Thank you, Paul!
I've just checked these variables and I think I found the path to solve
my problem (Really to make an improvement to my software)
$vpt = [ 307.88, 422.79, 929.94 ];
$vpr = [ 86.50, 0.00, 16.60 ];
$vpd = 2973.77;
My program can send keystrokes to OpenSCAD. I make this all the time. I
need to send to OpenSCAD the next keystrokes:
"Ctrl+T" to copy to clipboard $vpt value;
"Alt+E" and "Y" to copy to clipboard $vpr value.
and "Alt+E" and "W" to copy $vpd.
After each keystroke, I need to take the clipboard values inside
temporal variables in my software. When I need to restore the values I
save my .scad file that starts defining again the values.
$vpd = 2973.77;
The only worry about this technique is if there is going to have
problems with other languages for the keystrokes.
If there are problems, I can make these keystrokes configurable, I think.
I'm going to try this.
Thanks again, Paul!
On 26/07/2019 20:22, Torsten Paul wrote:
On 26.07.19 19:33, Juan C.Cilleruelo wrote:
If it's possible without close and reopen OpenSCAD.
For giving a specific viewport setting when loading a file,
you can include the $vpX variables to setup a fixed viewport
on preview/render.
The saved state is Qt internal, I don't know what the
format is and if it can/should be driven from outside.
That said, there's an (experimental) InputDriver for DBus
which allows external programs to interact with a running
OpenSCAD. But so far that is only available on Linux.
There might be a way to get DBus working on Windows, but
I have never tried.
Thank you, Paul!
$vpd = 2973.77;
$vpd = 2973.77;
Thanks again, Paul!
> on preview/render.
> I have never tried.
> ciao,
> Torsten.
