NS
Nathan Sokalski
Sat, Feb 10, 2024 3:15 AM
When using the Boolean operators (== & !=) to compare arrays, will OpenSCad return true or false? For example, if I have the following code:
testarray1=[0,0];
testarray2=[0,0];
echo((testarray1==testarray2)?"Arrays have the same value":"The arrays are not the same");
Which one will be the result? I can, of course, compare the values individually, but it is obviously more convenient to do it as a single operation.
Nathan Sokalski
testarray1=[0,0];
testarray2=[0,0];
Nathan Sokalski
njsokalski@hotmail.com<mailto:njsokalski@hotmail.com>
SL
Steve Lelievre
Sat, Feb 10, 2024 4:08 AM
According to the manual, "If both operands are vectors, an equality test
returns /true/ when the vectors are identical and /false/ otherwise."
Steve
testarray1=[0,0];
testarray2=[0,0];
are not the same");
operation.
Nathan Sokalski
Steve
> testarray1=[0,0];
> testarray2=[0,0];
> are not the same");
> operation.
> Nathan Sokalski
DP
David Phillip Oster
Sat, Feb 10, 2024 7:43 AM
returns true when the vectors are identical and false otherwise."
with all the usual caveats about floating point numbers are only an
approximation of mathematical real numbers, generally you want to test that
the absolute value of the difference is smaller than some small value,
rather than use '=='.
On Fri, Feb 9, 2024 at 8:09 PM Steve Lelievre via Discuss <
returns *true* when the vectors are identical and *false* otherwise."
Sat, Feb 10, 2024 1:28 PM
I actually ran your code, and it works as you might expect. I am
puzzled as to why you posted this question when it was so easy to get
the answer for yourself. Easier, in fact, than posting the question.
testarray1=[0,0];
testarray2=[0,0];
are not the same");
operation.
Nathan Sokalski
> testarray1=[0,0];
> testarray2=[0,0];
> are not the same");
> operation.
> Nathan Sokalski
Sat, Feb 10, 2024 7:19 PM
that the absolute value of the difference is smaller than some small
value, rather than use '=='.
Makes me wonder whether either (a) == should allow for some fuzz, or (b)
we should introduce ~= that would allow some fuzz.
To be precise, you want to test for whether the difference is smaller
than some small fraction of the values involved.
DP
Dan Perry
Sat, Feb 10, 2024 7:32 PM
Back in my working days, probably in Cadence Design Systems SKILL language,
I used 'ne' --> nearly equal.
Dan
On Sat, Feb 10, 2024 at 7:19 PM Jordan Brown via Discuss <
To be precise, you want to test for whether the difference is smaller than
Dan
FH
Father Horton
Sat, Feb 10, 2024 7:50 PM
Altering the definition of == could be breaking, though I would be a bit
surprised. But I'd rather see the fuzzy comparison made explicit.
function fuzeq(a, b, epsilon = 0.001) = abs(a - b) < epsilon;
echo(fuzeq(1, 1.1));
echo(fuzeq(1, 1.00001));
echo(fuzeq(1, 1.00001, epsilon = 0.0000001));
ECHO: false
ECHO: true
ECHO: false
ECHO: false
ECHO: true
ECHO: false
Sun, Feb 11, 2024 12:05 AM
Maybe round a number to 4 or 5 decimal places and then comparison should
work.
E.g.
round(2.0000001,4)==2 , should give "True" as result.
Function "round" needs to be written in this case
For most of the practical cases rounding a number up to 5 decimal places
should be fine
On Sun, 11 Feb, 2024, 1:20 am Father Horton via Discuss, <
ECHO: false
ECHO: true
ECHO: false
work.
E.g.
should be fine
> ECHO: false
> ECHO: true
> ECHO: false
Sun, Feb 11, 2024 12:25 PM
you have to include a value for the fuzziness, so not difficult to add
that, as you've shown. It's OK for numbers, but how about for shapes?
Personally, I have not looked at in detail, but I think for practical
purposes, we could not bother with floating point. 64 bit integer can
cover a range big enough for most, imnsho.
bit surprised. But I'd rather see the fuzzy comparison made explicit.
ECHO: false
ECHO: true
ECHO: false
> ECHO: false
> ECHO: true
> ECHO: false
Michael Möller
Sun, Feb 11, 2024 2:54 PM
Ohhh, I am curious, too, but refrained from asking. I wondered, was the
question badly phrased, as in: what is the result for undef, unequal sizes,
unequal nesting ? Maybe the test was done, but the answer was "wrong".
A few years working in IT support led me to reduce a problem description
"interview" to:
- what did you do (code)?
- what did you expect?
- what did happen?
Michael
lør. 10. feb. 2024 14.29 skrev jon via Discuss discuss@lists.openscad.org:
I actually ran your code, and it works as you might expect. I am puzzled
as to why you posted this question when it was so easy to get the answer
testarray1=[0,0];
testarray2=[0,0];
not the same");
operation.
Nathan Sokalski
Virus-free.www.avg.com
<#m_7177096355311457880_m_6914178584790883541_m_-8430813806441156325_m_7393337301490708340_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
"interview" to:
1) what did you do (code)?
2) what did you expect?
3) what did happen?
Michael
lør. 10. feb. 2024 14.29 skrev jon via Discuss <discuss@lists.openscad.org>:
> testarray1=[0,0];
> testarray2=[0,0];
> not the same");
> operation.
> Nathan Sokalski
> <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient>
