flaring a model
CA
Mon, Dec 16, 2019 7:01 PM
On 15.12.2019 23:23, Max Bond wrote:
There's nothing you can do with multmatrix() that you can't do with a
series of other transformations (rotate(), translate(), scale(), etc).
That's not entirely true. You can skew transform with multmatrix, you
cannot do that with the other transformations. In theory you could also
do a perspective transformation (bottom row), but it is disabled in
OpenSCAD.
On 15.12.2019 23:23, Max Bond wrote: > There's nothing you can do with multmatrix() that you can't do with a > series of other transformations (rotate(), translate(), scale(), etc). That's not entirely true. You can skew transform with multmatrix, you cannot do that with the other transformations. In theory you could also do a perspective transformation (bottom row), but it is disabled in OpenSCAD. Carsten Arnholm
Mon, Dec 16, 2019 7:27 PM
In fact, with a perspective transform, Max Bond code might avoid the
expensive projection() by cutting a model slice (is this less expensive?)
and transforming it directly with multmatrix().
Em seg., 16 de dez. de 2019 às 19:03, Carsten Arnholm arnholm@arnholm.org
escreveu:
OpenSCAD.
In fact, with a perspective transform, Max Bond code might avoid the expensive projection() by cutting a model slice (is this less expensive?) and transforming it directly with multmatrix(). Em seg., 16 de dez. de 2019 às 19:03, Carsten Arnholm <arnholm@arnholm.org> escreveu: > On 15.12.2019 23:23, Max Bond wrote: > > There's nothing you can do with multmatrix() that you can't do with a > > series of other transformations (rotate(), translate(), scale(), etc). > > That's not entirely true. You can skew transform with multmatrix, you > cannot do that with the other transformations. In theory you could also > do a perspective transformation (bottom row), but it is disabled in > OpenSCAD. > > Carsten Arnholm > >
Doug Moen
Tue, Dec 17, 2019 3:54 AM
Speaking of nerdsniping:
You can perform a skew by composing rotate() with scale().
Doug.
OpenSCAD.
Speaking of nerdsniping: You can perform a skew by composing rotate() with scale(). Doug. On Mon, Dec 16, 2019, at 7:01 PM, Carsten Arnholm wrote: > On 15.12.2019 23:23, Max Bond wrote: > > There's nothing you can do with multmatrix() that you can't do with a > > series of other transformations (rotate(), translate(), scale(), etc). > > That's not entirely true. You can skew transform with multmatrix, you > cannot do that with the other transformations. In theory you could also > do a perspective transformation (bottom row), but it is disabled in > OpenSCAD. > > Carsten Arnholm > > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
