AC
Alan Cox
Sun, Jan 10, 2016 12:11 PM
Ok, let's try to create a short resume of the discussion.
- The feature itself is expected by at least some (or even most of)
people, who posted their opinions here.
I'm surprised we need an export() given that you really need render() to
force the right behaviour. render(export="xx") might be saner but that
is a minor point.
- People are interested in having options to control, when export is
performing it's action - preview or render mode.
Or neither or both. However that's nothing to do with export(). It's a
matter of having a variable saying which mode you are in. That is
immediately way more powerful and cleaner.
Even better but a separate issue might also be having a "view" variable
that two fn keys inc/dec so that you can flip between views as programmed.
- There are security and unpredicted behavior issues:
3a when exporting to arbitrary file.
3b when importing and exporting from/to the same file.
Any file can be a security issue. Even writing just files ending ".stl"
into the current directory can be used to overwrite existing stuff, while
not overwriting has its own set of usability problems.
3a. Limit export operations to current working directory. Limit characters,
allowed in filenames to some known-safe set.
There is no simple known safe set (eg "AUX" in windows) but you can get
close. Another alternative is to strip any pathname elements out and
place all the render components in a subdirectory based upon the name of
the original
ie
foo.scad
produces
components-foo/*.stl
(you'll notice this is basically what for example Firefox does saving web
pages)
Alan
On Sun, 10 Jan 2016 14:49:15 +0300
> 1. The feature itself is expected by at least some (or even most of)
is a minor point.
> 2. People are interested in having options to control, when export is
Or neither or both. However that's *nothing* to do with export(). It's a
> 3. There are security and unpredicted behavior issues:
the original
ie
foo.scad
produces
pages)
Alan
Sun, Jan 10, 2016 12:13 PM
I don't think export should ever do anything in preview or render except
cause it children to be ignored. Making what it does optional does not
solve any of the objections raised about side effects, security and race
conditions. It should only export on a menu action and then show the files
names it has generated and the directory they will go into like a normal
export file dialog. The only complication is there are multiple files
rather than one.
There is no need for new syntax for meta data tagging. You can always
explicitly put what you want exported under the export statement.
There is a separate, but extremely interesting idea on giving
names/tags to subtrees. I think it's worth separate discussion. Like having
a function, which fetches such name from subtree to be able to do something
like:
module mymod(){
name("My Super Module");
export(file=nameofchild()+".stl") mymod();
Or even place texts with module names on top of the modules themself
(seems fun, but not sure, whether it is needed by someone at all).
If I have missed something, correct me please.
So, I have a simple question to maintainers - if I address the issues 1-3,
will these patches be accepted (after technical review, cleanup, whatever)?
What I'm planing to do:
2. Add options to export()
onrender=true|false, default - true
onpreview=true|false, default - true
// At this point I want to add undiscussed option
show=true|false, default - true, to control, whether just-exported subtree
should be shown on screen.
characters, allowed in filenames to some known-safe set.
3b. Store all export/import filenames in some common (global?) data
structure to prevent loops.
10 янв. 2016 г. 12:26 AM пользователь "Greg Frost" <
gregorybartonfrost@gmail.com> написал:
What if instead of export(), you could just tag a part of the tree with a
name. Then when you do export, there could be an option to export subtrees
where you give a base name for the export and each tagged subtree is
exported with a filename constructed by appending the subtree's name to the
base name.
You would have to think about what to do if two things were tagged with
the same name.
Greg Frost
I do the same, many of my files have a list of
*!module1Name();
*!module2Name();
I like that approach.
In many of my more complicated designs I have something like:
plate="combined";
if( plate == "part1" )
module1Name();
if( plate == "part2" )
module2Name();
if( plate == "combined" )
translate([-20,-20, 0]) module1Name();
translate([ 20, 20, 0]) module2Name();
This makes it easy to generate specific versions using openscad on the
command line. It works particularly well driven by make.
G. Wade
at the bottom so that I can easily turn pieces off and on.
However, if using a generator:
for (i=[0 : 10])
for (j=[0 : 10])
translate ([i20, j20, 0]) smallPartGenerator(i, j);
I then have 100 individual volumes on a build plate which is NOT as
easy to toggle.
If we had an export command, then I could have an
export("R"+str(i) + "C"+str(j) + ".STL");
in the mix and get 100 STL files out of the deal; this makes it
easier to get a specific replacement without reprinting all 100.
On 1/9/2016 6:07 AM, jon wrote:
I create modules for each part, list them at the bottom of the
script, and then use ! to create the geometry for the part that I
wish to print.
On 1/8/2016 9:59 PM, Ezra Reynolds wrote:
I normally arrange the pieces in OpenSCAD for 3D printing (many
discrete volumes as a single STL). This works up to the point
where I have a single part, or several parts, fail during
printing / derafting/assembly. It is an error-prone thing to
manually isolate each part, render as an STL, save it with the
correct name, rinse and repeat. Not a problem with a three-part
assembly, but could be a problem with file that generates two
dozen variations on a theme.
rather than one.
> 4. There is a separate, but extremely interesting idea on giving
> like:
> module mymod(){
>> base name.
>> the same name.
>> Greg Frost
>> > On 10 Jan 2016, at 5:31 am, "G. Wade Johnson" <gwadej@anomaly.org>
>> wrote:
>> > On Sat, 09 Jan 2016 07:38:30 -0500
>> >> *!module1Name();
>> >> *!module2Name();
>> > plate="combined";
>> > module1Name();
>> > module2Name();
>> > G. Wade
>> >> for (i=[0 : 10])
>> >> for (j=[0 : 10])
>> >> translate ([i*20, j*20, 0]) smallPartGenerator(i, j);
>> >> easy to toggle.
>> >>> wish to print.
>> >>> _______________________________________________
>> >>> OpenSCAD mailing list
>> >>> Discuss@lists.openscad.org
>> >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
>> > You need at least two viewpoints to have perspective.
>> > -- Rick Hoselton
Sun, Jan 10, 2016 4:25 PM
always explicitly put what you want exported under the export
statement.
Ok, we also have https://github.com/openscad/openscad/issues/1044
which asks for a way to control the layers that will be exported
to DXF. And there's a number of other similar requests already. How
would you do that with multiple file exports? Put all the various
possible inputs as parameters into one single export() which is then
called sometimes with parameterset A (for dxf layers) and sometimes
for parameterset B (for defining a file export)? This would also
mean the export() calls would need to be nested as the layers belong
into a single file.
With just tagging the subtrees, it leaves the interpretation to
the actual export function which could even show that information
to the user and allow changing it.
Note1: The syntax is just the Java one, lots of other languages
have adopted this feature with a different syntax, we would be
free to choose.
Note2: The prototype implementing this is already there and it's
actually not very complicated. The complex part is as always the
GUI. I also like to point out how this prototype is for a completely
different feature (https://github.com/openscad/openscad/issues/722)
and that would also be covered using the same syntax, maybe at
other places in the code, like the module definition instead of
the module instantiation.
module something(s) {
square(s * 10);
module part(r) {
@DxfLayer("layer1")
rotate(r) something(10);
@DxfLayer("layer2")
rotate(r) something(20);
@Export(name = "part1")
part1(0);
@Export(name = "part2")
part1(45);
Basically this simply attaches a set of key/value pairs to the
nodes which then can be interpreted when traversing the models
node tree.
Slic3r supports annotations in AMF files, to define some
properties for slicing a model. Even that could be handled
like @AMFMetaData(name = "slic3r.extruder", value = 1) and
would be silently ignore for STL export which does not have
any means to store this information.
> statement.
into a single file.
free to choose.
square(s * 10);
module part(r) {
@DxfLayer("layer1")
@DxfLayer("layer2")
part1(0);
part1(45);
node tree.
Sun, Jan 10, 2016 4:47 PM
I think being able to put multiple layers in a DXF or multiple materials in
an AMF is completely orthogonal functionality to being able to export
multiple files using the export menu. They can both be implemented
separately and will simple work together when you export a tree that makes
a multi component file.
I.e. If you export a DXF then it is exactly the same as removing a * or
adding a !, doing F6 (or F5 if it is a png) and using the export menu. My
proposed export simply automates what you can already with *,! and the
export menu but is tedious. I don't see why designing a multi-material
system needs to hold up this simple function.
My preferred way of doing multi-materials would be to attach attributes
exactly the same way color does, rather than borrowing more syntax from
other languages. Keep it looking like C as much as possible. I wouldn't
have chosen C myself as I prefer Python syntax but as it started out almost
pure C syntax I think it should stay that way.
statement.
into a single file.
free to choose.
square(s * 10);
module part(r) {
@DxfLayer("layer1")
@DxfLayer("layer2")
part1(0);
part1(45);
node tree.
> > statement.
> into a single file.
> free to choose.
> square(s * 10);
> module part(r) {
> @DxfLayer("layer1")
> @DxfLayer("layer2")
> part1(0);
> part1(45);
> node tree.
> ciao,
> Torsten.
Sun, Jan 10, 2016 5:23 PM
On 01/10/2016 05:47 PM, nop head wrote:
I wouldn't have chosen C myself as I prefer Python syntax but as it
started out almost pure C syntax I think it should stay that way.
Interesting, even Python has similar features for functions.
http://python-future.org/func_annotations.html
And when looking at python decorators, the syntax almost matches
the Java syntax, I've used as example:
http://thecodeship.com/patterns/guide-to-python-function-decorators/
Although those are serving a bit different purpose, I think.
As I said, the specific syntax is just a prototype so far. It
does not really matter. Unfortunately C does not have annotations
so we can't borrow that syntax. But you could also argue that SCAD
looks like C# and we could try to use that syntax.
attributes exactly the same way color does
I think the key word here is attach. And that's precisely what
color() right now does not do. It creates a new tree node, so
if you traverse the node tree, there's a separate color node.
This actually makes things more complicated internally.
I think the key word here is *attach*. And that's precisely what
Sun, Jan 10, 2016 5:46 PM
I think your last point is implementation details, which should not really
dictate language syntax. From the outside I don't see any logical
difference between color and material and isn't everything a tree node in
openscad? It is however a big subject when you consider what happens with
respect to CGS ops (that isn't even right for colours yet). I don't think
it should hold up this or have any bearing on it.
I would prefer to keep the syntax as small as possible and not grabbed from
other, far more complicated, languages. Otherwise you might as well write
in those languages and generate scad files, as many people do.
module mydx() {
layer("outlines") { // note I have no idea what DXF layers names look
like.
layer("engrave") {
export("my.xdf) mydxf();
module myamf() {
material("PLA") {.....};
material("TEP") {.....};
export("my.amf") myamf();
Why does it need to be more complicated?
module mydx() {
like.
layer("engrave") {
module myamf() {
> ciao,
> Torsten.
Mon, Jan 11, 2016 3:42 AM
not really dictate language syntax.
In some respects, yes, that's true. But there's one thing that
does make it relevant. When using "normal" builtin modules to
define meta-data, we will capture all those names. Part of that
might be fixable if there's ever an implementation for namespaces,
but that's a bigger project in itself.
I've seen quite some cases where trying to unify everything into
the same logic resulted in problems.
From the outside I don't see any logical difference between
color and material and isn't everything a tree node in openscad?
Yes, color() is obviously existing as node already as there is
currently no other means. It certainly could be an annotation too.
I'm not really convinced that because we currently only have
hammers^H^H^H^H^H^H^Hnodes we need to shape every new problem
into nails^H^H^H^H^Hnodes if there are other options too.
Well, actually that's not totally true that we only have nodes.
In fact the ! # and % modifiers already behave like an annotation
for the module they are written before. This explains why this is
a parse error:
! { cube(); sphere(); }
And if we are talking about how hugely complicated things look
with annotations, let me, just for illustration purposes, use _
instead of that scary @ and reformat a bit
module part(r) {
_layer("layer1") rotate(r) something(10);
_layer("layer2") rotate(r) something(20);
_export(name = "part1") part1(0);
_export(name = "part2") part1(45);
Hmm, I really don't see how that's more complicated. Although
export is probably a bad name anyway. Something like Volume
would probably be ok, or even better something that applies
nicely to both 3D and 2D objects. (That's basically the HTML
discussion: Do logical instead of presentational description
and leave the interpretation to the processor/browser).
In essence, I think the only real difference between using a
module and something special whatever it's called is that it
introduces a different global namespace that does not collide
with the other existing ones and is not evaluated in the
script itself but in the renderer/exporter/external-tool.
a parse error:
module part(r) {
MV
Mihail Vasiliev
Mon, Jan 11, 2016 5:51 AM
Well, interpretation of any language feature is always up to the tool,
which reads this language. E.g. if it's web app, it can open a frame/new
window/whatever with such exported view.
Hmm, may be it should be called view() instead of export()?
11 янв. 2016 г. 6:43 AM пользователь "Torsten Paul" Torsten.Paul@gmx.de
написал:
a parse error:
module part(r) {
11 янв. 2016 г. 6:43 AM пользователь "Torsten Paul" <Torsten.Paul@gmx.de>
написал:
> a parse error:
> module part(r) {
> ciao,
> Torsten.
Mon, Jan 11, 2016 7:43 AM
Structure
An AMF can represent one object, or multiple objects arranged in a
constellation. Each object is described as a set of non-overlapping
volumes. Each volume is described by a triangular mesh that references a
set of points (vertices). These vertices can be shared among volumes. An
AMF file can also specify the material and the color of each volume, as
well as the color of each triangle in the mesh. The AMF file is compressed
using the zip compression format, but the ".amf" file extension is
retained. A minimal AMF reader implementation must be able to decompress
an AMF file and import at least geometry information (ignoring curvature).
Basic file structure
The AMF file begins with the XML declaration line specifying the XML
version and encoding. The remainder of the file is enclosed between an
opening
<amf>
element and a closing
</amf>
element. The unit system can also be specified (millimeter, inch, feet,
meter or micrometer). In absence of a units specification, millimeters are
assumed.
Within the AMF brackets, there are five top level elements. Only a single
object element is required for a fully functional AMF file.
object - The object element defines a volume or volumes of material,
each of which are associated with a material ID for printing. At least one
object element must be present in the file. Additional objects are
optional.
material - The optional material element defines one or more materials
for printing with an associated material ID. If no material element is
included, a single default material is assumed.
texture - The optional texture element defines one or more images or
textures for color or texture mapping, each with an associated texture ID.
constellation - The optional constellation element hierarchically
combines objects and other constellations into a relative pattern for
printing.
metadata - The optional metadata element specifies additional
information about the object(s) and elements contained in the file.
"An AMF file can also specify the material and the color of each volume"
call it a volume()
View this message in context: http://forum.openscad.org/export-function-tp15428p15645.html
Wikpedia - AMF
> Structure
> opening
> <amf>
> </amf>
> assumed.
> optional.
> printing.
call it a volume()
Thu, Jan 14, 2016 12:26 AM
I agree with Nop Head that we can and should keep the syntax simple., The
namespace management issue that Torsten brought up is really orthogonal to
this discussion, and can be solved in a different way.
There are several different use cases being discussed. Multi-part models,
as described by Ezra, are really a different problem than multiple
materials. We've discussed multi-material semantics in a different thread,
and we want to extend the semantics of the CSG operators to behave sensibly
when the argument shapes consist of multiple materials. That issue doesn't
arise for multi-part models.
AMF is relevant to multi-part models. The AMF file format can separately
describe each component of a multi-part model. And slic3r has support for
reading and writing multi-part models, as single AMF files. Ezra describes
the situation where you try to print a multi-part model: some of the parts
print successfully, some of them fail. Then you want to reprint only those
components that failed. Slic3r supports this workflow using multi-part AMF
files (in Expert mode).
I think OpenSCAD should provide a simple, high level syntax for tagging the
different parts of a multi-part model. The details of how that is
represented in the file system should depend on what export option you are
using. There's one option to export a multi-part model as a collection of
STL files, and there's another option to export it as a single AMF file. (A
third option is to export the entire assembly as a single STL file.)
Instead of export("filename"), we could have component("partname"). This
way, the model stays abstract, and the details of which file format you are
exporting to are kept out of the model.
Doug.
from other, far more complicated, languages. Otherwise you might as well
write in those languages and generate scad files, as many people do.
module mydx() {
like.
layer("engrave") {
module myamf() {
AMF *is* relevant to multi-part models. The AMF file format can separately
Doug.
> module mydx() {
> like.
> layer("engrave") {
> module myamf() {
>> ciao,
>> Torsten.
