How does one open a second view of the same project now the multi-tab
version has been implemented?
I.e. if I open a file from the file menu it puts in on a second tab but it
doesn't get another preview window. Also if I have the editor hidden there
are no tabs, so it looks like it just replaces the original file but it
still has the old file loaded.
I can open another instance of OpenSCAD but then it doesn't share the
design. Since it will use another core, that is generally what I do, but we
seem to have lost some functionality. I think if the editor is hidden,
opening a file should do what it did before. I.e. you get a new instance of
the GUI that shares the model data.
You mean that you open two windows on the same design to view it from two
different angles? Neat trick. I should try that some day!
Not exactly. When I have big multi-file projects I might have the main
assembly in one window and a sub-assembly that I am working on in another
window.
it
second tab but it doesn't get another preview window.
Yes, one window = one 3d viewer. If you would like to have
multiple 3d viewers, "File->Open in New Window" will create
a new window.
Also if I have the editor hidden there are no tabs, so it
looks like it just replaces the original file but it still
Yes, editor tabs belong to the editor, so they are hidden
together. If you undock the editor to a separate view, the
tabs will come along too.
Thanks, I never noticed those new menu options, or perhaps forgot about
them.
One thing that would be great is if File New un-hid the editor. I only use
the editor when I cut and paste a code example from this mailing list, so I
always have to un-hide it after doing File New. I don't think new makes
sense with the editor hidden.
a new window.
a new window.
I am running OpenSCAD V2019.05, and I do not have a menu item
File->Open in New Window. Running on Windows 7, 64-bit.
If I click on File->New, I do get another blank window.
What am I missing?
What am I missing?
Editor tabs are new feature in the development snapshots.
the editor. I only use the editor when I cut and paste
a code example from this mailing list, so I always
new makes sense with the editor hidden.
Yep, that's sounds useful. I've created a ticket for
this: https://github.com/openscad/openscad/issues/3401
