Aborting normalization.
Fri, Feb 7, 2020 7:43 PM
After getting this console message I could not compile anything else:
Geometries in cache: 2
Geometry cache size in bytes: 323728
CGAL Polyhedrons in cache: 0
CGAL cache size in bytes: 0
WARNING: Normalized tree is growing past 200000 elements. Aborting
normalization.
Execution aborted
I had to close OpenSCAD e reopen again.
After getting this console message I could not compile anything else: Compiling design (CSG Products generation)... Geometries in cache: 2 Geometry cache size in bytes: 323728 CGAL Polyhedrons in cache: 0 CGAL cache size in bytes: 0 Compiling design (CSG Products normalization)... WARNING: Normalized tree is growing past 200000 elements. Aborting normalization. Execution aborted I had to close OpenSCAD e reopen again.
Fri, Feb 7, 2020 7:50 PM
I change the turn "Turn off rendering at" to 1 million elements in
preferences.
normalization.
Execution aborted
I change the turn "Turn off rendering at" to 1 million elements in preferences. On Fri, 7 Feb 2020 at 19:43, Ronaldo Persiano <rcmpersiano@gmail.com> wrote: > After getting this console message I could not compile anything else: > > Compiling design (CSG Products generation)... > > Geometries in cache: 2 > > Geometry cache size in bytes: 323728 > > CGAL Polyhedrons in cache: 0 > > CGAL cache size in bytes: 0 > > Compiling design (CSG Products normalization)... > > WARNING: Normalized tree is growing past 200000 elements. Aborting > normalization. > > Execution aborted > > > I had to close OpenSCAD e reopen again. > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Fri, Feb 7, 2020 9:10 PM
Thank you, I will do it. However, stopping to compile after that error
seems to be a bug.
A sexta, 7/02/2020, 19:51, nop head nop.head@gmail.com escreveu:
preferences.
normalization.
Execution aborted
Thank you, I will do it. However, stopping to compile after that error seems to be a bug. A sexta, 7/02/2020, 19:51, nop head <nop.head@gmail.com> escreveu: > I change the turn "Turn off rendering at" to 1 million elements in > preferences. > > On Fri, 7 Feb 2020 at 19:43, Ronaldo Persiano <rcmpersiano@gmail.com> > wrote: > >> After getting this console message I could not compile anything else: >> >> Compiling design (CSG Products generation)... >> >> Geometries in cache: 2 >> >> Geometry cache size in bytes: 323728 >> >> CGAL Polyhedrons in cache: 0 >> >> CGAL cache size in bytes: 0 >> >> Compiling design (CSG Products normalization)... >> >> WARNING: Normalized tree is growing past 200000 elements. Aborting >> normalization. >> >> Execution aborted >> >> >> I had to close OpenSCAD e reopen again. >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Fri, Feb 7, 2020 11:16 PM
Perhaps a bug introduced when stop on first warning option was added.
seems to be a bug.
preferences.
normalization.
Execution aborted
Perhaps a bug introduced when stop on first warning option was added. On Fri, 7 Feb 2020 at 21:13, Ronaldo Persiano <rcmpersiano@gmail.com> wrote: > Thank you, I will do it. However, stopping to compile after that error > seems to be a bug. > > A sexta, 7/02/2020, 19:51, nop head <nop.head@gmail.com> escreveu: > >> I change the turn "Turn off rendering at" to 1 million elements in >> preferences. >> >> On Fri, 7 Feb 2020 at 19:43, Ronaldo Persiano <rcmpersiano@gmail.com> >> wrote: >> >>> After getting this console message I could not compile anything else: >>> >>> Compiling design (CSG Products generation)... >>> >>> Geometries in cache: 2 >>> >>> Geometry cache size in bytes: 323728 >>> >>> CGAL Polyhedrons in cache: 0 >>> >>> CGAL cache size in bytes: 0 >>> >>> Compiling design (CSG Products normalization)... >>> >>> WARNING: Normalized tree is growing past 200000 elements. Aborting >>> normalization. >>> >>> Execution aborted >>> >>> >>> I had to close OpenSCAD e reopen again. >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Troberg
Fri, Feb 14, 2020 12:24 PM
Two things I've found helping when that happen, regardless of settings:
  • Double check that you have closed every {} properly, and that you only
    have ; where they should be.
  • Add a render() on the part being drawn.
Two things I've found helping when that happen, regardless of settings: * Double check that you have closed every {} properly, and that you only have ; where they should be. * Add a render() on the part being drawn. -- Sent from: http://forum.openscad.org/
