Re: [OpenSCAD] combine a union child and a difference childinoneobject.
Leef_me
Tue, Dec 1, 2015 10:08 AM
I disagree with your comment that they are completely different things.
One encapsulates the other,
You notice that the code can be single lines; but I have only presented the simplest form for discussion.
I found this reference, but I'm working through it.
http://www.tridimake.com/2014/11/how-to-use-openscad-4-children-and.html
Sent: Tuesday, December 01, 2015 1:43 AM
Subject: Re: [OpenSCAD] combine a union child and a difference childinoneobject.
Passing a parameter to a module to make it do two completely different things doesn't make sense from a programming point of view. It is better to stop pretending it is a single thing and make two modules: wire_inner() and wire_outer(). That is a lot more descriptive than wire(which=2) and wire(which=-1) and since they can be single line modules it is actually less code.
module wire_inner()cylinder(d = 1, h = 15, center = true);
module wire_outer()cylinder(d = 1.5, h = 7, center = true);
$fn=16;
cube([5, 5, 5], center = true);
wire_outer(); // part A
wire_inner(); // part B
It is more readable but it still doesn't get around the fact you can't have negative objects outside of a difference.
You could make a module that does both an add and a subtract but it makes these code more obscure.
module add_and_subtract()
       children(0);
       children(1);
   children(2);
$fn=16;
add_and_subtract() {
wire_outer();
wire_inner();
And you could to a truly horrible hack like this: -
module wire()
if($negative)
   wire_outer();
else
   wire_inner();
       children(0);
       $negative = true;
       children(1);
   $negative = false;
   children(1);
$fn=16;
wire();
But I think it is just obscuration.
On 1 December 2015 at 00:54, Leef_me Leef_me@cox.net wrote:
Here is a new version that does something of what I want.
$fn=16;
cube([5,5,5], center=true);
wire(which=2); // part A
wire(which=-1); // part B
module wire(which=1)
if (which==-1)
cylinder(d=1, h=15, center=true); // part B
else
#cylinder(d=1.5, h=7, center=true); // part A
This page refers to children, but I don't see how to change the module to use children(0) or children(1)
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/The_OpenSCAD_Language#Object_modules
Sent: Monday, November 30, 2015 4:22 PM
Subject: Re: [OpenSCAD] combine a union child and a difference child inoneobject.
No you can't do that in one operation in OpenScad. You need to subtract the hole and add the rod. You could subtract a tube, which would leave a hole with a rod in it but it couldn't protrude out of the cube without adding it.
On 1 December 2015 at 00:08, Leef_me Leef_me@cox.net wrote:
You have all the essentially information.
  The cube has a cylindrical hole cut vertically through it.
  Inside this is a thinner rod.
  They are not connected together in any place.
  We can't work out what sort of object you are trying to make.
I want the "cylindrical hole" to be in the same module as the "thinner rod".
Wherever the "thinner rod" is placed, the "cylindrical hole" follows.
If I build a union of all the "thinner rods", their companion holes are cut from some shape that I specify.
Sent: Monday, November 30, 2015 2:32 PM
To: <discuss@lists.openscad.org>
Subject: Re: [OpenSCAD] combine a union child and a difference child in oneobject.
  You could add a flattened cube at the bottom and thereby make a mold kind-of
  object to perhaps pour goop into to make tubes,  but not sure what this
  object is trying to acheive so not sure how to answer your question.
  View this message in context: http://forum.openscad.org/combine-a-union-child-and-a-difference-child-in-one-object-tp14834p14846.html
I disagree with your comment that they are completely different things. One encapsulates the other, You notice that the code can be single lines; but I have only presented the simplest form for discussion. I found this reference, but I'm working through it. http://www.tridimake.com/2014/11/how-to-use-openscad-4-children-and.html From: nop head Sent: Tuesday, December 01, 2015 1:43 AM To: OpenSCAD general discussion Subject: Re: [OpenSCAD] combine a union child and a difference childinoneobject. Passing a parameter to a module to make it do two completely different things doesn't make sense from a programming point of view. It is better to stop pretending it is a single thing and make two modules: wire_inner() and wire_outer(). That is a lot more descriptive than wire(which=2) and wire(which=-1) and since they can be single line modules it is actually less code. module wire_inner()cylinder(d = 1, h = 15, center = true); module wire_outer()cylinder(d = 1.5, h = 7, center = true); $fn=16; difference() { cube([5, 5, 5], center = true); wire_outer(); // part A }; wire_inner(); // part B It is more readable but it still doesn't get around the fact you can't have negative objects outside of a difference. You could make a module that does both an add and a subtract but it makes these code more obscure. module add_and_subtract() union() { difference() { children(0); children(1); } children(2); } $fn=16; add_and_subtract() { cube([5, 5, 5], center = true); wire_outer(); wire_inner(); } And you could to a truly horrible hack like this: - module wire() if($negative) wire_outer(); else wire_inner(); module add_and_subtract() union() { difference() { children(0); $negative = true; children(1); } $negative = false; children(1); } $fn=16; add_and_subtract() { cube([5, 5, 5], center = true); wire(); } But I think it is just obscuration. On 1 December 2015 at 00:54, Leef_me <Leef_me@cox.net> wrote: Here is a new version that does something of what I want. $fn=16; difference() { cube([5,5,5], center=true); wire(which=2); // part A }; wire(which=-1); // part B module wire(which=1) { if (which==-1) cylinder(d=1, h=15, center=true); // part B else #cylinder(d=1.5, h=7, center=true); // part A }; This page refers to children, but I don't see how to change the module to use children(0) or children(1) https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/The_OpenSCAD_Language#Object_modules From: nop head Sent: Monday, November 30, 2015 4:22 PM To: OpenSCAD general discussion Subject: Re: [OpenSCAD] combine a union child and a difference child inoneobject. No you can't do that in one operation in OpenScad. You need to subtract the hole and add the rod. You could subtract a tube, which would leave a hole with a rod in it but it couldn't protrude out of the cube without adding it. On 1 December 2015 at 00:08, Leef_me <Leef_me@cox.net> wrote: You have all the essentially information. The cube has a cylindrical hole cut vertically through it. Inside this is a thinner rod. They are not connected together in any place. We can't work out what sort of object you are trying to make. I want the "cylindrical hole" to be in the same module as the "thinner rod". Wherever the "thinner rod" is placed, the "cylindrical hole" follows. If I build a union of all the "thinner rods", their companion holes are cut from some shape that I specify. -------------------------------------------------- From: "Neon22" <mschafer@wireframe.biz> Sent: Monday, November 30, 2015 2:32 PM To: <discuss@lists.openscad.org> Subject: Re: [OpenSCAD] combine a union child and a difference child in oneobject. The cube has a cylindrical hole cut vertically through it. Inside this is a thinner rod. They are not connected together in any place. We can't work out what sort of object you are trying to make. You could add a flattened cube at the bottom and thereby make a mold kind-of object to perhaps pour goop into to make tubes, but not sure what this object is trying to acheive so not sure how to answer your question. -- View this message in context: http://forum.openscad.org/combine-a-union-child-and-a-difference-child-in-one-object-tp14834p14846.html Sent from the OpenSCAD mailing list archive at Nabble.com. _______________________________________________ OpenSCAD mailing list Discuss@lists.openscad.org http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org _______________________________________________ OpenSCAD mailing list Discuss@lists.openscad.org http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org ------------------------------------------------------------------------------ _______________________________________________ OpenSCAD mailing list Discuss@lists.openscad.org http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org _______________________________________________ OpenSCAD mailing list Discuss@lists.openscad.org http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org -------------------------------------------------------------------------------- _______________________________________________ OpenSCAD mailing list Discuss@lists.openscad.org http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
