Just move it in Inkscape. I think inkscape places the origin in the bottom
left corner of the page.
View this message in context: http://forum.openscad.org/Rendering-DXFs-from-Inkscape-tp11789p11802.html
I have been using this same tutorial for importing dxfs into my scad files.
Only on step 6 I am using the "Extensions - Modify Path - Flatten Beziers"
with a value of 0.1
Apart from that in order to exactly locate my imported dxfs I use the
"dxf_cross" mentioned here:
http://en.wikibooks.org/wiki/OpenSCAD_User_Manual/General#Getting_input
You can see how I use it lines 516-519 and lines 900-903
Code is in BasWheel.scad file
DXF files are BasSpoke1.dxf and rc1_10.dxf (I also have the source svg files
too)
Files can be found here: https://github.com/basile-laderchi/BasWheel
View this message in context: http://forum.openscad.org/Rendering-DXFs-from-Inkscape-tp11789p11813.html
I use Inkscape and OpenSCAD together frequently.
my steps:
1 - Draw object in Inkscape
2 - Move object to lower left corner of page, align left/right center marker
to left page border, align top/bottom center marker with the bottom page
border (it may help to turn off the page shadow in Document Properties)
3 - Select Objects you want to export
4 - Convert to Path: Path --> Object to Path (Ctrl+Shift+C)
5 - Flatten Beziers: Extensions --> Modify Path --> Flatten Beziers
(adjust the value based on granularity you need; I use 0.3 or 0.1 for most
things)
6 - Save as Desktop Cutting Plotter (Autocad DXF R14) .DXF file
7 - Make sure the ROBO-Master spline option is unchecked, LWPOLYLINE option
is checked. I keep the base units in mm to be consistent with OpenSCAD.
8 - import the file in OpenSCAD (e.g. import ("drawing.dxf"); )
View this message in context: http://forum.openscad.org/Rendering-DXFs-from-Inkscape-tp11789p11814.html
re: processing with inkscape
you can 'resize the page to drawing' in Inkscape, which helps with
getting expected output. I inserted an optional step below that
describes how it works in my 0.91pre version that should work for most
all versions:
my steps:
Resize page to drawing:
in Inkscape, from the File menu, select 'document properties', and go
to the orientation section of the document properties dialog, click
the section pointer at 'resize page to content' to expand, and click
resize page to drawing or selection.
things)
