Command line syntax issue - variable not specified as a parameter
PB
Peter Bates
Sun, Apr 2, 2023 11:57 AM
Hi all.
When calling an OpenSCAD script from the command line, I get the following error:
"...-D "base=3.0" -D "stiffeningfactor=3.0" -D "detail=11.5" -D "height=3.0" "coexcuscad_V2.scad"
Could not initialize localization.
WARNING: variable id not specified as parameter, in file coexcuscad_V2.scad, line 23
WARNING: variable id not specified as parameter, in file coexcuscad_V2.scad, line 27
WARNING: variable id not specified as parameter, in file coexcuscad_V2.scad, line 31"
The lines in question are as follows:
"    linear_extrude(height = base, center = false, convexity = 10)
offset(r=blade*2, $fn=quality)
import (file = inputfile, id = "layer2");
offset(r=blade, $fn=quality)
import (file = inputfile, id = "layer3");
import (file = inputfile, id = "layer4");"
The idea is that each linear extrude is performed on a separate layer of the SVG, denoted by the id of the layer
I am not sure why it wants me to specify this as a parameter - it would need to be different for each operation and I am not sure how to do that?
Any help is greatly appreciated!
Hi all. When calling an OpenSCAD script from the command line, I get the following error: "...-D "base=3.0" -D "stiffeningfactor=3.0" -D "detail=11.5" -D "height=3.0" "coexcuscad_V2.scad" Could not initialize localization. WARNING: variable id not specified as parameter, in file coexcuscad_V2.scad, line 23 WARNING: variable id not specified as parameter, in file coexcuscad_V2.scad, line 27 WARNING: variable id not specified as parameter, in file coexcuscad_V2.scad, line 31" The lines in question are as follows: " linear_extrude(height = base, center = false, convexity = 10) offset(r=blade*2, $fn=quality) import (file = inputfile, id = "layer2"); linear_extrude(height = base, center = false, convexity = 10) offset(r=blade, $fn=quality) import (file = inputfile, id = "layer3"); linear_extrude(height = base, center = false, convexity = 10) offset(r=blade, $fn=quality) import (file = inputfile, id = "layer4");" The idea is that each linear extrude is performed on a separate layer of the SVG, denoted by the id of the layer I am not sure why it wants me to specify this as a parameter - it would need to be different for each operation and I am not sure how to do that? Any help is greatly appreciated!
Sun, Apr 2, 2023 12:06 PM
Looks like the version of openscad run from the command line does not have
an id parameter to import.
On Sun, 2 Apr 2023, 12:57 Peter Bates, peter.bates@live.co.za wrote:
Hi all.
error:
Looks like the version of openscad run from the command line does not have an id parameter to import. On Sun, 2 Apr 2023, 12:57 Peter Bates, <peter.bates@live.co.za> wrote: > Hi all. > > When calling an OpenSCAD script from the command line, I get the following > error: > > "...-D "base=3.0" -D "stiffeningfactor=3.0" -D "detail=11.5" -D > "height=3.0" "coexcuscad_V2.scad" > Could not initialize localization. > WARNING: variable id not specified as parameter, in file > coexcuscad_V2.scad, line 23 > WARNING: variable id not specified as parameter, in file > coexcuscad_V2.scad, line 27 > WARNING: variable id not specified as parameter, in file > coexcuscad_V2.scad, line 31" > > The lines in question are as follows: > > " linear_extrude(height = base, center = false, convexity = 10) > offset(r=blade*2, $fn=quality) > import (file = inputfile, id = "layer2"); > > linear_extrude(height = base, center = false, convexity = 10) > offset(r=blade, $fn=quality) > import (file = inputfile, id = "layer3"); > > linear_extrude(height = base, center = false, convexity = 10) > offset(r=blade, $fn=quality) > import (file = inputfile, id = "layer4");" > > The idea is that each linear extrude is performed on a separate layer of > the SVG, denoted by the id of the layer > I am not sure why it wants me to specify this as a parameter - it would > need to be different for each operation and I am not sure how to do that? > > Any help is greatly appreciated! > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
PB
Peter Bates
Sun, Apr 2, 2023 12:37 PM
You're right. Used the dev preview for the new id feature nd did not purge the old version correctly
Thanks
Sent: Sunday, 02 April 2023 14:06
Subject: [OpenSCAD] Re: Command line syntax issue - variable not specified as a parameter
On Sun, 2 Apr 2023, 12:57 Peter Bates, <peter.bates@live.co.zamailto:peter.bates@live.co.za> wrote:
Hi all.
You're right. Used the dev preview for the new id feature nd did not purge the old version correctly Thanks ________________________________ From: nop head <nop.head@gmail.com> Sent: Sunday, 02 April 2023 14:06 To: OpenSCAD general discussion Mailing-list <discuss@lists.openscad.org> Subject: [OpenSCAD] Re: Command line syntax issue - variable not specified as a parameter Looks like the version of openscad run from the command line does not have an id parameter to import. On Sun, 2 Apr 2023, 12:57 Peter Bates, <peter.bates@live.co.za<mailto:peter.bates@live.co.za>> wrote: Hi all. When calling an OpenSCAD script from the command line, I get the following error: "...-D "base=3.0" -D "stiffeningfactor=3.0" -D "detail=11.5" -D "height=3.0" "coexcuscad_V2.scad" Could not initialize localization. WARNING: variable id not specified as parameter, in file coexcuscad_V2.scad, line 23 WARNING: variable id not specified as parameter, in file coexcuscad_V2.scad, line 27 WARNING: variable id not specified as parameter, in file coexcuscad_V2.scad, line 31" The lines in question are as follows: " linear_extrude(height = base, center = false, convexity = 10) offset(r=blade*2, $fn=quality) import (file = inputfile, id = "layer2"); linear_extrude(height = base, center = false, convexity = 10) offset(r=blade, $fn=quality) import (file = inputfile, id = "layer3"); linear_extrude(height = base, center = false, convexity = 10) offset(r=blade, $fn=quality) import (file = inputfile, id = "layer4");" The idea is that each linear extrude is performed on a separate layer of the SVG, denoted by the id of the layer I am not sure why it wants me to specify this as a parameter - it would need to be different for each operation and I am not sure how to do that? Any help is greatly appreciated! _______________________________________________ OpenSCAD mailing list To unsubscribe send an email to discuss-leave@lists.openscad.org<mailto:discuss-leave@lists.openscad.org>
