Thx, ctchin. That's neat.
Since I spent most of design in polyhedron, what I am most interested in is
how two polyhedrons join/branch.
$ Runsun Pan, PhD
$ libs:
doctest ,
faces ( git ),
offline doc ( git ),
runscad.py( 1 , 2 , git );
$ tips:
hash( 1 , 2 ),
sweep ,
var( 1 , 2 ),
lerp ,
animGif ,
precision
View this message in context: http://forum.openscad.org/Non-Linear-Transformations-tp14539p14633.html
btw, ctchin, posts in this thread, Bent rod
http://forum.openscad.org/Bent-rod-tp14003p14004.html , might give some
ideas. Among them, my version:
http://forum.openscad.org/file/n14004/20150925_bent_pipe.png
$ Runsun Pan, PhD
$ libs:
doctest ,
faces ( git ),
$ tips:
hash( 1 , 2 ),
sweep ,
var( 1 , 2 ),
lerp ,
animGif ,
precision
View this message in context: http://forum.openscad.org/Non-Linear-Transformations-tp14539p14634.html
ctchin wrote
Branching also becomes obvious.
Parkinbot wrote
If I was a pipe I'd prefer to be modelled like this (works for any angle
I was playing with these two approaches and tried to make a generalized tree
branching with fillets between.
Its working well for direct code but I wanted to use a list and a for loop.
Alas the for loop does an implied union() and so the children() is not
working.
My brain has frozen on how to get around it.
E.g. I have this: (images in forum)
use <fillet.scad>
// from clothbot
// - https://github.com/clothbot/ClothBotCreations/tree/master/utilities
d0 = 10;
h1 = 30;
h2 = 20;
angle = -66;
// Parkinbot approach (filleted)
translate([30,20,0])
fillet(r=2,steps=2) {
rotate([angle,0,0])
cylinder(h1, d=d0);
cylinder(h2, d=d0);
// join
color("red")
sphere(d0/2);
// ctchin approach (filleted)
translate([30,-20,0])
fillet(r=2,steps=4) {
rotate([angle,0,0]) cylinder(h1, d=d0);
cylinder(h2, d=d0);
// join
color("red")
rotate([angle,0,0])
translate([0,0,-2d0])
cylinder(d=d0,h=2d0);
// Each branch is a cylinder with [diameter, startpt, anglexyz, length]
// - startpt, anglexyz are triplets
// generalize later to use shape profile instead of circle (cylinder)
// (one day alllow random variation in deformation along length of the
branch object)
branches = [
[10, [0,0,0], [0,0,0], 40],
[10, [0,0,0], [45,0,0], 40],
[5, [0,0,30], [66,-22,0], 33],
[5, [0,0,25], [66,-22,250], 33],
module make_tree(branches=branches, blend=4, method="round") {
// add round/sharp in here
// how to get around implied union of for() ?
for (b=branches) {
dia = b[0];
start = b[1];
angle = b[2];
dist = b[3];
translate(start)
rotate(angle)
cylinder(h=dist, d=dia);
make_tree();
To get a result like this:
http://forum.openscad.org/file/n14635/branches_5.png
How do I pass all the results of the for loop to fillet() as children ?
View this message in context: http://forum.openscad.org/Non-Linear-Transformations-tp14539p14635.html
Usually, an (implicit) union joins overlapping or matching (there is always a
numerical error!) objects. This happens also with polyhedrons. If you
calculate your own polyhedrons (your example doesn't look so) just provide
some very small overlapping.
BUT, when I try to implement your example along the "broadway", say, like
this:
I'm getting this:
http://forum.openscad.org/file/n14636/weird.png
I remember that the convexity parameter of linear_extrude() never worked
properly with me, so in the end to get more out of it I implemented a
fullblown library to bypass it on the basis of hull(). Just have a look at:
http://www.thingiverse.com/thing:648813
Bent rod http://forum.openscad.org/Bent-rod-tp14003p14004.html
, might give some ideas. Among them, my version:
View this message in context: http://forum.openscad.org/Non-Linear-Transformations-tp14539p14636.html
@Neon: If something is against you, better try to befriend it.
OK, I know, this is more a work around than the solution you are seeking,
but I'm afraid you won't get rid of the implicit union.
http://forum.openscad.org/file/n14637/tree.png
View this message in context: http://forum.openscad.org/Non-Linear-Transformations-tp14539p14637.html
ok that's pretty nice.
I guess the disadvantage is the exponential work done as each fillet is
applied to the growing object and one new part.
Maybe in OpenSCAD2 .
Thanks...
View this message in context: http://forum.openscad.org/Non-Linear-Transformations-tp14539p14638.html
Parkinbot wrote
Doh of course you are right! My brain was stuck from a previous design for
which the sphere wouldn't work, but for cylinders of course a spherical
elbow is easier and prettier.
THANKS!
(anyway the model with the ugly angular joints already went and come back
from the printer)
http://forum.openscad.org/file/n14639/bifurcation-printed.jpg
View this message in context: http://forum.openscad.org/Non-Linear-Transformations-tp14539p14639.html
You are right. A better solution would be the following approach. I didn't
present it, as I forgot how to express a partial array (Was it ever possible
in OpenSCAD to express a partial array like branches[2:4] ) Overcoming this
obstacle with the tail function, this is your proper and fast solution
ver2.0:
(By the way: a nice approach .)
View this message in context: http://forum.openscad.org/Non-Linear-Transformations-tp14539p14644.html
Yes I used this pattern
for (i=[1:len(branches)]) {
b = branches[i];
ver2.0:
parkinbot: Was it ever possible in OpenSCAD to express a partial array like
branches[2:4]?
Currently you must write
[for(i=[2:4])branches[i]]
Many people have asked for a more direct 'slice' operator, but we don't
have one yet. Multiple syntaxes have been proposed.
possible
ver2.0:
