Mon, Feb 12, 2024 5:18 PM
consider the case below:
list=[[7,8,9],[1,2,3],[10,11,12],[4,5,6],[7,8,9],[10,11,12]]
for simplicity, I have removed the decimal points here, but if you want to
remove duplicates in this case it would be difficult to compare in case the
list within the list are not properly rounded.
remove_extra_points(list) => [[7, 8, 9], [1, 2, 3], [10, 11, 12], [4, 5,
6]]
On Mon, 12 Feb 2024 at 22:24, Sanjeev Prabhakar sprabhakar2006@gmail.com
If you can round the arrays to a certain number all at once, comparing
them would be much neater and easier for many people.
subtract and compare is probably better for speed right now, till you have
such a rounding solution not available inside openscad
On Mon, 12 Feb 2024 at 22:02, Father Horton fatherhorton@gmail.com
Why would this be better than the more usual (and faster)
subtract-and-compare method?
On Mon, Feb 12, 2024 at 10:27 AM Sanjeev Prabhakar <
You have a point here, I did not think about this in enough depth.
but maybe you can achieve the same result by writing a better logic for
rounding.
e.g. iteratively rounding a number from 1 less than the decimal point of
a number till you reach the decimal point you want.
in the example 1.12344999999, if it is first rounded to 10 decimal it
will be 1.12345 and another step will make it 1.1234
similarly 1.12345000001 if it is rounded to 10 decimal it will be
1.12345 and so on.
Now writing such logic in openscad may need some good skills, but I
think this should be the right logic.
On Mon, 12 Feb 2024 at 12:52, Jordan Brown <
On 2/10/2024 4:05 PM, Sanjeev Prabhakar via Discuss wrote:
Maybe round a number to 4 or 5 decimal places and then comparison
should work.
E.g.
round(2.0000001,4)==2 , should give "True" as result.
No, it won't.
If you're looking to compare to four decimal places, you would want
1.12344999999
and
1.12345000001
to compare equal, because they only differ by 0.00000000002, but the
first will round to 0.1234 and the second will round to 0.1235.
The "compare the absolute value of the difference" answer seems
correct, except that to be general, if you're looking at floating point,
you want to compare to some number of significant figures, not some number
of decimal places. If you want to compare to six significant figures, and
you're comparing numbers that are around 1, then you need to confirm that
their difference is less than 0.000001. If you're comparing numbers that
are around a million, then you need to confirm that their difference is
less than 1. You can do that by comparing the absolute value of the
difference to a fraction of one of the two numbers.
But that breaks down when the value you are comparing against is zero,
because there are no significant figures.
It is also problematic - not wrong, but you could easily make errors -
if the values that you are comparing are themselves the results of
subtracting large nearly-equal numbers. Discussing single-precision
floating point for easy numbers, if you subtract two numbers that are
around a million and get a result of around 1, that result only has about
two significant figures. Each of your two millions is plus or minus about
0.1, and (simplistically) those error bars add, so your result of around 1
is plus or minus 0.2; you should consider everything from 0.8 to 1.2 to be
the same as 1. (I might be off by an order of magnitude there, but
hopefully the idea comes across.)
6]]
On Mon, 12 Feb 2024 at 22:24, Sanjeev Prabhakar <sprabhakar2006@gmail.com>
> On Mon, 12 Feb 2024 at 22:02, Father Horton <fatherhorton@gmail.com>
>>> rounding.
>>> 1.12345 and so on.
>>>> should work.
>>>> E.g.
>>>> No, it won't.
>>>> 1.12344999999
>>>> and
>>>> 1.12345000001
>>>> because there *are* no significant figures.
On 2/12/2024 1:11 AM, nop head via Discuss wrote:
My Casio calculator from the 1970's seems to round numbers perfectly.
So you can divide 1 by three and multiply by 3 to get one. I presume
it just calculates an extra digit and rounds. I wish OpenSCAD did the
same.
The operative words there are "seems to".
OpenSCAD (at least on Windows) handles that case perfectly too.
echo(1/3*3);
echo(1 - 1/3*3);
echo(1/3*3 == 1);
yields
ECHO: 1
ECHO: 0
ECHO: true
The smallest integer where OpenSCAD doesn't get that right is 49.
I'm pretty sure that the "store an extra digit and round" scheme will
fail in some case, but I'm not enough of a mathematician and not
enough of a floating point expert to predict what that case is.
> same.
echo(1/3*3);
echo(1 - 1/3*3);
echo(1/3*3 == 1);
yields
ECHO: 1
ECHO: 0
ECHO: true
fail in *some* case, but I'm not enough of a mathematician and not
Mon, Feb 12, 2024 5:34 PM
And what happens if the lists have the same elements, but in different
order?
On Mon, Feb 12, 2024 at 11:18 AM Sanjeev Prabhakar via Discuss <
6]]
have such a rounding solution not available inside openscad
rounding.
of a number till you reach the decimal point you want.
1.12345 and so on.
should work.
E.g.
No, it won't.
1.12344999999
and
1.12345000001
order?
> 6]]
>>>> rounding.
>>>> 1.12345 and so on.
>>>>> should work.
>>>>> E.g.
>>>>> No, it won't.
>>>>> 1.12344999999
>>>>> and
>>>>> 1.12345000001
>>>>> _______________________________________________
Mon, Feb 12, 2024 6:08 PM
want to remove duplicates in this case it would be difficult to
compare in case the list within the list are not properly rounded.
5, 6]]
I don't think anybody doubts that there are cases where you want to do
comparisons, and where arithmetic error is an issue for precise equality.
The questions are whether there's anything to improve in the arithmetic
so that precise equality does work, and what the math and syntax
should be for an "almost exactly equal to" comparison.
> 5, 6]]
so that precise equality *does* work, and what the math and syntax
Michael Möller
I learned that comparing Floats (or Reals) for equality is something you
DO NOT DO back in my FORTRAN IV days. Haven't done it since.
Despite Jordan Brown's long but excellent explanation why not, it will
still be on the wishlist for many people that the damn computer should be
able to second guess what they mean, and not what it has calculated. <sigh>
Especially in a language where there is no explicit distinction between int
and real .. you do not know what goes on under the hood. Is "42" stored as
an int or as 42.0? Don't get me started on autoconversion from strings to
numbers.
echo(43==43.0?"Yes":"No"); // Yes (somewhere a conversion is made from a
definite 43, to a float approximation of 4.3x10^-1 to be able to do the
comparison)
FT1=43+1E-6;echo(FT1); // Echos the same "43"
echo(43.0==FT1?"Yes":"No"); // "No", even though they seem the same.
You might have made a calculation that you think resulted in 43.0, your
echo proves it, but alas ..
On Mon, 12 Feb 2024 at 18:18, Jordan Brown via Discuss <
My Casio calculator from the 1970's seems to round numbers perfectly. So
you can divide 1 by three and multiply by 3 to get one. I presume it
just calculates an extra digit and rounds. I wish OpenSCAD did the same.
echo(1/33);
echo(1 - 1/33);
echo(1/3*3 == 1);
yields
ECHO: 1
ECHO: 0
ECHO: true
I'm pretty sure that the "store an extra digit and round" scheme will fail
in some case, but I'm not enough of a mathematician and not enough of a
numbers.
comparison)
> echo(1/3*3);
> echo(1 - 1/3*3);
> echo(1/3*3 == 1);
> yields
> ECHO: 1
> ECHO: 0
> ECHO: true
> in *some* case, but I'm not enough of a mathematician and not enough of a
Mon, Feb 12, 2024 6:11 PM
1.12345 and so on.
So if you're rounding 1.49 to zero decimal places, you should first
round it to 1.5 and then to 2?
Rounding, at least straightforward rounding, has all the same issues
that ordinary comparison does - they're just centered around the values
that are halfway between your "final" values. Which should be no
surprise when you realize that rounding is just adding 0.5 and truncating.
> 1.12345 and so on.
Mon, Feb 12, 2024 6:13 PM
On 2/12/2024 1:44 AM, Dan Perry via Discuss wrote:
Integer math is a feature not a bug. The easiest way to check odd vs
even is: num % 2 == 0.
Sure. Integer arithmetic is great when you need integer arithmetic.
But it doesn't magically solve the problems that people have with
floating point arithmetic.
Mon, Feb 12, 2024 6:24 PM
you DO NOT DO back in my FORTRAN IV days. Haven't done it since.
Is "42" stored as an int or as 42.0?
from a definite 43, to a float approximation of 4.3x10^-1 to be able
to do the comparison)
No. They are exactly the same value, and they are both absolutely
precise. The problem arises only with non-integers. Integers in the
range -10^15 through 10^15, approximately, are represented precisely.
Larger integers start getting fuzz in their lower digits.
It's exactly like in grade-school arithmetic. You can add, subtract,
and multiply integer values all you want, and everything will be fine.
It's division (and square root and trig and ...) that can introduce
those obnoxious infinite-length values that can't be represented precisely.
Correct. There are two places in there that introduce errors:
- First, and most obvious, is that echo() rounds to six or so places,
and so the 1e-6 is dropped.
- Second, the 1e-6, being derived from a negative power of 5, is an
infinite repeating fraction and cannot be represented precisely.
your echo proves it, but alas ..
Yes. If you really care, you should subtract the echoed result from the
calculated result and look at the difference. (No, there's no way to do
that inside OpenSCAD.)
Yep.
Yes. Both. Sort of.
* First, and most obvious, is that echo() rounds to six or so places,
* Second, the 1e-6, being derived from a negative power of 5, is an
