Help modifying a file
D
drclong
Sat, May 15, 2021 8:18 AM
Hi All, I have downloaded a model from thingiverse in open scad format that I
want to modify. Unfortunately I only use fusion 360 and have no idea what I
am doing in OSC. I have attempted to contact the model maker so I could pay
him to do it to no avail. Would one of you kind people be ablt to do it for
me? Thanks in advance :-)
Hi All, I have downloaded a model from thingiverse in open scad format that I want to modify. Unfortunately I only use fusion 360 and have no idea what I am doing in OSC. I have attempted to contact the model maker so I could pay him to do it to no avail. Would one of you kind people be ablt to do it for me? Thanks in advance :-) -- Sent from: http://forum.openscad.org/
Michael Möller
Sat, May 15, 2021 8:35 AM
what is the thingiverse link and what is the change you need(25 words or
less ;-) )?
It might be trivial. If not, then you are wiser on perhaps another approach
Michael, fra mobilen
lør. 15. maj 2021 10.19 skrev drclong dr.christopher.long@gmail.com:
at Nabble.com.
what is the thingiverse link and what is the change you need(25 words or less ;-) )? It might be trivial. If not, then you are wiser on perhaps another approach Michael, fra mobilen lør. 15. maj 2021 10.19 skrev drclong <dr.christopher.long@gmail.com>: > Hi All, I have downloaded a model from thingiverse in open scad format > that I want to modify. Unfortunately I only use fusion 360 and have no idea > what I am doing in OSC. I have attempted to contact the model maker so I > could pay him to do it to no avail. Would one of you kind people be ablt to > do it for me? Thanks in advance :-) > ------------------------------ > Sent from the OpenSCAD mailing list archive <http://forum.openscad.org/> > at Nabble.com. > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
D
drclong
Sun, May 16, 2021 1:44 AM
Thankyou so much for the help.
OK. So I want  this https://www.thingiverse.com/thing:47025  (which has
perameters that can be altered simply in OSD and converted to .stl for
printing) to have a parameter added to do the following:
Looking along the length of the orthotic, I want to be able to add an angle
parameter to be able to tilt the foot up on the inside or up on the outside
of the foot. Like the image below. Does that make sense?
http://forum.openscad.org/file/t3162/Capture.png
Additionally, if possible, to look like the "Example_Left-Low-Heel.stl" in
this thing https://www.thingiverse.com/thing:1625633/files  .
Thanks very much.
Thankyou so much for the help. OK. So I want this <https://www.thingiverse.com/thing:47025> (which has perameters that can be altered simply in OSD and converted to .stl for printing) to have a parameter added to do the following: Looking along the length of the orthotic, I want to be able to add an angle parameter to be able to tilt the foot up on the inside or up on the outside of the foot. Like the image below. Does that make sense? <http://forum.openscad.org/file/t3162/Capture.png> Additionally, if possible, to look like the "Example_Left-Low-Heel.stl" in this thing <https://www.thingiverse.com/thing:1625633/files> . Thanks very much. -- Sent from: http://forum.openscad.org/
Sun, May 16, 2021 2:16 AM
To paraphrase, as the thing has a flat bottom you want the equivalent of an adjustable wedge on the
bottom.
Re 'look like the "Example_Left-Low-Heel.stl" ' you need to be a bit more specific than 'look'.
From: drclong [mailto:dr.christopher.long@gmail.com]
Sent: Sun, 16 May 2021 11:44
Subject: [OpenSCAD] Re: Help modifying a file
OK. So I want this https://www.thingiverse.com/thing:47025  (which has perameters that can be
following:
make sense?
Thanks very much.
Sent from the OpenSCAD mailing http://forum.openscad.org/  list archive at Nabble.com.
To paraphrase, as the thing has a flat bottom you want the equivalent of an adjustable wedge on the bottom. Re 'look like the "Example_Left-Low-Heel.stl" ' you need to be a bit more specific than 'look'. _____ From: drclong [mailto:dr.christopher.long@gmail.com] Sent: Sun, 16 May 2021 11:44 To: discuss@lists.openscad.org Subject: [OpenSCAD] Re: Help modifying a file Thankyou so much for the help. OK. So I want this <https://www.thingiverse.com/thing:47025> (which has perameters that can be altered simply in OSD and converted to .stl for printing) to have a parameter added to do the following: Looking along the length of the orthotic, I want to be able to add an angle parameter to be able to tilt the foot up on the inside or up on the outside of the foot. Like the image below. Does that make sense? <http://forum.openscad.org/file/t3162/Capture.png> Additionally, if possible, to look like the "Example_Left-Low-Heel.stl" in this thing <https://www.thingiverse.com/thing:1625633/files> . Thanks very much. _____ Sent from the OpenSCAD mailing <http://forum.openscad.org/> list archive at Nabble.com. -- This email has been checked for viruses by AVG. https://www.avg.com
D
drclong
Mon, May 17, 2021 12:36 AM
Adjustable wedge is correct. I would love to be able to just set each of the
parameters including the angle of the wedge.
Sorry that was very vague. I would like it to be a full foot orthotic like
the example I linked to, with the parameters of the adjustable wedge
tapering the wedge to 0 deg about 2/3rds the way towards the toe end of the
orthotic.
Adjustable wedge is correct. I would love to be able to just set each of the parameters including the angle of the wedge. Sorry that was very vague. I would like it to be a full foot orthotic like the example I linked to, with the parameters of the adjustable wedge tapering the wedge to 0 deg about 2/3rds the way towards the toe end of the orthotic. -- Sent from: http://forum.openscad.org/
Mon, May 17, 2021 1:45 PM
OK, got a prototype of the wedge bit, I'll refine it in a while.
Sorry, the second part is so full of assumptions that I'm sure any decent Cordwainer could do it
with their eyes closed. That is before the question of fashion in footwear is to be considered,
where did that Jester get to?
Also the example thing is copyright, Licensed as Non Commercial, so I'm not going to attempt to
incorporate it.
If you would like me to make the toe-end some oversized generic shape that you could manually trim,
like those inserts you buy from the chemist let me know.
Sent: Mon, 17 May 2021 10:36
OK, got a prototype of the wedge bit, I'll refine it in a while. Sorry, the second part is so full of assumptions that I'm sure any decent Cordwainer could do it with their eyes closed. That is before the question of fashion in footwear is to be considered, where did that Jester get to? Also the example thing is copyright, Licensed as Non Commercial, so I'm not going to attempt to incorporate it. If you would like me to make the toe-end some oversized generic shape that you could manually trim, like those inserts you buy from the chemist let me know. _____ From: drclong [mailto:dr.christopher.long@gmail.com] Sent: Mon, 17 May 2021 10:36 To: discuss@lists.openscad.org Subject: [OpenSCAD] Re: Help modifying a file Adjustable wedge is correct. I would love to be able to just set each of the parameters including the angle of the wedge. Sorry that was very vague. I would like it to be a full foot orthotic like the example I linked to, with the parameters of the adjustable wedge tapering the wedge to 0 deg about 2/3rds the way towards the toe end of the orthotic. _____ Sent from the OpenSCAD mailing <http://forum.openscad.org/> list archive at Nabble.com. -- This email has been checked for viruses by AVG. https://www.avg.com
Mon, May 17, 2021 2:19 PM
Chris,
BTW, I didn't pick up on your original post, the bit "to contact the model maker so I could pay
him".
I do this stuff for the intellectual exercise, so I'll happily contribute my wedge bit when it's
done.
If someone else wants to propose taking a commission on design of the "I would like it to be a full
foot orthotic like the example" with the bother of working out how big a foot is and does it last,
please speak up.
Chris, this Forum is not typically use for design commissions, but you never know your luck.
Sent: Mon, 17 May 2021 23:46
incorporate it.
tent=emailclient>
Virus-free.
tent=emailclient> www.avg.com
Chris, BTW, I didn't pick up on your original post, the bit "to contact the model maker so I could pay him". I do this stuff for the intellectual exercise, so I'll happily contribute my wedge bit when it's done. If someone else wants to propose taking a commission on design of the "I would like it to be a full foot orthotic like the example" with the bother of working out how big a foot is and does it last, please speak up. Chris, this Forum is not typically use for design commissions, but you never know your luck. _____ From: MichaelAtOz [mailto:oz.at.michael@gmail.com] Sent: Mon, 17 May 2021 23:46 To: 'OpenSCAD general discussion' Subject: [OpenSCAD] Re: Help modifying a file OK, got a prototype of the wedge bit, I'll refine it in a while. Sorry, the second part is so full of assumptions that I'm sure any decent Cordwainer could do it with their eyes closed. That is before the question of fashion in footwear is to be considered, where did that Jester get to? Also the example thing is copyright, Licensed as Non Commercial, so I'm not going to attempt to incorporate it. If you would like me to make the toe-end some oversized generic shape that you could manually trim, like those inserts you buy from the chemist let me know. _____ From: drclong [mailto:dr.christopher.long@gmail.com] Sent: Mon, 17 May 2021 10:36 To: discuss@lists.openscad.org Subject: [OpenSCAD] Re: Help modifying a file Adjustable wedge is correct. I would love to be able to just set each of the parameters including the angle of the wedge. Sorry that was very vague. I would like it to be a full foot orthotic like the example I linked to, with the parameters of the adjustable wedge tapering the wedge to 0 deg about 2/3rds the way towards the toe end of the orthotic. _____ Sent from the OpenSCAD mailing <http://forum.openscad.org/> list archive at Nabble.com. <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_con tent=emailclient> Virus-free. <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_con tent=emailclient> www.avg.com -- This email has been checked for viruses by AVG. https://www.avg.com
CL
Chris Long
Wed, May 19, 2021 8:11 AM
Hi Michael,
Yes I tried to message him to see if he would do the work. I can "tip him"
but I would rather get in touch with him. Even tried google searching all
the information I could gleen from the profile to no avail.
The full foot thing is not overly important but would be nice. Tapering the
wedge down to the base of the toes (ie the front end of the "short original
model) might be difficult. But like I said, I have no idea on OSC
I appreciate your efforts.
Kind regards,
Christopher Long
mob: +61 417 530 116
On Tue, 18 May 2021 at 00:19, MichaelAtOz oz.at.michael@gmail.com wrote:
Chris,
know.
orthotic.
at Nabble.com.
Virus-free. www.avg.com
<#m_236002379642643423_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
Hi Michael, Yes I tried to message him to see if he would do the work. I can "tip him" but I would rather get in touch with him. Even tried google searching all the information I could gleen from the profile to no avail. The full foot thing is not overly important but would be nice. Tapering the wedge down to the base of the toes (ie the front end of the "short original model) might be difficult. But like I said, I have no idea on OSC I appreciate your efforts. Kind regards, Christopher Long mob: +61 417 530 116 On Tue, 18 May 2021 at 00:19, MichaelAtOz <oz.at.michael@gmail.com> wrote: > Chris, > > > > BTW, I didn't pick up on your original post, the bit "to contact the > model maker so I could pay him". > > > > I do this stuff for the intellectual exercise, so I'll happily contribute > my wedge bit when it's done. > > > > If someone else wants to propose taking a commission on design of the "I > would like it to be a full foot orthotic like the example" with the > bother of working out how big a foot is and does it last, please speak up. > > > > Chris, this Forum is not typically use for design commissions, but you > never know your luck. > > > ------------------------------ > > *From:* MichaelAtOz [mailto:oz.at.michael@gmail.com] > *Sent:* Mon, 17 May 2021 23:46 > *To:* 'OpenSCAD general discussion' > *Subject:* [OpenSCAD] Re: Help modifying a file > > > > OK, got a prototype of the wedge bit, I'll refine it in a while. > > > > Sorry, the second part is so full of assumptions that I'm sure any decent > Cordwainer could do it with their eyes closed. That is before the question > of fashion in footwear is to be considered, where did that Jester get to? > > > > Also the example thing is copyright, Licensed as Non Commercial, so I'm > not going to attempt to incorporate it. > > > > If you would like me to make the toe-end some oversized generic shape that > you could manually trim, like those inserts you buy from the chemist let me > know. > > > ------------------------------ > > *From:* drclong [mailto:dr.christopher.long@gmail.com] > *Sent:* Mon, 17 May 2021 10:36 > *To:* discuss@lists.openscad.org > *Subject:* [OpenSCAD] Re: Help modifying a file > > > > Adjustable wedge is correct. I would love to be able to just set each of > the parameters including the angle of the wedge. > > Sorry that was very vague. I would like it to be a full foot orthotic like > the example I linked to, with the parameters of the adjustable wedge > tapering the wedge to 0 deg about 2/3rds the way towards the toe end of the > orthotic. > ------------------------------ > > Sent from the OpenSCAD mailing list archive <http://forum.openscad.org/> > at Nabble.com. > > > > > <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient> > > Virus-free. www.avg.com > <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient> > > <#m_236002379642643423_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
CL
Chris Long
Tue, Jun 22, 2021 7:27 AM
Hi Michael,
How did you get on with this project?
Kind regards,
Christopher Long
Chris,
know.
orthotic.
at Nabble.com.
<#m_-966593880356355860_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
Hi Michael, How did you get on with this project? Kind regards, Christopher Long mob: +61 417 530 116 On Tue, 18 May 2021 at 00:19, MichaelAtOz <oz.at.michael@gmail.com> wrote: > Chris, > > > > BTW, I didn't pick up on your original post, the bit "to contact the > model maker so I could pay him". > > > > I do this stuff for the intellectual exercise, so I'll happily contribute > my wedge bit when it's done. > > > > If someone else wants to propose taking a commission on design of the "I > would like it to be a full foot orthotic like the example" with the > bother of working out how big a foot is and does it last, please speak up. > > > > Chris, this Forum is not typically use for design commissions, but you > never know your luck. > > > ------------------------------ > > *From:* MichaelAtOz [mailto:oz.at.michael@gmail.com] > *Sent:* Mon, 17 May 2021 23:46 > *To:* 'OpenSCAD general discussion' > *Subject:* [OpenSCAD] Re: Help modifying a file > > > > OK, got a prototype of the wedge bit, I'll refine it in a while. > > > > Sorry, the second part is so full of assumptions that I'm sure any decent > Cordwainer could do it with their eyes closed. That is before the question > of fashion in footwear is to be considered, where did that Jester get to? > > > > Also the example thing is copyright, Licensed as Non Commercial, so I'm > not going to attempt to incorporate it. > > > > If you would like me to make the toe-end some oversized generic shape that > you could manually trim, like those inserts you buy from the chemist let me > know. > > > ------------------------------ > > *From:* drclong [mailto:dr.christopher.long@gmail.com] > *Sent:* Mon, 17 May 2021 10:36 > *To:* discuss@lists.openscad.org > *Subject:* [OpenSCAD] Re: Help modifying a file > > > > Adjustable wedge is correct. I would love to be able to just set each of > the parameters including the angle of the wedge. > > Sorry that was very vague. I would like it to be a full foot orthotic like > the example I linked to, with the parameters of the adjustable wedge > tapering the wedge to 0 deg about 2/3rds the way towards the toe end of the > orthotic. > ------------------------------ > > Sent from the OpenSCAD mailing list archive <http://forum.openscad.org/> > at Nabble.com. > > > > > <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient> > > Virus-free. www.avg.com > <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient> > > <#m_-966593880356355860_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
Tue, Jun 22, 2021 7:38 AM
Sorry Chris, but it is on the backburner for now, I've got a family crisis ATM.
From: Chris Long [mailto:dr.christopher.long@gmail.com]
Sent: Tue, 22 Jun 2021 17:27
Hi Michael,
Kind regards,
Christopher Long
Chris,
Sent from the OpenSCAD mailing list archive http://forum.openscad.org/  at Nabble.com.
Virus-free.  http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient www.avg.com
Sorry Chris, but it is on the backburner for now, I've got a family crisis ATM. _____ From: Chris Long [mailto:dr.christopher.long@gmail.com] Sent: Tue, 22 Jun 2021 17:27 To: OpenSCAD general discussion Subject: [OpenSCAD] Re: Help modifying a file Hi Michael, How did you get on with this project? Kind regards, Christopher Long mob: +61 417 530 116 On Tue, 18 May 2021 at 00:19, MichaelAtOz <oz.at.michael@gmail.com> wrote: Chris, BTW, I didn't pick up on your original post, the bit "to contact the model maker so I could pay him". I do this stuff for the intellectual exercise, so I'll happily contribute my wedge bit when it's done. If someone else wants to propose taking a commission on design of the "I would like it to be a full foot orthotic like the example" with the bother of working out how big a foot is and does it last, please speak up. Chris, this Forum is not typically use for design commissions, but you never know your luck. _____ From: MichaelAtOz [mailto:oz.at.michael@gmail.com] Sent: Mon, 17 May 2021 23:46 To: 'OpenSCAD general discussion' Subject: [OpenSCAD] Re: Help modifying a file OK, got a prototype of the wedge bit, I'll refine it in a while. Sorry, the second part is so full of assumptions that I'm sure any decent Cordwainer could do it with their eyes closed. That is before the question of fashion in footwear is to be considered, where did that Jester get to? Also the example thing is copyright, Licensed as Non Commercial, so I'm not going to attempt to incorporate it. If you would like me to make the toe-end some oversized generic shape that you could manually trim, like those inserts you buy from the chemist let me know. _____ From: drclong [mailto:dr.christopher.long@gmail.com] Sent: Mon, 17 May 2021 10:36 To: discuss@lists.openscad.org Subject: [OpenSCAD] Re: Help modifying a file Adjustable wedge is correct. I would love to be able to just set each of the parameters including the angle of the wedge. Sorry that was very vague. I would like it to be a full foot orthotic like the example I linked to, with the parameters of the adjustable wedge tapering the wedge to 0 deg about 2/3rds the way towards the toe end of the orthotic. _____ Sent from the OpenSCAD mailing list archive <http://forum.openscad.org/> at Nabble.com. <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient> Virus-free. <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient> www.avg.com _______________________________________________ OpenSCAD mailing list To unsubscribe send an email to discuss-leave@lists.openscad.org -- This email has been checked for viruses by AVG. https://www.avg.com
