Hello
I have made a cylindrical shell using binary difference between two cylinders.
I have made a cubic bezier curve using this : https://openhome.cc/eGossip/OpenSCAD/BezierCurve.html
The bezier_coordinate function spits out the coordinates for a polyline to be drawn.
I can project these points on the surface of the cylindrical shell, effectivly "wrapping the curve" on the outer cylindrical surface , The curve is a closed curve,
I want to find a way to cut the cylindrical shell along this line. As if, an arbitrarily small milling bit has milled through the entire depth of the shell , splitting it in different parts.
How is that possible using openscad. Thank you.
Ihr Recht auf Privatsphäre. Schützen Sie Ihre Daten und wechseln jetzt zu eclipso Mail & Cloud.
I think you need to convert the point list into a polyhedron by adding a
second set of points on a circle bigger than the tube and further away then
its end. Then list all the faces to connect those points to your curve.
That would give a 3D shape that you can subtract from the tube to cut it.
On Fri, 23 Apr 2021 at 23:02, Sayandeep Khan seany@eclipso.de wrote:
Hello
cylinders.
be drawn.
Mail & Cloud https://www.eclipso.de.
How can we extract such faces from a shell given some conditions?
Thank you> Von: nop head <nop.head@gmail.com>
Datum: 24.04.2021 00:30:51
An: Sayandeep Khan <seany@eclipso.de>, OpenSCAD general discussion <discuss@lists.openscad.org>
Betreff: Re: [OpenSCAD] Cutting a Cylindrical shellI think you need to convert the point list into a polyhedron by adding a second set of points on a circle bigger than the tube and further away then its end. Then list all the faces to connect those points to your curve. That would give a 3D shape that you can subtract from the tube to cut it.
On Fri, 23 Apr 2021 at 23:02, Sayandeep Khan <seany@eclipso.de> wrote:
Hello
You could simply duplicate the points and give them two different z values,
one where you want the cut and the other far away. Concatenate the lists
and pass that as the point list for polyhedron. Then for the faces list you
need to make the walls and the endcaps by listing triangles that index the
point list.
Thank you
Von: nop head nop.head@gmail.com
An: Sayandeep Khan seany@eclipso.de, OpenSCAD general discussion <
http://seany%40eclipso.de> wrote:
Hello
cylinders.
be drawn.
http://discuss-leave%40lists.openscad.org
I'd be happy to cook up a demonstration, but I don't have time right now.
Here's the basic theory...
Have you looked at how you build a polyhedron? You define a bunch of
points, and then you connect groups of those points into faces that all
add up to being the polyhedron.
The idea here is that you're going to build a polyhedron that mostly
looks like a cylinder a bit bigger than the cylinder that you're going
to cut, except that the top of this polyhedron is wavy, using your
Bezier curve.
If your curve is planar, there are simple ways to do it. If the curve is
general and non-planar, the suggestions given by others here apply, but
constructing a polyhedron from the ground up can be cumbersome.
Perhaps another approach is workable by first modelling the small drill
bit as a small polyhedron, then place copies of it, properly oriented,
in every point along the split curve. Union pairs of neighbouring drill
bits and use them to subtract from the cylindrical shell. When done for
all pairs, the result is a split cylinder.
Indeen my curve is not planer any more after wrapping it around a cylinder.
But I like the way you propose.
Thank you.
--- Ursprüngliche Nachricht ---
Von: arnholm@arnholm.org
Datum: 24.04.2021 09:30:03
An: OpenSCAD general discussion discuss@lists.openscad.org
Betreff: [OpenSCAD] Re: Cutting a Cylindrical shell
Ihr Recht auf Privatsphäre. Schützen Sie Ihre Daten und wechseln jetzt zu eclipso Mail & Cloud - https://www.eclipso.de
cylinder.
Thank you.
Actually, I meant to say use hull() rather than union() for the drill
bit pairs
This approach will work, but it will be very slow. I think the right
approach is to use a sweep to create the cutting polyhedron. As you say,
it's hard to construct a polyhedron from the ground up, which is why you
should instead use helper functions to do it. Many libraries provide a
sweep function such as dotSCAD, Parkinbot's naca sweep, and BOSL2.
Using BOSL2:
https://github.com/revarbat/BOSL2/wiki/skin.scad#functionmodule-path_sweep
$fn=90;
r=8;
thickness=1;
len=21;
curve = [for(theta=[0:4:359]) [rcos(theta), rsin(theta),
10+sin(4*theta)]];
cylinder(r=r, l=len);
down(.5)cylinder(r=r-thickness, l=len+1);
path_sweep(left(.05,square([1.1,1])), curve, closed=true, method="manual",
normal=UP);
http://forum.openscad.org/file/t2477/cutcyl.png
discuss-leave@.openscad
An alternative approach is to use BOSL2 skin() to make a polyhedron to cut
away the cylinder unneeded part. Oskar Lange's skin() possibly would work
too.
r = 10;
h = 20;
module cyl_shell(r,h) {
cylinder(r=r,h=h,center=true);
cylinder(r=r-0.1,h=h+.1,center=true);
n = 50;
a = 3;
cyl_curve = [for(i=[0:n-1]) [rcos(i360/n), rsin(i360/n),
acos(3i*360/n)] ];
cyl_curve_up = [for(p=cyl_curve) p + [0,0,100] ];
//trace_path(cyl_curve, size=.5, closed=true);
cyl_shell(r,h);
skin(1.01*[cyl_curve, cyl_curve_up],slices=1);
Em sáb., 24 de abr. de 2021 às 13:23, adrianv avm4@cornell.edu escreveu:
Using BOSL2:
