children not being passed to submodules
a.human
Sat, Oct 15, 2016 9:10 PM
This works:
// Cut along y axis
module cut_shape_y(keep = "left"){
if(keep == "left"){
intersection(){ children(); left_xy_plane(); }
}else if(keep == "right"){
intersection(){ children(); right_xy_plane(); }
}else if (keep == "both"){
xy_plane modules are simply large squares that define the planes to enable
various cutting operations and such.
However, the following does not work, and issues no warnings or errors. It
simply draws the plane, the intersection never occurs because (I think) the
submodule doesn't receive the children of the main module.
// Cut along y axis
module left(){
intersection(){
left_xy_plane();
module right(){
intersection(){
right_xy_plane();
if(keep == "left"){ left();}
else if(keep == "right"){ right();}
else if (keep == "both"){ left(); right();}
Even calling left() children(); doesn't work instead of just left(); as in
the code above.
This is a scoping issue. Either it should throw a warning specifying that
submodules cannot access module's children, or better yet, it should work.
View this message in context: http://forum.openscad.org/children-not-being-passed-to-submodules-tp18722.html
This works: // Cut along y axis module cut_shape_y(keep = "left"){ if(keep == "left"){ intersection(){ children(); left_xy_plane(); } }else if(keep == "right"){ intersection(){ children(); right_xy_plane(); } }else if (keep == "both"){ intersection(){ children(); left_xy_plane(); } intersection(){ children(); right_xy_plane(); } } } xy_plane modules are simply large squares that define the planes to enable various cutting operations and such. However, the following does not work, and issues no warnings or errors. It simply draws the plane, the intersection never occurs because (I think) the submodule doesn't receive the children of the main module. // Cut along y axis module cut_shape_y(keep = "left"){ module left(){ intersection(){ children(); left_xy_plane(); } } module right(){ intersection(){ children(); right_xy_plane(); } } if(keep == "left"){ left();} else if(keep == "right"){ right();} else if (keep == "both"){ left(); right();} } Even calling left() children(); doesn't work instead of just left(); as in the code above. This is a scoping issue. Either it should throw a warning specifying that submodules cannot access module's children, or better yet, it should work. -- View this message in context: http://forum.openscad.org/children-not-being-passed-to-submodules-tp18722.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sat, Oct 15, 2016 9:26 PM
Are you sure you did not do:
left(); /* <- extra semicolon */ children(); ?
What I've tested worked fine, if it's still not working
for you, I'd suggest to post a fully working example
instead of just a snippet.
On 10/15/2016 11:10 PM, a.human wrote: > Even calling left() children(); doesn't work instead of > just left(); as in the code above. > Are you sure you did not do: left(); /* <- extra semicolon */ children(); ? What I've tested worked fine, if it's still not working for you, I'd suggest to post a fully working example instead of just a snippet. ciao, Torsten.
a.human
Sat, Oct 15, 2016 9:37 PM
Oops! Embarrassed :)
You are right, I did left(); children(); instead of left() children();
Thanks much,Have a great day,A human
  1. Oct 2016 02:57 by ml-node+s1091067n18723h32@n5.nabble.com:
[hidden email]
			-- Torsten			>
If you reply to this email, your message will be added to the discussion below:> > http://forum.openscad.org/children-not-being-passed-to-submodules-tp18722p18723.html> > > To unsubscribe from children not being passed to submodules, > click here> .
NAML>
View this message in context: http://forum.openscad.org/children-not-being-passed-to-submodules-tp18722p18724.html
Oops! Embarrassed :) You are right, I did left(); children(); instead of left() children(); Thanks much,Have a great day,A human 16. Oct 2016 02:57 by ml-node+s1091067n18723h32@n5.nabble.com: > On 10/15/2016 11:10 PM, a.human wrote: > > Even calling left() children(); doesn't work instead of > > just left(); as in the code above. > > > Are you sure you did not do: > > left(); /* <- extra semicolon */ children(); ? > > What I've tested worked fine, if it's still not working > for you, I'd suggest to post a fully working example > instead of just a snippet. > > ciao, >   Torsten. > > > _______________________________________________ > OpenSCAD mailing list > [hidden email] > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > -- Torsten > > > > > > If you reply to this email, your message will be added to the discussion below:> > http://forum.openscad.org/children-not-being-passed-to-submodules-tp18722p18723.html> > > To unsubscribe from children not being passed to submodules, > click here> . > > NAML> -- View this message in context: http://forum.openscad.org/children-not-being-passed-to-submodules-tp18722p18724.html Sent from the OpenSCAD mailing list archive at Nabble.com.
