This week my snap/openscad installation broke.
After removing snap/openscd and so on I tried to reinstall openscad on
Ubuntu, with no luck. I've
apt install openscad op
snap install openscad
docker
Result: openscad: error while loading shared libraries:
libboost_filesystem.so.1.71.0: cannot open shared object file: No such
file or directory
Google doesn't come with an answer. :(
I know it's probably not a real openscad issue, but I'm stuck and any
help would be appreciated.
Greetings Matthieu
Which OpenSCAD did you use, the one shipped included in Ubuntu?
What Ubuntu version is it?
Check with apt-cache policy and see where the package is coming
from. Maybe it's some additional package source causing the issue.
This not working is surprising as the application is packaged
completely inside a container so there should not be some random
stuff missing. Did you try running specifically with:
/snap/bin/openscad
I would not recommend that unless you have special needs,
plain docker installation of GUI programs is not impossible
but it does need some deeper understanding of what's going
on behind the curtains.
libboost_filesystem.so.1.71.0: cannot open shared object file: No such file or directory
Try:
"which openscad" to show where the binary is coming from
Run:
"ldd /usr/bin/openscad" using the path from the previous step
and see what it shows reagarding "libboost*" files.
on Ubuntu, with no luck. I've
I am not a fan of snap, so I can't help with that part.
I am running a development snapshot in an Appimage, on Ubuntu MATE, and
have no problems with it.
You can get it on https://openscad.org/downloads.html#snapshots
I put it in my ~/bin directory where I keep Appimages and script files.
Greetings Matthieu
I'm using Ubuntu 22.04.3 LTS.
I finally downloaded the source code, did a complete compile and
install, without any options/special settings, and it was running.
Than I saw the appimage on the dowload, After that I downloaded the
"appimage" this one also worked fine.
So I gave up on the apt install, the snap install and the docker
install. :)
I expected the compiled version to be faster than the appimage one. But
the appimage one is with the preview significant faster than with the
local compiled one.
Any clues about this?
Thanks for helping out.
Torsten Paul schreef op 2023-09-16 19:31:
/snap/bin/openscad
file or directory
Try:
Run:
If you did not specify CMAKE_BUILD_TYPE=Release then it was likely built
with no compiler optimizations.
On Sat, Sep 16, 2023 at 2:44 PM Matthieu Hendriks mhendriks@digirent.nl
I finally downloaded the source code, did a complete compile and install,
So I gave up on the apt install, the snap install and the docker install.
the appimage one is with the preview significant faster than with the local
compiled one.
/snap/bin/openscad
Try:
Run:
Yes that did it.
cmake -DCMAKE_BUILD_TYPE=Release
Thanks for the help.
Hans L schreef op 2023-09-16 22:46:
built with no compiler optimizations.
install. :)
local compiled one.
On 16.09.23 07:58, Matthieu Hendriks wrote: This week my snap/openscad
installation broke.
/snap/bin/openscad
file or directory
Try:
Run:
