Mon, Sep 24, 2018 6:29 PM
Actually QCoreApplication::applicationDirPath() is static so I don't need
an instance.
On 24 September 2018 at 19:27, nop head nop.head@gmail.com wrote:
The way it currently works is if it runs the GUI then it gets the
application path from the OpenSCADApp instance. If it runs the command line
version it instantiates a QCoreApplication app and uses that. Only if it is
compiled without QT does it use the boost version.
To get the color schemes in the command line description it needs the app
path before it has processed the command line. I bodged it by always
creating a QCoreApplicationapp on the heap, using it to get the app path
and then deleting it. That seems to fix the problem and still uses QT if
compiled with QT.
#ifdef OPENSCAD_QTGUI
QCoreApplication *app = new QCoreApplication(argc, argv);
const std::string application_path = QCoreApplication::instance()->
applicationDirPath().toLocal8Bit().constData();
delete app;
#else
const std::string application_path = fs::absolute(boost::
filesystem::path(argv[0]).parent_path()).generic_string();
#endif
PlatformUtils::registerApplicationPath(application_path);
Can anybody see a problem with this hack?
On 24 September 2018 at 18:28, Torsten Paul Torsten.Paul@gmx.de wrote:
On 09/24/2018 04:03 PM, nop head wrote:
Having two QT app instances seems to be a problem, no surprise there!
Is there a reason for preferring the QT version? The boost version
produces the same path on my system so using that solves the problem.
The current code might be just for legacy reasons, but there are various
issues with boost on Windows regarding hard-links and non-ascii path.
I don't know if the toLocal8Bit() from Qt is better, but it might actually
help in those cases. Otherwise it would be nicer to just have a single
way to determine the path.
The command line help change looks very nice. I think that using the
generated version is much better as this pretty much removes the risk
of information missing in the output in case of future changes to the
options.
an instance.
> compiled with QT.
> delete app;
> #else
> #endif
>> options.
>> ciao,
>> Torsten.
>> OpenSCAD mailing list
>> Discuss@lists.openscad.org
>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Mon, Sep 24, 2018 6:33 PM
QCoreApplication::applicationDirPath().toLocal8Bit().constData();
#else
fs::absolute(boost::filesystem::path(argv[0]).parent_path()).generic_string();
#endif
Much nicer!
an instance.
compiled with QT.
delete app;
#else
const std::string application_path = fs::absolute(boost::filesystem
#endif
actually
options.
#else
#endif
Much nicer!
> an instance.
>> compiled with QT.
>> delete app;
>> #else
>> #endif
>>> actually
>>> options.
>>> ciao,
>>> Torsten.
Mon, Sep 24, 2018 7:10 PM
A bit more re-ordering, some blank line separators and a list of
experimental features available. Anybody got any suggestions before I make
a PR.
Usage: openscad.exe [options] file.scad
Allowed options:
-o [ --o ] arg out_file -output a file instead of running the GUI,
file extension specifies the type: stl, off, amf,
csg,
dxf, svg, png, echo, ast, term, nef3, nefdbg
-D [ --D ] arg var=val -pre-define variables
-p [ --p ] arg customizer parameter file
-P [ --P ] arg customizer parameter set
--enable arg enable experimental features: assert | echo |
lc-each |
lc-else | lc-for-c | amf-import | svg-import |
customizer
-h [ --help ] print this help message and exit
-v [ --version ] print the version
--camera arg camera parameters when exporting png:
translate_x,y,z,rot_x,y,z,dist or
eye_x,y,z,center_x,y,z
--autocenter adjust camera to look at object center
--viewall adjust camera to fit object
--imgsize arg =width,height for exporting png
--render arg if exporting a png image, do a full geometry
evaluation
--preview arg if exporting a png image, do an OpenCSG(default) or
ThrownTogether preview
--projection arg (o)rtho or (p)erspective when exporting png
--colorscheme arg colorscheme: *Cornfield | Metallic | Sunset |
Starnight
| BeforeDawn | Nature | DeepOcean | Solarized |
Tomorrow | Tomorrow Night | Monotone
--csglimit arg if exporting a png image, stop rendering at the
given
number of CSG elements
-d [ --d ] arg deps_file -generate a dependency file for make
-m [ --m ] arg make_cmd -runs make_cmd file if file is missing
--info print information about the build process
--debug arg special debug info
-q [ --quiet ] quiet mode (don't print anything except errors)
-s [ --s ] arg stl-file deprecated, use -o
-x [ --x ] arg dxf-file deprecated, use -o
#else
#endif
Much nicer!
need an instance.
app path before it has processed the command line. I bodged it by always
compiled with QT.
delete app;
#else
#endif
various
actually
options.
a PR.
Allowed options:
csg,
lc-each |
customizer
evaluation
Starnight
given
-q [ --quiet ] quiet mode (don't print anything *except* errors)
> #else
> #endif
> Much nicer!
>> need an instance.
>>> compiled with QT.
>>> delete app;
>>> #else
>>> #endif
>>>> various
>>>> actually
>>>> options.
>>>> ciao,
>>>> Torsten.
Mon, Sep 24, 2018 7:23 PM
This code won't work. Suppose that you git clone the OpenSCAD repository,
build it, and install it in some place like /usr/local/bin. Then, when you
type 'openscad' from a bash prompt, then argv[0] will just be the string
"openscad", with no directory component. application_path should be set to
"/usr/local/bin", but this code won't return the correct directory.
I have a function called 'progdir()' which computes the application
directory, portable between Linux and MacOS. However, I've never tested my
code on Windows. You can have the code if you want it. progdir() works by
searching the PATH environment variable, when necessary, to determine the
application path.
How important is it for OpenSCAD to work correctly if it is built without
linking to Qt?
#else
#endif
Much nicer!
need an instance.
compiled with QT.
delete app;
#else
#endif
various
actually
options.
application path.
linking to Qt?
> #else
> #endif
> Much nicer!
>> need an instance.
>>> compiled with QT.
>>> delete app;
>>> #else
>>> #endif
>>>> various
>>>> actually
>>>> options.
>>>> ciao,
>>>> Torsten.
Mon, Sep 24, 2018 7:45 PM
I think argv[0] is the full path of the executable on Windows, regardless
of what you type, but on Linux it is just what you typed. Does your code
cope with it being a full path like
C:/msys64/home/ChrisP/openscad/release/openscad.exe?
application path.
linking to Qt?
const std::string application_path = QCoreApplication::applicationD
#else
#endif
Much nicer!
need an instance.
compiled with QT.
delete app;
#else
#endif
various
actually
options.
> application path.
> linking to Qt?
>> #else
>> #endif
>> Much nicer!
>>> need an instance.
>>>> compiled with QT.
>>>> delete app;
>>>> #else
>>>> #endif
>>>>> various
>>>>> actually
>>>>> options.
>>>>> ciao,
>>>>> Torsten.
Mon, Sep 24, 2018 8:25 PM
Okay, here is my code. It's based on boost::filesystem, which OpenSCAD
already uses. It also uses my custom curv::Exception class, but you can
easily replace that part.
I think the only part of this that won't work on Windows is the part where
it splits the PATH variable at ':' characters. I think that should be a ';'
character on Windows, but I don't have a Windows dev environment to test
on. The licence can be replaced by GPL2, but keep the copyright notice.
Actually, here's another possible Windows dependency. If 'openscad.exe'
exists in the current directory, and you type 'openscad', then what
happens? If the existence of openscad.exe in the current directory
overrides the PATH search on Windows, and if argv[0] is set to "openscad"
in that case, then extra code would be required.
// Copyright 2016-2018 Doug Moen
// Licensed under the Apache License, version 2.0
// See https://www.apache.org/licenses/LICENSE-2.0
extern "C" {
#include <stdlib.h>
#include <string.h>
#include <libcurv/exception.h>
#include "progdir.h"
namespace fs = boost::filesystem;
Compute the absolute pathname of the directory
containing the program executable.
The storage for the result string is dynamically allocated.
argv0 is argv[0] of the argv passed to main().
,,, Unix specific, right now.
fs::path
progdir(const char *argv0)
fs::path cmd(argv0);
if (cmd.is_absolute())
return cmd.parent_path();
if (cmd.has_parent_path())
return fs::current_path() / cmd.parent_path();
const char* PATH = getenv("PATH");
if (PATH == NULL) {
throw curv::Exception_Base(curv::stringify(
"Can't determine directory of program ", argv0,
": PATH not defined"));
const char* p = PATH;
const char* pend = PATH + strlen(PATH);
while (p < pend) {
const char* q = strchr(p, ':');
if (q == nullptr)
q = pend;
fs::path file(p, q);
file /= argv0;
if (fs::exists(fs::status(file)))
return file.parent_path();
p = (q < pend ? q + 1 : pend);
": can't find ", argv0, " in $PATH"));
cope with it being a full path like C:/msys64/home/ChrisP/
application path.
linking to Qt?
#else
#endif
Much nicer!
need an instance.
compiled with QT.
delete app;
#else
#endif
various
actually
options.
extern "C" {
#include <stdlib.h>
#include <string.h>
* Compute the absolute pathname of the directory
* containing the program executable.
* The storage for the result string is dynamically allocated.
* argv0 is argv[0] of the argv passed to main().
* ,,, Unix specific, right now.
fs::path
if (PATH == NULL) {
while (p < pend) {
if (q == nullptr)
q = pend;
file /= argv0;
>> application path.
>> linking to Qt?
>>> #else
>>> #endif
>>> Much nicer!
>>>> need an instance.
>>>>> compiled with QT.
>>>>> delete app;
>>>>> #else
>>>>> #endif
>>>>>> various
>>>>>> actually
>>>>>> options.
>>>>>> ciao,
>>>>>> Torsten.
Mon, Sep 24, 2018 9:32 PM
Just a note on licensing, OpenSCAD code requires to be GPL2+,
including the "or (at your option) any later version" clause.
Otherwise it would not be possible to distribute OpenSCAD
anymore.
anymore.
Mon, Sep 24, 2018 9:37 PM
You can relicense this particular code with any open source licence you
wish. GPL2+ is fine, I didn't intend to exclude that.
> anymore.
> ciao,
> Torsten.
Mon, Sep 24, 2018 9:43 PM
licence you wish. GPL2+ is fine, I didn't intend to exclude
that.
Great, thanks, as (due to CGAL) the final application is GPL3+
anyway, it would work with Apache-2.0, I think. Having both
options is even better :-).
> that.
Mon, Sep 24, 2018 11:19 PM
If 'openscad.exe' exists in the current directory, and you type
'openscad', then what happens?
Win7 cmd.exe runs it. MSYS2's bash doesn't run unless you prepend ./
I wrote a win32 console program in a very old version of Visual studio and
found argv[0] is what you type, like Unix when run from CMD.EXE. However if
I run it in MSYS2's bash it is always the full path regardless. Also when
launched from the Desktop GUI then it is always the full path.
So when a program is run from CMD I think you have to look in the current
directory and then the path.
that.
>> that.
> ciao,
> Torsten.
