Rendering inconsistent across two computers
WH
Will Hardiman
Sat, May 11, 2019 3:55 PM
When I try to preview or render this code:
circle(r = 100);
translate([10, 0, 0])
circle(r = 100);
On my computer, I see a crescent, as expected. When my friend previews or
renders it on his computer, there's no model. We both have version
2015.03-2 running on windows 10.
Any ideas?
Cheers,
Will
Hi, When I try to preview or render this code: difference(){ circle(r = 100); translate([10, 0, 0]) circle(r = 100); } On my computer, I see a crescent, as expected. When my friend previews or renders it on his computer, there's no model. We both have version 2015.03-2 running on windows 10. Any ideas? Cheers, Will
AR
Algot Runeman
Sat, May 11, 2019 5:18 PM
On 5/11/19 11:55 AM, Will Hardiman wrote:
circle(r = 100);
circle(r = 100);
I entered your code into my Linux computer using the same OpenSCAD
version you mentioned.
Initially, I could not see the preview, but 100 units out is beyond the
default view for the preview. After I clicked the zoom-in icon a couple
of times, there it was.
I don't know if that was an issue for your friend, but...
On 5/11/19 11:55 AM, Will Hardiman wrote: > difference(){ > circle(r = 100); > > translate([10, 0, 0]) > circle(r = 100); > } I entered your code into my Linux computer using the same OpenSCAD version you mentioned. Initially, I could not see the preview, but 100 units out is beyond the default view for the preview. After I clicked the zoom-in icon a couple of times, there it was. I don't know if that was an issue for your friend, but...
Sat, May 11, 2019 5:56 PM
I had to zoom out to be able to see it. If your friend is a novice that
might be the problem.
On Sat, 11 May 2019 at 16:56, Will Hardiman bill.hardiman1995@gmail.com
circle(r = 100);
circle(r = 100);
Any ideas?
Cheers,
Will
I had to zoom out to be able to see it. If your friend is a novice that might be the problem. On Sat, 11 May 2019 at 16:56, Will Hardiman <bill.hardiman1995@gmail.com> wrote: > Hi, > > When I try to preview or render this code: > > difference(){ > circle(r = 100); > > translate([10, 0, 0]) > circle(r = 100); > } > > On my computer, I see a crescent, as expected. When my friend previews or > renders it on his computer, there's no model. We both have version > 2015.03-2 running on windows 10. > > Any ideas? > > Cheers, > Will > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
SR
Sébastien Roy
Sun, May 12, 2019 10:31 PM
On Sat, 2019-05-11 at 18:56 +0100, nop head wrote:
circle(r = 100);
circle(r = 100);
The preview (F5) is using opencsg, which depends on the graphics card
capabilities.
If you to F6 (full render), do you get the same result?
Cheers,
Sebastien
On Sat, 2019-05-11 at 18:56 +0100, nop head wrote: > difference(){ > circle(r = 100); > > translate([10, 0, 0]) > circle(r = 100); > } The preview (F5) is using opencsg, which depends on the graphics card capabilities. If you to F6 (full render), do you get the same result? Cheers, Sebastien
