You want a higher $fn on that corner, ie round(2,$fn=16)
Sent: Thu, 29 Jul 2021 18:30
Subject: [OpenSCAD] Re: How best to apply offset on 2D square?
Thanks Ray, that should prove handy. Heading out so yet to study
it properly. But something odd about one of the corners that's
more obvious when viewed from the top. Attached or here:
https://www.dropbox.com/s/q18jwxjvs2r6y15/Rounding-Ray-1.jpg?raw=1
Presumably dependent on $fn?
I'm surprised there's no OpenSCAD command that emulates scissors,
or Tipp-Ex, or pasting a bit of white paper over your mistakes. It
would just make a quadrant of specified radius and let you move
(translate) it to a precise position. That's what I intuitively
wanted to do with my square corners ;-)
Terry
On Thu, 29 Jul 2021 00:52:48 +0100, you wrote:
If I want to round off square corners I do this (or a 3d version.)
//corner rounder
module round(r){
square(r*2,true);
translate([r,r]) circle(r);
translate([-r,r]) circle(r);
translate([r,-r]) circle(r);
translate([-r,-r]) circle(r);
//example to round a couple of corners of a 30 by 20 rectangle
square([30,20]);
translate([30,20]) round(6);
translate ([0,20]) round(2);
On 28/07/2021 16:43, Terry wrote:
Decades ago I bought plastic rain guttering as one of many sources
for making electronics project cases.
Attached or here:
https://www.dropbox.com/s/itbg6n7mh58d2fe/Guttering.jpg?raw=1
I've got some guttering left but no end caps (which are no longer
available). To 3D print a simple push-on replacement my first
approach is to linearly extrude the difference between two
rectangles to make the push-on 'lip'. (I'll then add a 2mm thick
cube for the back.) But I find it hard going using offset,
difference and translate on squares to see exactly what's
happening to the dimensions. I'm about to try 'center = true' on
the squares to see if that helps.
Attached or here:
https://www.dropbox.com/s/lmtrwvtct0aclia/OffsetChangesThickness.jpg?raw=1
Specifically, after adding offset (r=3) to get the corners
rounded, thickness is also increased by 3mm and I'm not clear how
to avoid that? Is it possible for offset to add rounding without
changing the other dimensions?
Or should I go straight to 3D and use hull or minkowski? Or some
other method?
Terry
Yes, you need a $fn = or similar. Also, for the 3d version you'll maybe
get a bit of z fighting, so make the cube a bit bigger, or cylinder a
bit smaller. (I rarely am able to give the fish, maybe I may not even be
able to say where to buy the rod.) The same 'round module' can radius
inside corners, too.
Terry
//corner rounder
module round(r){
square(r*2,true);
square([30,20]);
Attached or here:
Attached or here:
other method?
Terry
The simplest way is to offset a square inwards by the radius and and then
outwards by the radius, making sure $fn is a multiple of four. See
https://github.com/nophead/NopSCADlib/blob/master/utils/core/rounded_rectangle.scad#L23
If you want each corner a different radius then hull four circles offset
inwards by their radius. See
https://github.com/nophead/NopSCADlib/blob/master/vitamins/sheet.scad#L47.
There I hull four corners that can be square, rounded or chamfered.
get a bit of z fighting, so make the cube a bit bigger, or cylinder a bit
smaller. (I rarely am able to give the fish, maybe I may not even be able
to say where to buy the rod.) The same 'round module' can radius inside
corners, too.
more obvious when viewed from the top. Attached or here:https://www.dropbox.com/s/q18jwxjvs2r6y15/Rounding-Ray-1.jpg?raw=1
Terry
//corner rounder
module round(r){
square(r*2,true);
square([30,20]);
Attached or here:https://www.dropbox.com/s/itbg6n7mh58d2fe/Guttering.jpg?raw=1
Attached or here:
other method?
Terry
