I wish it was possible to write our own warnings and errors to the console
from the scad script.
Typical usage could be:
module test(value) {
if (value < 10)
warning("Value less than 10 is a bad idea.");
if (value < 0)
error("Value less than zero are not valid");
The error() could perhaps include a stop=true parameter, which would halt
the script execution.
What do you think? Are there exiting methods in place already that I've
missed?
View this message in context: http://forum.openscad.org/Wish-error-and-warning-tp10840.html
echo(); ?
View this message in context: http://forum.openscad.org/Wish-error-and-warning-tp10840p10877.html
warning() and error() would be better than echo() as they could use the built
in coloring.
And error() could be used somewhat like a breakpoint, so that you get the
red error-dot in the editor.
My workaround so far is this;
module warning(message) {
echo(str("WARNING: " , message, ""));
View this message in context: http://forum.openscad.org/Wish-error-and-warning-tp10840p10880.html
module warn(msg) {
m = str("<html>", msg, "</html>");
echo(m);
warn("The end of the world is nigh");
module error(msg) {
echo(m);
// I can't think of a way to terminate evaluation
error("This is the end");
View this message in context: http://forum.openscad.org/Wish-error-and-warning-tp10840p10886.html
Woops that didn't work, file attached warn-error.scad
http://forum.openscad.org/file/n10887/warn-error.scad
View this message in context: http://forum.openscad.org/Wish-error-and-warning-tp10840p10887.html
