Various "illegalities" are tolerated on a single object (the STL file
polyhedron) but not allowed when unioned with other objects where more
strict rules (closed, inward/outard faces) are enforced. Try a F5 with
"thrown together"
On Fri, 3 Mar 2023 at 14:27, fred via Discuss discuss@lists.openscad.org
Cc:
Bcc:
Date: Fri, 3 Mar 2023 13:27:01 +0000 (UTC)
Subject: [OpenSCAD] Re: Why?????
without the stl file to import, it's just a rough guess on my part, not
being particularly skilled with OpenSCAD, but I'd venture a guess that the
imported file sits on the x/y plane and your d_base is slightly below that
level. Translate one down or the other up and aim for a bit of overlap
(i.e., 0.0625 mm) to ensure a clean join/union.
On Friday, March 3, 2023 at 08:03:26 AM EST, gmagyar6@gmail.com <
gmagyar6@gmail.com> wrote:
I would like to import an stl file and then add a shape.
If I render ONLY the stl file (F6), everything is fine!!!
If I create a base for it, however, it runs into an error:
ERROR: The given mesh is not closed! Unable to convert to CGAL_Nef_Polyhedron.
WHY????
$fn=64;
turret_height = 25;
p0 = 0;
p1 = 50;
p2 = 60;
module base(){
cylinder(h=15, r1=50, r2=52, center=true);
translate([0,0,5])
cylinder(h=15, r1=47, r2=49, center=true);
}//difference
module d_base(){
base();
translate([0,0,1])
for (i=[0 : 45 : 360]) {
rotate([0, 0, i])
linear_extrude(height = turret_height) {
polygon( points=[[0,0],[p2,p1],[p1,p2]] );
} //linear_extrude
} //for
} //difference
} //module
module gorilla(){
resize([48,0,0], auto=true)
translate([0,0,3])
import("buddha_gorilla.stl",convexity=10);
gorilla();
d_base();
/*union(){
gorilla();
d_base();
}//union
Cc: fred fred_dot_u@yahoo.com
Bcc:
I always repair STLs (when necessary) at:
https://www.formware.co/onlinestlrepair
This is also sometimes necessary with STLs generated by openSCAD, even
when just unioning and differencing primitive objects. I have one
project where after exporting the STL contains funnies that cause the
slicer to simply leave out one layer in the middle. With the next
layer sticking "a bit" onto the previous one, it looks normal, but the
object breaks easily. But after repair: all layers are converted to
gcode.
"thrown together"
Cc:
Bcc:
WHY????
$fn=64;
turret_height = 25;
p0 = 0;
p1 = 50;
p2 = 60;
module base(){
translate([0,0,5])
}//difference
module d_base(){
base();
translate([0,0,1])
rotate([0, 0, i])
} //linear_extrude
} //for
} //difference
} //module
module gorilla(){
translate([0,0,3])
gorilla();
d_base();
/*union(){
gorilla();
d_base();
}//union
Bcc:
