polyhedron with cube not valid 2-manifold
D
dknell
Sun, Feb 14, 2016 11:17 PM
Hello,
I have a simple polyhedron and I'm trying to attach a cube to it. My code is
below.
The preview looks like this:
http://forum.openscad.org/file/n16132/img1.png
The render looks like this:
http://forum.openscad.org/file/n16132/img2.png
If I remove the cube, it renders fine:
http://forum.openscad.org/file/n16132/img3.png
I've read a bunch of posts regarding this subject on the OpenSCAD forums and
a few other places and I can't seem to figure out why my object is not
rendering correctly.
If anyone can shed some light, I'd really appreciate it.
Here is my code:
View this message in context: http://forum.openscad.org/polyhedron-with-cube-not-valid-2-manifold-tp16132.html
Hello, I have a simple polyhedron and I'm trying to attach a cube to it. My code is below. The preview looks like this: <http://forum.openscad.org/file/n16132/img1.png> The render looks like this: <http://forum.openscad.org/file/n16132/img2.png> If I remove the cube, it renders fine: <http://forum.openscad.org/file/n16132/img3.png> I've read a bunch of posts regarding this subject on the OpenSCAD forums and a few other places and I can't seem to figure out why my object is not rendering correctly. If anyone can shed some light, I'd really appreciate it. Here is my code: -- View this message in context: http://forum.openscad.org/polyhedron-with-cube-not-valid-2-manifold-tp16132.html Sent from the OpenSCAD mailing list archive at Nabble.com.
PF
Peter Falke
Sun, Feb 14, 2016 11:39 PM
Most likely there are wrongly orientated triangles:
Have a look here:
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Primitive_Solids
Let's now see how to fix polyhedrons with badly oriented polygons. When you
select 'Thrown together' from the view menu and compile the design (not
compile and render!) you will see a preview with the mis-oriented polygons
highlighted. Unfortunately this highlighting is not possible in the OpenCSG
preview mode because it would interfere with the way the OpenCSG preview
mode is implemented.)
Below you can see such a problematic polyhedron, bad triangles are in pink.
2016-02-15 0:17 GMT+01:00 dknell d4v1dd@gmail.com:
Hello,
is
below.
and
Here is my code:
Most likely there are wrongly orientated triangles: Have a look here: https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Primitive_Solids Let's now see how to fix polyhedrons with badly oriented polygons. When you select 'Thrown together' from the view menu and *compile* the design (*not* compile and render!) you will see a preview with the mis-oriented polygons highlighted. Unfortunately this highlighting is not possible in the OpenCSG preview mode because it would interfere with the way the OpenCSG preview mode is implemented.) Below you can see such a problematic polyhedron, bad triangles are in pink. 2016-02-15 0:17 GMT+01:00 dknell <d4v1dd@gmail.com>: > Hello, > > I have a simple polyhedron and I'm trying to attach a cube to it. My code > is > below. > > The preview looks like this: > <http://forum.openscad.org/file/n16132/img1.png> > > The render looks like this: > <http://forum.openscad.org/file/n16132/img2.png> > > If I remove the cube, it renders fine: > <http://forum.openscad.org/file/n16132/img3.png> > > I've read a bunch of posts regarding this subject on the OpenSCAD forums > and > a few other places and I can't seem to figure out why my object is not > rendering correctly. > > If anyone can shed some light, I'd really appreciate it. > > Here is my code: > > > > > > > > -- > View this message in context: > http://forum.openscad.org/polyhedron-with-cube-not-valid-2-manifold-tp16132.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
jpmendes
Mon, Feb 15, 2016 12:22 AM
Hello
You must connect the top vertices of the top triangles. If you check the
part in wireframe mode "F11" you will see what I mean.
jpmendes
View this message in context: http://forum.openscad.org/polyhedron-with-cube-not-valid-2-manifold-tp16132p16135.html
Hello You must connect the top vertices of the top triangles. If you check the part in wireframe mode "F11" you will see what I mean. jpmendes -- View this message in context: http://forum.openscad.org/polyhedron-with-cube-not-valid-2-manifold-tp16132p16135.html Sent from the OpenSCAD mailing list archive at Nabble.com.
jpmendes
Mon, Feb 15, 2016 1:13 AM
Hey
Check this.
Code:
$fn = 180;
size = 34;
side_a = size * sin(45);
side_b = size * cos(45);
side_c = size * tan(45);
tri_top_0 = [0,0,0];
tri_top_1 = [side_b,0,0];
tri_top_2 = [0,-side_a,0];
tri_bot_3 = [0,0,size];
tri_bot_4 = [side_b,0,size];
tri_bot_5 = [0,-side_a,size];
show_mount_plate = true;
mount_plate_thickness = 5;
polyhedron(
points=[
tri_top_0, tri_top_1, tri_top_2,
tri_bot_3, tri_bot_4, tri_bot_5,
// faces=[ [0,1,2], [3,4,5], [0,1,4,3], [1,2,5,4], [2,0,3,5] ]
faces=[ [1,0,2], [3,4,5], [1,2,5,4], [0,3,5,2] , [0,1,4,3 ] ]
if (show_mount_plate == true) {
    translate([0,-side_b,0])
        rotate([0,0,-45])
            cube([mount_plate_thickness, size, size]);
jpmendes
View this message in context: http://forum.openscad.org/polyhedron-with-cube-not-valid-2-manifold-tp16132p16137.html
Hey Check this. Code: $fn = 180; size = 34; side_a = size * sin(45); side_b = size * cos(45); side_c = size * tan(45); tri_top_0 = [0,0,0]; tri_top_1 = [side_b,0,0]; tri_top_2 = [0,-side_a,0]; tri_bot_3 = [0,0,size]; tri_bot_4 = [side_b,0,size]; tri_bot_5 = [0,-side_a,size]; show_mount_plate = true; mount_plate_thickness = 5; union() { polyhedron( points=[ tri_top_0, tri_top_1, tri_top_2, tri_bot_3, tri_bot_4, tri_bot_5, ], // faces=[ [0,1,2], [3,4,5], [0,1,4,3], [1,2,5,4], [2,0,3,5] ] faces=[ [1,0,2], [3,4,5], [1,2,5,4], [0,3,5,2] , [0,1,4,3 ] ] ); if (show_mount_plate == true) { translate([0,-side_b,0]) rotate([0,0,-45]) cube([mount_plate_thickness, size, size]); } } jpmendes -- View this message in context: http://forum.openscad.org/polyhedron-with-cube-not-valid-2-manifold-tp16132p16137.html Sent from the OpenSCAD mailing list archive at Nabble.com.
D
dknell
Mon, Feb 15, 2016 1:26 AM
Thanks for the help jpmendes and peter!
I was just reading about the "Point ordering for faces" in  the manual
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Primitive_Solids#polyhedron
and it looks like my problem was with the order of points in the bottom
triangle going counter-clockwise instead of clockwise.
Thanks so much for the tips!
View this message in context: http://forum.openscad.org/polyhedron-with-cube-not-valid-2-manifold-tp16132p16138.html
Thanks for the help jpmendes and peter! I was just reading about the "Point ordering for faces" in the manual <https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Primitive_Solids#polyhedron> and it looks like my problem was with the order of points in the bottom triangle going counter-clockwise instead of clockwise. Thanks so much for the tips! -- View this message in context: http://forum.openscad.org/polyhedron-with-cube-not-valid-2-manifold-tp16132p16138.html Sent from the OpenSCAD mailing list archive at Nabble.com.
jpmendes
Mon, Feb 15, 2016 1:34 AM
Hey
In fact it is sufficient to change the order of the points of the bottom
triangle only:
faces=[ [1,0,2], [4,3,5], [0,1,4,3], [1,2,5,4], [2,0,3,5] ] );
Can anybody explain why?
Thanks
jpmendes
View this message in context: http://forum.openscad.org/polyhedron-with-cube-not-valid-2-manifold-tp16132p16139.html
Hey In fact it is sufficient to change the order of the points of the bottom triangle only: faces=[ [1,0,2], [4,3,5], [0,1,4,3], [1,2,5,4], [2,0,3,5] ] ); Can anybody explain why? Thanks jpmendes -- View this message in context: http://forum.openscad.org/polyhedron-with-cube-not-valid-2-manifold-tp16132p16139.html Sent from the OpenSCAD mailing list archive at Nabble.com.
D
dknell
Mon, Feb 15, 2016 1:39 AM
According to the documentation, “ When looking at the face from the outside inwards, the points must be clockwise”. I incorrectly oriented the bottom triangle by looking from the inside outward.
View this message in context: http://forum.openscad.org/polyhedron-with-cube-not-valid-2-manifold-tp16132p16140.html
According to the documentation, “ When looking at the face from the outside inwards, the points must be clockwise”. I incorrectly oriented the bottom triangle by looking from the inside outward. > On Feb 14, 2016, at 8:34 PM, jpmendes [via OpenSCAD] <ml-node+s1091067n16139h13@n5.nabble.com> wrote: > > Hey > > In fact it is sufficient to change the order of the points of the bottom triangle only: > > faces=[ [1,0,2], [4,3,5], [0,1,4,3], [1,2,5,4], [2,0,3,5] ] ); > > Can anybody explain why? > > Thanks > > jpmendes > > If you reply to this email, your message will be added to the discussion below: > http://forum.openscad.org/polyhedron-with-cube-not-valid-2-manifold-tp16132p16139.html <http://forum.openscad.org/polyhedron-with-cube-not-valid-2-manifold-tp16132p16139.html> > To unsubscribe from polyhedron with cube not valid 2-manifold, click here <http://forum.openscad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=16132&code=ZDR2MWRkQGdtYWlsLmNvbXwxNjEzMnwxOTcwMjIwODAw>. > NAML <http://forum.openscad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml> -- View this message in context: http://forum.openscad.org/polyhedron-with-cube-not-valid-2-manifold-tp16132p16140.html Sent from the OpenSCAD mailing list archive at Nabble.com.
jpmendes
Mon, Feb 15, 2016 1:55 AM
Ok, I read the manual.
However I can't understand why this have to be this way. I do not imagine me
spending a lot of time making a complex polyhedron from points and having to
care about the order of points for each face.
I think that the language should infer the correct order and rearrange the
points order internally if necessary to avoid crashing or the type of issues
above.
As a minimum, an error message should be echoed reporting the faces with
problems.
jpmendes
View this message in context: http://forum.openscad.org/polyhedron-with-cube-not-valid-2-manifold-tp16132p16141.html
Ok, I read the manual. However I can't understand why this have to be this way. I do not imagine me spending a lot of time making a complex polyhedron from points and having to care about the order of points for each face. I think that the language should infer the correct order and rearrange the points order internally if necessary to avoid crashing or the type of issues above. As a minimum, an error message should be echoed reporting the faces with problems. jpmendes -- View this message in context: http://forum.openscad.org/polyhedron-with-cube-not-valid-2-manifold-tp16132p16141.html Sent from the OpenSCAD mailing list archive at Nabble.com.
