Is it possible to combine the examples below
I don't see exactly how you intend to combine Jordan's and mine examples
for two reasons.
the examples aim to build different kinds of models; Jordan's model is a
linear extrusion upward of a shell of your wall shape so requiring one
input data: the shape; mine is a sweep of the wall shape along a generic
path requiring two set of data: a shape and a path; (*)
Jordan's model is produced by operating (by hull() and linear_extrude()
) on primitive objects (circles); the principles of my example are very
different because essentially only one operator is applied (BOSL2 sweep() )
to two lists of points (section and path); at the very end, sweep() calls
an OpenSCAD operator: polyhedron().
Those approaches might be compared to defining a polygon either by
operating (with union(), difference(), etc) on circles and squares or by
passing a list of points to the primitive polygon().
But is it possible to put together several formulas? (in some way)
- A formula from the first corner (90 degrees) to the second corner
- The second corner (a circle sector of 90 gtrader) should not be
difficult.
- A line to the third corner.
- 3rd corner (circle sector <90 degrees)
- Where should the next straight line begin
etc.
As Jordan showed there are many ways to define a shape by a list of its
vertices. I used the concept of BOSL2 region in order to define the wall by
a code similar to your original wall() module but it could have used any
list of points defined by list comprehension.
Other alternatives are possible like unioning and/or differencing models
produced by sweeps.
(*) it is possible to argue that linear_extrude is a specific kind of sweep
operating on polygons where the path is a vertical segment.
Em qui., 24 de mar. de 2022 às 23:57, Jan Öhman via Discuss <
discuss@lists.openscad.org> escreveu:
for two reasons.
1) the examples aim to build different kinds of models; Jordan's model is a
2) Jordan's model is produced by operating (by hull() and linear_extrude()
> 1) A formula from the first corner (90 degrees) to the second corner
> 2) The second corner (a circle sector of 90 gtrader) should not be
> difficult.
> 3) A line to the third corner.
> 4) 3rd corner (circle sector <90 degrees)
> 5) Where should the next straight line begin
> etc.
produced by sweeps.
