Nightly 2024.12.21 on Windows 10 gives me an error message when
rendering the following code
x = -15;
$fn = 60;
minkowski() {
scale([1, 1, x]) roof() hull() {
circle(d = 15);
translate([0, 6]) circle(d = 6);
sphere(d = 0.06);
The message produced is
WARNING: [manifold] Minkowski failed with error, falling back to Nef
operation: CGAL ERROR: assertion violation!
Expr: e->incident_sface() != SFace_const_handle()
File:
/mxe/usr/x86_64-w64-mingw32.static.posix/include/CGAL/Nef_S2/SM_const_decorator.h
Line: 329
CGAL_Nef_Polyhedron.
I can circumvent the problem by using x = +15 and inverting the
resulting shape by adding "scale([1,1,-1])" just before the minkowski.
The issue can also be removed by reducing the value of $fn to 28 or less.
Although I can avoid the issue, I'd be interested to hear an explanation
of the cause - in particular why it works okay for x = +15 but not x =
-15 (to me, it's just symmetry so sign inversion should not make a
difference.)
Cheers,
Steve
Does this only fail when using roof(), or are you able to reproduce similar behavior also without roof()?
-Markus
On Dec 23, 2024, at 10:48, Steve Lelievre via Discuss discuss@lists.openscad.org wrote:
Nightly 2024.12.21 on Windows 10 gives me an error message when rendering the following code
x = -15;
$fn = 60;
minkowski() {
circle(d = 15);
sphere(d = 0.06);
WARNING: [manifold] Minkowski failed with error, falling back to Nef operation: CGAL ERROR: assertion violation!
File: /mxe/usr/x86_64-w64-mingw32.static.posix/include/CGAL/Nef_S2/SM_const_decorator.h
Line: 329
ERROR: The given mesh is not closed! Unable to convert to CGAL_Nef_Polyhedron.
I can circumvent the problem by using x = +15 and inverting the resulting shape by adding "scale([1,1,-1])" just before the minkowski. The issue can also be removed by reducing the value of $fn to 28 or less.
Although I can avoid the issue, I'd be interested to hear an explanation of the cause - in particular why it works okay for x = +15 but not x = -15 (to me, it's just symmetry so sign inversion should not make a difference.)
Cheers,
Steve
Further testing shows that my problem happens only when I use roof to
define the initial 3D shape, and that it works just fine with roof
method 'straight'. As well, I found a simpler failing case (no hull):
minkowski() {
scale([1, 1, -15]) roof() circle(d = 15, $fn = 60);
sphere(d = 1);
The problem can be made to go away by choosing other values for the z
scaling, the circle diameter, or the circle facet number.
Steve
-Markus
x = -15;
$fn = 60;
minkowski() {
circle(d = 15);
sphere(d = 0.06);
Line: 329
Cheers,
Steve
Thanks for confirming. This could be a bug in roof(); roof is still very experimental and have some rough corners.
Could you open an issue on https://github.com/openscad/openscad/issues and include your minimal example?
On Dec 23, 2024, at 15:45, Steve Lelievre via Discuss discuss@lists.openscad.org wrote:
Further testing shows that my problem happens only when I use roof to define the initial 3D shape, and that it works just fine with roof method 'straight'. As well, I found a simpler failing case (no hull):
minkowski() {
sphere(d = 1);
The problem can be made to go away by choosing other values for the z scaling, the circle diameter, or the circle facet number.
Steve
-Markus
x = -15;
$fn = 60;
minkowski() {
circle(d = 15);
sphere(d = 0.06);
Line: 329
Cheers,
Steve
https://www.gnomoni.ca
https://www.youtube.com/@gnomonica
Will do.
Thanks for your hard work.
Steve
example?
This smells like roof is creating wrong oriented faces ...
On Mon, Dec 23, 2024 at 9:46 PM Steve Lelievre via Discuss <
minkowski() {
sphere(d = 1);
Steve
-Markus
On Dec 23, 2024, at 10:48, Steve Lelievre via Discuss <
x = -15;
$fn = 60;
minkowski() {
circle(d = 15);
sphere(d = 0.06);
File:
Line: 329
difference.)
Cheers,
Steve
Issue #5528
example?
minkowski() {
sphere(d = 1);
Steve
-Markus
x = -15;
$fn = 60;
minkowski() {
circle(d = 15);
sphere(d = 0.06);
File:
Line: 329
$fn to 28 or less.
Cheers,
Steve
