBo --
On Wed, Feb 25, 2026 at 2:32 PM Jordan Brown openscad@jordan.maileater.net
[ Sigh. Copying an image from Edge to Thunderbird did not copy the image;
It wouldn't surprise me at all if there was misbehavior, but I don't think
* model.color("RRGGBB",alpha=0.3) works. But model.color("RRGGBBAA") does
fix
snippet:
float(col[3]));
if (color) {
} else {
return NULL;
EBo --
On Wed, Feb 25, 2026 at 2:32 PM Jordan Brown <openscad@jordan.maileater.net>
John David
Wed, Feb 25, 2026 8:33 PM
I do not know if my fix above solves what you show as the ordering problem
(which apparently has been known for over 14 years). It only solves the
problem of losing the alpha channel when parsing colors by hex value of
#RRGGBBAA.
fix
snippet:
float(col[3]));
if (color) {
} else {
return NULL;
EBo --
#RRGGBBAA.
> fix
> snippet:
> float(col[3]));
> if (color) {
> } else {
> return NULL;
> EBo --
Wed, Feb 25, 2026 9:55 PM
problem (which apparently has been known for over 14 years). It only
solves the problem of losing the alpha channel when parsing colors by
hex value of #RRGGBBAA.
To be clear: the new problem that you're describing applies only to
PythonSCAD, not to old-school OpenSCAD.
And yes, the other has been known for a long time... that doesn't mean
it's easy to fix, or that it's important to fix for the core OpenSCAD
audience.
audience.
John David
Wed, Feb 25, 2026 10:04 PM
Sorry. I thought it applied to both PythonSCAD and OpenSCAD. I'll
double-check. I'll do a PR on PythonSCAD then. Sorry for the noise.
On Wed, Feb 25, 2026 at 4:55 PM Jordan Brown openscad@jordan.maileater.net
#RRGGBBAA.
audience.
On Wed, Feb 25, 2026 at 4:55 PM Jordan Brown <openscad@jordan.maileater.net>
> #RRGGBBAA.
> audience.
John David
Wed, Feb 25, 2026 10:16 PM
I just verified that the issue is in the old-school OpenSCAD version as
well, but I reported the line number from the PythonSCAD version of the
code. Sorry about that.
Take a look at line 999 in ./src/python/pyfunctions.cc from a clean git
clone of openscad. Here is the relevant code snippet:
if (color) {
} else {
The call to parse_color takes in a string "#RRGGBBAA" and parses it
correctly. alpha is set from the call to export("#RRGGBBAA",[alpha=1.0]).
The default for alpha=1.0 which overwrites the colors alpha channel
always. The fix was to simply add "if (1.0!=alpha)" before the setAlpha
call.
EBo --
solves the problem of losing the alpha channel when parsing colors by hex
value of #RRGGBBAA.
audience.
if (color) {
} else {
call.
EBo --
>> value of #RRGGBBAA.
>> audience.
Wed, Feb 25, 2026 11:22 PM
as well, but I reported the line number from the PythonSCAD version of
the code. Sorry about that.
Sorry, I was unclear on my terminology.
I meant that it applies only to programs written in Python (no matter
which distribution they are running on), and not to programs written in
OpenSCAD-language.
In OpenSCAD-language:
color("#FF000080") cube(10);
correctly produces a transparent red cube.
OpenSCAD-language.
John David
Thu, Feb 26, 2026 12:40 AM
Ahhh... OK. I agree that it is python only, but the bug is in both source
trees.
I guess I will go ahead and post a PR for the OpenSCAD specific fix and
just try to move it forward.
BTW, what I am using it for is part of Guenther's and my work on developing
a *SCAD to laser cutter gcode path. At this point, we have it very close
to working, and I can do things like make some part, preview, render, and
export to gcode. Guenther also fixed something in PythonSCAD which allows
us to do a model.export(filename) directly in the PythonSCAD script, and it
will generate the gcode when you run preview. At the moment I am tracking
down a bug exposed in a special case I have on a project where I have
multiple materials (3mm plywood, and 0.75" pine) that are parametrically
used in a single OpenSCAD script so I can visualize how the parts fit
together, but I would like to generate the 3mmply.gcode separate from the
0.75"pine.gcode for cutting on the laser cutter...
Once I get a first pass running in PythonSCAD, I would like to back port it
to OpenSCAD. That said, I need to get it fully working on at least one of
the platforms.
EBo --
trees.
the platforms.
EBo --
