Re: [OpenSCAD] Bending complex shapes, circle of a helix
N
Neon22
Sat, Aug 8, 2015 7:47 AM
most people won't see your post as you're not registered for the mailing
list. You should ?
As for the dynamic helix.
Check the post a couple back where another user has been making ellipses.
Hope it helps.
http://forum.openscad.org/Tough-Nut-How-to-get-text-on-this-ellipse-shape-td13430.html
View this message in context: http://forum.openscad.org/Bending-complex-shapes-circle-of-a-helix-tp13460p13479.html
most people won't see your post as you're not registered for the mailing list. You should ? As for the dynamic helix. Check the post a couple back where another user has been making ellipses. Hope it helps. http://forum.openscad.org/Tough-Nut-How-to-get-text-on-this-ellipse-shape-td13430.html -- View this message in context: http://forum.openscad.org/Bending-complex-shapes-circle-of-a-helix-tp13460p13479.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sat, Aug 8, 2015 1:05 PM
list. You should ?
Not sure what you're asking. So;
a. Most people just read the emails which Nabble sends them.
b. Many people do NOT read the web 'forum'  here.
c. So, if you are NOT appropriately  registered.
http://forum.openscad.org/mailing_list/MailingListOptions.jtp?forum=1
your posts do not go to the many people at a.
d. Sometimes a new register-person's first post doesn't make it for some
timing issue, but second posts are OK.
e. Every so-often, I go through the posts on the web forum, and any with
zero replies, I check to see if they are 'lost' posts which didn't make it
to the mailing list, and inform them of such.
f. If there is a problem they should do/redo the instructions  here.
g. If that fails, they should post a help-me post to attract the attention
of the list admins.
View this message in context: http://forum.openscad.org/Bending-complex-shapes-circle-of-a-helix-tp13460p13480.html
> most people won't see your post as you're not registered for the mailing list. You should ? Not sure what you're asking. So; a. Most people just read the emails which Nabble sends them. b. Many people do NOT read the web 'forum' here. <http://forum.openscad.org/> c. So, if you are NOT appropriately registered. <http://forum.openscad.org/mailing_list/MailingListOptions.jtp?forum=1> your posts do not go to the many people at a. d. Sometimes a new register-person's first post doesn't make it for some timing issue, but second posts are OK. e. Every so-often, I go through the posts on the web forum, and any with zero replies, I check to see if they are 'lost' posts which didn't make it to the mailing list, and inform them of such. f. If there is a problem they should do/redo the instructions here. <http://forum.openscad.org/mailing_list/MailingListOptions.jtp?forum=1> g. If that fails, they should post a help-me post to attract the attention of the list admins. ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/Bending-complex-shapes-circle-of-a-helix-tp13460p13480.html Sent from the OpenSCAD mailing list archive at Nabble.com.
