JW
Joe Weinpert
Fri, May 30, 2025 8:19 PM
Could you please provide guidance on how to import an SVG file into
openSCAD and represent it as a list of points?
Thank you,
Joe Weinpert
joe.weinpert@gmail.com
www.jwstudio.art http://jwstudio.art
Thank you,
Joe Weinpert
www.jwstudio.art <http://jwstudio.art>
Sat, May 31, 2025 5:39 AM
Using base OpenSCAD, you can't. You can import an SVG file as a
polygon, but you cannot extract the list of points.
However, it happens that I just saw something using the Pathbuilder
library that consumes SVG path text and returns points. See
https://openscad.org/libraries.html#pathbuilder .
The documentation says that it accepts the full SVG syntax, but I think
that's a little misleading. It looks like it accepts the SVG path
syntax. That's important for two reasons: (1) SVG per se is an
XML-based format of which paths are only one part, and (2) not all SVG
shapes are represented as paths. I just created a test file and
happened to draw an ellipse; it's represented in the SVG with the
<ellipse> element, not as a path.
Anyhow, if you convert everything into paths then you might be able to
copy-and-paste the path strings out of the SVG and into OpenSCAD source,
and use Pathbuilder to process them.
that's a little misleading. It looks like it accepts the SVG *path*
Sat, May 31, 2025 8:55 AM
You can use search and replace in a text editor to convert an SVG file
to an OpenSCAD polygon format. Then, if you want to do it a number of
times, then get ChatGPT to write a python script to do the same.
> Thank you,
> Joe Weinpert
JW
Joe Weinpert
Sat, May 31, 2025 1:04 PM
Hi Jordan and Raymond,
Thanks for your insights. It sounds like the method I've been using is
indeed the way to go:
- Create a drawing in Aspire.
- Export it as an SVG.
- Use UltraEdit to extract only the path information.
- Copy and paste the path data into OpenSCAD as a string variable.
- Utilize Pathbuilder's
svgPoints() function to create the list of
points.
- Finally, use BOSL2's
deduplicate() function to ensure a clean list.
Thanks again for confirming this approach.
Best,
Joe
On Sat, May 31, 2025 at 4:55 AM Raymond West via Discuss <
You can use search and replace in a text editor to convert an SVG file to
an OpenSCAD polygon format. Then, if you want to do it a number of times,
Thank you,
Joe Weinpert
1. Create a drawing in Aspire.
2. Export it as an SVG.
3. Use UltraEdit to extract only the path information.
4. Copy and paste the path data into OpenSCAD as a string variable.
5. Utilize Pathbuilder's `svgPoints()` function to create the list of
points.
6. Finally, use BOSL2's `deduplicate()` function to ensure a clean list.
Best,
Joe
> Thank you,
> Joe Weinpert
RV
Roel Vanhout
Sat, May 31, 2025 6:43 PM
There are a few Inkscape plugins that automate much of this - basically
letting you copy/paste from Inkscape into Openscad point lists. I don't
remember much of the details, and I have my own plugin that also copies
curve date in various formats to the clipboard, so I sometimes mix and
match depending on what exactly I'm doing. But it's worth looking into
existing plugins, manually copying and fixing up gets old fast.
Cheers
On Sat, May 31, 2025, 15:05 Joe Weinpert via Discuss <
points.
Best,
Joe
Thank you,
Joe Weinpert
Cheers
> points.
> Best,
> Joe
>> Thank you,
>> Joe Weinpert
Sat, May 31, 2025 8:43 PM
I don't do these things, but it sure feels as if this comes up
repeatedly. Maybe a Wiki page or similar?
basically letting you copy/paste from Inkscape into Openscad point
lists. I don't remember much of the details, and I have my own plugin
that also copies curve date in various formats to the clipboard, so I
sometimes mix and match depending on what exactly I'm doing. But it's
worth looking into existing plugins, manually copying and fixing up
gets old fast.
Cheers
using is indeed the way to go:
of points.
list.
Best,
Joe
SVG file to an OpenSCAD polygon format. Then, if you want to
do it a number of times, then get ChatGPT to write a python
file into openSCAD and represent it as a list of points?
Thank you,
Joe Weinpert
> gets old fast.
> Cheers
> of points.
> list.
> Best,
> Joe
>> Thank you,
>> Joe Weinpert
>> To unsubscribe send an email todiscuss-leave@lists.openscad.org
