I dimly remember this being asked before but I've not been able to find the
answer.
Is there a clever/less cumbersome way to optionally apply the debug prefix
"#"? Similar to the following?
module myObject( debug=false ) {
xyz = [ 10, 20, 30 ];
if (debug) {
#cube( xyz );
else {
cube( xyz );
Thanks! Len
You could limit the cumbersome bit to a module such as:
module debug() {
if($debug)
#children();
else
and then just use debug() instead of # when you want it easily
enabled/disabled by setting $debug.
On Fri, Jun 13, 2025 at 8:46 PM Leonard Martin Struttmann via Discuss <
the answer.
if (debug) {
#cube( xyz );
else {
cube( xyz );
Thanks! Len
In BOSL2 you can do
highlight(debug) children();
On Fri, Jun 13, 2025 at 11:46 PM Todd Allen via Discuss <
module debug() {
if($debug)
#children();
else
the answer.
prefix "#"? Similar to the following?
if (debug) {
#cube( xyz );
else {
cube( xyz );
Thanks! Len
