How can I get the split screen orientation back to vertical?
Due to some odd event involved in opening a different file gedit and
openscad editor (screen went black, etc.) I ended up with openscad
having all the split screens (editor and console) horizontal, rather
than the original vertical orientation.
I ran an earlier version openscad and it gave the same result, so that
suggests that the problem is some configuration file, someplace. OS is
Ubuntu 16.04 LTS.
Grab the grey section next to 'editor' & 'console' (the pane titles), drag
them around.
Thanks.
After much experimenting I finally got it back to the original
layout. One has to grab the pane and move it to the left until a grey
vertical pane appears and drop it, otherwise it simply snaps back.
Don
drag
them around.
Admin - PM me if you need anything, or if I've done something
stupid...
