On 12/28/2020 7:32 AM, adrianv wrote:
JordanBrown wrote
I'm concerned about somebody who naïvely goes and tweaks their
standard library because they can, then six months later, having
forgotten that tweak, runs into trouble and asks for help. They give
their entire source file, with no include/use statements (or with
"use <stdlib.scad> ", depending on how the standard library works),
and everybody is mystified. And yeah... it's not exactly "libraries
are a support disaster". It's "sources are a support disaster".
And maybe that's just part of the cost of doing business in the FOSS
world, so to speak.
This just seems like a really bizarre concern to me. Have you had this
problem in some other context?
Yes and no. Perhaps I'm just being paranoid.
In a work context (Oracle's Solaris Operating System), customers do the
strangest things, and then call for support.
I've personally hacked FOSS when it didn't work right (Western Digital
bookshelf server did NTP wrong).
I've overridden OpenSCAD builtins when they didn't work, and then
forgotten that I'd done so. (I don't remember the details, but rotate
was doing something very slightly wrong on 90 degree angles, so I
replaced it with a version that was correct.)
---Changing gears to a minimalist OpenSCAD ---
First, to be clear, it was a thought experiment, not a proposal. What
would the advantages and disadvantages be of aggressively pushing
non-performance-critical stuff out into userspace, as part of the
standard environment that you get without any use/include?
Advantage: Many more people could contribute to the "standard"
language. Bugs would be less likely, and less likely to be fatal.
Disadvantage: Many more people could contribute to the "standard"
language :-). There would be more push for including everybody's pet
feature. There would be more 70% solutions that sort of work being
pushed for inclusion. There would be the possibility of the "forgotten
tweak" that I discussed above.
Since we have to implement sweep operations (which are much harder
than linear extrude) in user space, really, why not linear_extrude?
Sweep sure seems like a candidate for moving into C++.
One thing that this proposal opens the door to is more people trying to
submit changes to the core. Unlike the bizarre hack concern above, I think
if it was easy to extend the core then people would be proposing all sorts
of changes. I think it makes more sense to keep things as they are and
allow libraries to extend the core (as is already basically possible). That
is, the various extensions you're talking about can be provided by
libraries, not in the core.
Yes, though, again as a thought experiment... does this mean that we
don't add O(1) features to the default environment? Or that they must
be added as C++?
If we had the ability to override a C++ module from userspace, while
still being able to invoke it when needed, and we decided that we wanted
the "control whether the polygon approximation of a circle is inside or
outside the theoretical circle" feature discussed in another thread,
what would we do? Would we say "nope, must go in a library that you
explicitly use/include"? Would we say "OK, but has to be implemented in
C++"? Or would we implement it in userspace in a library that is
automatically included?
That last sure seems like the right answer, if there's a serious
throttle on the flow of features.
And with the concerns I mentioned about supporting people when they do
their own tweaks.
