export() function.
PF
Peter Falke
Sat, Jan 16, 2016 9:43 AM
We should think about how export() will work with costomizer on thingiverse.
2016-01-16 9:20 GMT+01:00 nop head nop.head@gmail.com:
Yes F4 would still reload. Also auto reload should behave the same way in
not changing $assembly.
On 16 January 2016 at 04:53, MichaelAtOz oz.at.michael@gmail.com wrote:
I presume F4 still reloads.
Of course the variables can be overridden in the source. So you can test
effect without having to render, for example.
Newly minted Admin - PM me if you need anything, or if I've done
something stupid...
View this message in context:
http://forum.openscad.org/export-function-tp15428p15727.html
We should think about how export() will work with costomizer on thingiverse. 2016-01-16 9:20 GMT+01:00 nop head <nop.head@gmail.com>: > Yes F4 would still reload. Also auto reload should behave the same way in > not changing $assembly. > > On 16 January 2016 at 04:53, MichaelAtOz <oz.at.michael@gmail.com> wrote: > >> I presume F4 still reloads. >> Of course the variables can be overridden in the source. So you can test >> effect without having to render, for example. >> >> >> >> ----- >> Newly minted Admin - PM me if you need anything, or if I've done >> something stupid... >> >> Unless specifically shown otherwise above, my contribution is in the >> Public Domain; to the extent possible under law, I have waived all >> copyright and related or neighbouring rights to this work. Obviously >> inclusion of works of previous authors is not included in the above. >> >> The TPP is no simple “trade agreement.” Fight it! >> http://www.ourfairdeal.org/ time is running out! >> -- >> View this message in context: >> http://forum.openscad.org/export-function-tp15428p15727.html >> Sent from the OpenSCAD mailing list archive at Nabble.com. >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
Sat, Jan 16, 2016 11:31 PM
thingiverse.
In the sense that we should not break the use case of OpenSCAD
running on a server, I agree.
Other than that, I don't see how we can care much as there seems
to be no feedback coming from thingiverse.
On 01/16/2016 10:43 AM, Peter Falke wrote: > We should think about how export() will work with costomizer on > thingiverse. > In the sense that we should not break the use case of OpenSCAD running on a server, I agree. Other than that, I don't see how we can care much as there seems to be no feedback coming from thingiverse. ciao, Torsten.
