Is there an instruction guide for the actual editor? I have a problem with
auto fill.
If I start to type "cube" I get the popup window with "cube" highlighted in
it and I can click on it and it is entered into the editor.
But if I type "cube(" I get 3 options which would be correct but none are
highlighted and nothing I've tried so far allows me to select them.
What am I missing?
Ken Howard
I have not seen a guide. But then I never read manuals so I have not thought to look for one.
I think you will find that the first window is autocomplete and the later is help - they are different color boxes.
With autocomplete on Mac (threshold set at 3 (preferences, editor, character threshold)) I can just hit enter after typing ‘dif' and it completes “difference’ no mouse involved.
On 13 Apr 2021, at 20:37, Ken Howard 1301ken@gmail.com wrote:
Is there an instruction guide for the actual editor? I have a problem with auto fill.
If I start to type "cube" I get the popup window with "cube" highlighted in it and I can click on it and it is entered into the editor.
But if I type "cube(" I get 3 options which would be correct but none are highlighted and nothing I've tried so far allows me to select them.
What am I missing?
Ken Howard
As a newbie, the syntax doesn't come naturally. The pop-up options are very
helpful but I'd find it significantly better if one could be clicked to
automatically insert it.
Terry
Thanks for that. I had the wrong idea about the popup.
Ken Howard
auto fill.
What am I missing?
Ken Howard
The popup autocomplete is fine, but would really like to see
configurable popup help.
I find it extremely annoying when it blocks something I want to see,
like values in the next few lines.
This may be because of workflow that not many others might use.
Example:
I type a line:
cube([10.4,21.5,30]);
I then want to translate it, so I position my cursor on the previous
line.
translate(
At that point, the help popup activates, blocking my view of the
values. Then I usually hit cursor down then up, getting rid of the help
popup.
What I would find extremely helpful as popup help is if the initial
autocomplete popup would give me something like (for cube, as an
example)
cube();
cube([]);
And when one is selected, position the cursor in the appropriate place.
I am not a touch-typist, so when I enter something that needs a vector,
I do something like this:
translate([]);
then left cursor three times, and put in my values.
editor.
select them.
What am I missing?
Ken Howard
