Thu, Sep 20, 2018 8:38 AM
I think all normal tests should catch accidental transparency now the test
framework has been updated to check it. This test is actually testing the
test system does that. It isn't testing OpenSCAD because any image that
doesn't match the 'expected' one will pass the test.
All the other tests can generate the expected image but this one can't, so
I have no easy way of making it.
On 20 September 2018 at 09:10, Rogier Wolff R.E.Wolff@bitwizard.nl wrote:
On Thu, Sep 20, 2018 at 08:38:15AM +0100, nop head wrote:
OK, Thanks. I will comment it out.
I would say that the test has its merits: It should trigger when the
transparency code accidentally makes things transparent that should
not be. The thing is... Testing if it precisely matches the
transparent image is not a good test to see if that happened.
A good test would combine say a purple image with the openscad image
"on top" obscuring all the purple when things are not
transparent.... When you still get the original openscad image, things
are ok. See some purple, things are not ok.
> Roger.
> *-- BitWizard writes Linux device drivers for any device you may have! --*
> The plan was simple, like my brother-in-law Phil. But unlike
> Phil, this plan just might work.
Fri, Sep 21, 2018 2:37 PM
I have now unified the camera modes with this PR
https://github.com/openscad/openscad/pull/2491. There is no vector mode any
more, just the option to set it up from vector parameters. It fixes the
lighting bug in vector mode, the view all without auto center bug in gimbal
mode and makes the GUI default view the same as the command line default.
I kept the camera default distance at 140 because although the default was
different for the vector camera it was never used because if you don't
specify a camera it uses viewall and autocenter. 140 is too close for me
but I think all the examples are sized for it.
The default angle is now [70, 0, 315], which is a fraction of a degree
different from the old command line default. It is different from the old
GUI default [55, 0, 25], but more logical if you design in the first
quadrant and it results in you looking towards the best lit side. IIRC it
used to be different in the distant past, or perhaps the lighting was.
Sat, Sep 22, 2018 3:52 PM
As there is now no reason to not offer axes, scales and cross-hairs I added
them to the command line and invoked them in some of the camera tests,
expecting them to fail initially. To my surprise they pass, even though the
actual images have axes but the expected don't.
Is there some tolerance to the image comparison that is big enough to not
notice a scaled axis?
any more, just the option to set it up from vector parameters. It fixes the
Sat, Sep 22, 2018 5:02 PM
Note that there is a PR open to control some of those view settings as cmd-line arguments. I’m on my phone so I’ll be short, but it shouldn’t be hard to find.
Yes, we have some erosion setting to let small rendering details slip through. It wasn’t int intended to allow such large changes pass by unnoticed though. Ideas are welcome!
On Sep 22, 2018, at 11:52, nop head nop.head@gmail.com wrote:
As there is now no reason to not offer axes, scales and cross-hairs I added them to the command line and invoked them in some of the camera tests, expecting them to fail initially. To my surprise they pass, even though the actual images have axes but the expected don't.
Is there some tolerance to the image comparison that is big enough to not notice a scaled axis?
I have now unified the camera modes with this PR https://github.com/openscad/openscad/pull/2491. There is no vector mode any more, just the option to set it up from vector parameters. It fixes the lighting bug in vector mode, the view all without auto center bug in gimbal mode and makes the GUI default view the same as the command line default.
I kept the camera default distance at 140 because although the default was different for the vector camera it was never used because if you don't specify a camera it uses viewall and autocenter. 140 is too close for me but I think all the examples are sized for it.
The default angle is now [70, 0, 315], which is a fraction of a degree different from the old command line default. It is different from the old GUI default [55, 0, 25], but more logical if you design in the first quadrant and it results in you looking towards the best lit side. IIRC it used to be different in the distant past, or perhaps the lighting was.
HL
Hans L
Sat, Sep 22, 2018 5:28 PM
The default imagemagick arguments can be seen here:
https://github.com/openscad/openscad/blob/74078c561afcbaaa98bfecc8efdac805ae74d482/tests/test_cmdline_tool.py#L156
args = [expectedfilename, resultfilename, "-alpha", "On", "-compose",
"difference", "-composite", "-threshold", "10%", "-morphology",
"Erode", "Square", "-format", "%[fx:whmean]", "info:"]
As I understand an exact pixel comparison would be too strict for it
to pass across different platforms due to small variations in the
output of different graphics cards.
There is a threshold for the difference (to allow for slight color
rendering variation between graphics cards?), plus the morphology
erode operation which I think the idea is to ignore possible variation
in aliasing on object borders across graphics cards, but also means
that thin differences like single pixel axes will get eroded away
entirely.
You can try tweaking the imagemagick arguments to maybe find a more
precise comparison method that reduces false negatives/positives
between test server and your dev machine.
Hans
"Erode", "Square", "-format", "%[fx:w*h*mean]", "info:"]
entirely.
Hans
> -Marius
Sat, Sep 22, 2018 7:00 PM
Yes it is the morphology erode that ignores the single pixel axes. If I
remove it all the tests pass except the ones where have turned on axes plus
a couple of 2D images. However I have just re-created all the expected
images 3D for my previous changes so I won't get any aliasing differences.
I can't think how we can both ignore aliasing differences and detect single
pixel axes at the same time.
My previous machine used to anti-alias the preview but this machine
doesn't. Its only option is to use application settings or turn it off,
whereas IIRC on my old machine I could force it on for a specify
application and I think it rendered at higher resolution and downsampled to
get smooth edges. Anybody know an application specifies anti-aliasing?
entirely.
Hans
hard to find.
> entirely.
> Hans
> hard to find.
> > -Marius
Sun, Sep 23, 2018 10:11 AM
entirely.
Hans
hard to find.
I added a PR for command line axes. I have manually checked it works by
removing the erode but it won't get automatically regression tested.
However, the axes code never has been, so it is no worse than the current
situation.
While looking at the command line options I noticed they are added with
descriptions here:
https://github.com/openscad/openscad/blob/master/src/openscad.cc#L822 but
the help message doesn't use that data structure. It prints them without
descriptions here:
https://github.com/openscad/openscad/blob/master/src/openscad.cc#L138, so
they have to be added twice and kept in sync. Is there a reason for this?
>> entirely.
>> Hans
>> hard to find.
>> > -Marius
Sun, Sep 23, 2018 10:44 AM
This is what it currently outputs manually:
Usage: openscad.exe [ -o output_file [ -d deps_file ] ]
[ -m make_command ] [ -D var=val [..] ]
[ --help ] print this help message and exit
[ --version ] [ --info ]
[ --camera=translatex,y,z,rotx,y,z,dist |
--camera=eyex,y,z,centerx,y,z ]
[ --autocenter ]
[ --viewall ]
[ --imgsize=width,height ] [
--projection=(o)rtho|(p)ersp]
[ --render | --preview[=throwntogether] ]
--colorscheme=[Cornfield|Sunset|Metallic|Starnight|BeforeDawn|Nature|DeepOcean]
[ --csglimit=num ] [ --enable=<feature> ]
[ -p <Parameter Filename>] [-P <Parameter Set>]
filename
This is what Boost::program_options generates automatically:
C:\msys64\home\ChrisP\openscad\release\openscad.exe: Allowed options:
-h [ --help ] help message
-v [ --version ] print the version
--info print information about the building process
--render arg if exporting a png image, do a full geometry
evaluation
--preview arg if exporting a png image, do an OpenCSG(default) or
ThrownTogether preview
--csglimit arg if exporting a png image, stop rendering at the
given
number of CSG elements
--camera arg parameters for camera when exporting png
--autocenter adjust camera to look at object center
--viewall adjust camera to fit object
--showaxes show axes
--showscale show scale markers on axes
--showcrosshairs show cross hairs at the center of the view
--imgsize arg =width,height for exporting png
--projection arg (o)rtho or (p)erspective when exporting png
--colorscheme arg colorscheme
--debug arg special debug info
-q [ --quiet ] quiet mode (don't print anything except errors)
-o [ --o ] arg out-file
-p [ --p ] arg parameter file
-P [ --P ] arg parameter set
-s [ --s ] arg stl-file
-x [ --x ] arg dxf-file
-d [ --d ] arg deps-file
-m [ --m ] arg makefile
-D [ --D ] arg var=val
--enable arg enable experimental features
I think by adding to a couple of the descriptions it would be better.
situation.
descriptions here: https://github.com/openscad/openscad/blob/master/src/
openscad.cc#L822 but the help message doesn't use that data structure. It
prints them without descriptions here: https://github.com/openscad/
openscad/blob/master/src/openscad.cc#L138, so they have to be added twice
entirely.
Hans
hard to find.
was.
Usage: openscad.exe [ -o output_file [ -d deps_file ] ]\
[ -m make_command ] [ -D var=val [..] ] \
[ --help ] print this help message and exit \
[ --version ] [ --info ] \
[ --camera=translatex,y,z,rotx,y,z,dist | \
--camera=eyex,y,z,centerx,y,z ] \
[ --autocenter ] \
[ --viewall ] \
--projection=(o)rtho|(p)ersp] \
[ --render | --preview[=throwntogether] ] \
[ --csglimit=num ] [ --enable=<feature> ] \
[ -p <Parameter Filename>] [-P <Parameter Set>] \
filename
evaluation
given
-q [ --quiet ] quiet mode (don't print anything *except* errors)
> situation.
>>> entirely.
>>> Hans
>>> hard to find.
>>> > -Marius
>>> was.
Sun, Sep 23, 2018 11:44 AM
Here it is tidied up a bit:
Usage: openscad.exe [options] file.scad
Allowed options:
given
--camera arg camera parameters when exporting png:
translate_x,y,z,rot_x,y,z,dist or
eye_x,y,z,center_x,y,z
--showaxes show axes in png images
evaluation
--colorscheme arg colorscheme Cornfield | Sunset | Metallic |
Starnight |
BeforeDawn | Nature | DeepOcean
-p [ --p ] arg customizer parameter file
-P [ --P ] arg customizer parameter set
-s [ --s ] arg stl-file deprecated, use -o
-x [ --x ] arg dxf-file deprecated, use -o
Auto generated with four lines of code. What do people think?
[ --autocenter ]
[ --viewall ]
[ --colorscheme=[Cornfield|Sunset|Metallic|Starnight|BeforeDawn|Nature|DeepOcean]
filename
evaluation
given
situation.
enscad/blob/master/src/openscad.cc#L822 but the help message doesn't use
that data structure. It prints them without descriptions here:
so they have to be added twice and kept in sync. Is there a reason for this?
entirely.
Hans
be hard to find.
default.
was.
Allowed options:
given
evaluation
Starnight |
> [ --autocenter ] \
> [ --viewall ] \
> filename
> evaluation
> given
>> situation.
>>>> entirely.
>>>> Hans
>>>> be hard to find.
>>>> > -Marius
>>>> default.
>>>> was.
Sun, Sep 23, 2018 12:02 PM
That sort of changes are VERY good from a software-engineering and/or
maintenance point-of-view. So. IMHO: Great work!
