VB
Verachten Bruno
Thu, Nov 26, 2020 3:17 PM
Hello,
It has been a while since I touched OpenScad. I'm starting from
scratch once again, I forgot everything.
I'm trying to "design" simple brackets and drill templates for PCBs.
Following https://hackaday.com/2018/02/13/openscad-tieing-it-together-with-hull/
precepts, I define my points, make cylinders, holes and then hull to
stitch everything together.
The problem I'm facing right now is that I get my trigo wrong. I don't
think it's OpenScad, it's maybe a bad understanding of what I'm
supposed to do with the atan function.
I have four holes, forming a rectangle. I have then four feets. I'm
trying to join 2 feet by a diagonal cylinder. So I'm dividing the
opposite side by the adjacent side, and applying atan() on the result,
to hopefully find the angle I'm supposed to use in rotate().
Unfortunately, that does not fit correctly, I'm a few degrees wrong.
I know it's stupid and I'm rusted with OpenScad and trigonometry, but
if anyone could point me in the right direction, that could help.
Thanks in advance,
feet = [[0,0,0], [42.11,0,0], [0,40.11,0], [42.11,40.11,0]];
holeSize = 3;
baseSize = 9;
footSize = 5;
baseHeight = 3;
totalHeight = 7;
linkThickness = 3;
linkHeight = 2;
feet(feet,holeSize, baseSize, baseHeight, totalHeight);
link(feet, linkThickness, linkHeight);
module foot(point, holeSize, baseSize, baseHeight, totalHeight) {
hull() {
cylinder(r=baseSize/2, h=baseHeight, $fn=100);
translate([0,0,(totalHeight - baseHeight)/2])
cylinder(r=footSize/2, h=baseHeight, $fn=100);
translate([0,0,totalHeight - baseHeight])
color("red") translate([0,0,-0.5]) cylinder(r=holeSize/2,
h=totalHeight+1, $fn=100);
module feet(points,holeSize, baseSize, baseHeight, totalHeight) {
for (point = points) {
translate (point) foot(point, holeSize, baseSize, baseHeight,
totalHeight);
module link(points, thickness, height) {
firstSide = points[1][0] - points[0][0];
secondSide = points[3][1] - points[0][0];
length = sqrt(pow(firstSide,2) + pow(secondSide,2));
tan = secondSide/firstSide;
atan = atan(secondSide/firstSide);
echo ("tan is", tan, " and atan is ", atan);
//360-atan(tan)
color("blue") translate([0,0,height*2]) rotate([270,0,-atan])
cylinder(h=length, r=thickness/2, center=false, $fn=100);
Bruno Verachten
Hello,
Thanks in advance,
holeSize = 3;
baseSize = 9;
footSize = 5;
baseHeight = 3;
totalHeight = 7;
linkThickness = 3;
linkHeight = 2;
hull() {
totalHeight);
//360-atan(tan)
Bruno Verachten
Thu, Nov 26, 2020 3:34 PM
Your problem with the trigonometry is you have the argument to atan inverted.
It should be atan(firstSide/secondSide).
Another consideration if you prefer not to work hard doing trigonometry is
to use a library such as BOSL2 where you could do
include<BOSL2/std.scad>
module link(points,thickness,height)
up(height*2) stroke([points[0],points[3]],
width=thickness,endcaps="butt",$fn=100);
to get the same result without trig. Many folks seem to delight in working
out the trigonometry for their models, but even though I know trigonometry
well, I feel it is easier and better to have the computer do it for me.
gounthar wrote
Hello,
Following
Thanks in advance,
holeSize = 3;
baseSize = 9;
footSize = 5;
baseHeight = 3;
totalHeight = 7;
linkThickness = 3;
linkHeight = 2;
hull() {
totalHeight);
//360-atan(tan)
Bruno Verachten
gounthar wrote
> Hello,
> Following
> Thanks in advance,
> holeSize = 3;
> baseSize = 9;
> footSize = 5;
> baseHeight = 3;
> totalHeight = 7;
> linkThickness = 3;
> linkHeight = 2;
> difference() {
> union() {
> hull() {
> totalHeight);
> //360-atan(tan)
> Bruno Verachten
> Discuss@.openscad
rickan
Thu, Nov 26, 2020 3:55 PM
Another method not involving atan (or a library) (I think quaternions are
easier):
holeSize = 3;
baseSize = 9;
footSize = 5;
baseHeight = 3;
totalHeight = 7;
linkThickness = 3;
linkHeight = 2;
hull() {
totalHeight);
//360-atan(tan)
color("blue")
rotate(-90, [secondSide/length, -firstSide/length, 0])
easier):
holeSize = 3;
baseSize = 9;
footSize = 5;
baseHeight = 3;
totalHeight = 7;
linkThickness = 3;
linkHeight = 2;
hull() {
totalHeight);
//360-atan(tan)
color("blue")
arnholm@arnholm.org
There is no need to use trigonometric functions for something like this.
Try this to replace your link
pdx = points[3][0] - points[0][0];
pdy = points[3][1] - points[0][1];
length = sqrt(pow(pdx,2) + pow(pdy,2));
dx = pdx/length;
dy = pdy/length;
color("blue")
multmatrix([[dx,-dy,0,0],[dy,dx,0,0],[0,0,1,0],[0,0,0,1]])
rotate([0,90,0])
You already have the direction cosines, so you just need to apply them.
dx = pdx/length;
dy = pdy/length;
color("blue")
rotate([0,90,0])
VB
Verachten Bruno
Thu, Nov 26, 2020 4:36 PM
That was quick!
Thanks a lot for pointing out my obvious (but not to me at the time of
coding) mistake and for the links and other ways of doing this.
I now have a working bracket design.
I'm a happy camper.
See you soon for another stupid question. ;-)
easier):
holeSize = 3;
baseSize = 9;
footSize = 5;
baseHeight = 3;
totalHeight = 7;
linkThickness = 3;
linkHeight = 2;
hull() {
totalHeight);
//360-atan(tan)
color("blue")
That was quick!
I'm a happy camper.
> easier):
> holeSize = 3;
> baseSize = 9;
> footSize = 5;
> baseHeight = 3;
> totalHeight = 7;
> linkThickness = 3;
> linkHeight = 2;
> difference() {
> union() {
> hull() {
> totalHeight);
> //360-atan(tan)
> color("blue")
Bruno Verachten
arnholm@arnholm.org
Thu, Nov 26, 2020 4:39 PM
this. Try this to replace your link
dx = pdx/length;
dy = pdy/length;
color("blue")
rotate([0,90,0])
Obviously, you could optimize it and avoid separate rotation &
translation:
dx = pdx/length;
dy = pdy/length;
color("blue")
multmatrix([[0,-dy,dx,0],[0,dx,dy,0],[-1,0,0,height*2],[0,0,0,1]])
Carsten Arholm
> dx = pdx/length;
> dy = pdy/length;
> color("blue")
> rotate([0,90,0])
translation:
dx = pdx/length;
dy = pdy/length;
color("blue")
Carsten Arholm
