Hello everybody :)
I would like to parametrize a group.
So I have different components that I would like to assemble to an
assembly. In this assembly, I would then specify parameters that adjust
the individual parts. Is this possible with openscad and is my question
understandable?
The final code should look like for example like this
// car
car_size = 5
// tires
tires_size = 21
import ("car.stl");
import ("tires.stl");
and in this assembly i want that the adjustment is set
thanks for your help in forward
Hi Wonka,
accepted by the mailing list yet", so nobody gets it unless they look.
You need to subscribe to the mailing list
Re your question.
For .stl files you can use scale() resize() difference() etc. on the whole
.stl model, but not on subsets.
However if instead of import, you used modules which created the car & tire
geometry (like using cube() cylinder() etc and the rest), the parameters can
easily be used to create custom models.
View this message in context: http://forum.openscad.org/Parametrize-an-assembly-tp19364p19414.html
Wonka23 wrote
> Hello everybody :)
> understandable?
> // car
> car_size = 5
> // tires
> tires_size = 21
> import ("car.stl");
Hi Wonka,
<http://forum.openscad.org/mailing_list/MailingListOptions.jtp?forum=1> ,
Re your question.
