BR
Bob Roos
Mon, Apr 24, 2023 1:14 PM
Hello OpenSCAD,
module Tags(type,holes){
if (type==1) {
Base = 1;
Text = 0;
echo(concat("type=1, Text=",Text));
else {
Base = 0;
Text = 1;
echo(concat("type=0, Text=",Text));
Hole = holes;
echo(Text);
Tags(1,0);
Tags(0,1);
Best regards,
Bob mailto:roosbob@wybatap.com
Hello OpenSCAD,
if (type==1) {
Base = 1;
Text = 0;
else {
Base = 0;
Text = 1;
Hole = holes;
echo(Text);
Tags(1,0);
Tags(0,1);
Best regards,
WH
Will Hardiman
Mon, Apr 24, 2023 1:25 PM
Probably because your module definition does not include it. Try
module Tags(type, holes, Text){
... (same code as before)
Tags(1,0,"Hello World");
You also probably want to change the echo line because it doesn't output
the whole echo onto a single line. But I don't know how to fix it.
Cheers,
Will
On Mon, 24 Apr 2023 at 14:15, Bob Roos roosbob@wybatap.com wrote:
Hello OpenSCAD,
if (type==1) {
Base = 1;
Text = 0;
else {
Base = 0;
Text = 1;
Hole = holes;
echo(Text);
Tags(1,0);
Tags(0,1);
Best regards,
Cheers,
Will
On Mon, 24 Apr 2023 at 14:15, Bob Roos <roosbob@wybatap.com> wrote:
> Hello OpenSCAD,
> if (type==1) {
> Base = 1;
> Text = 0;
> else {
> Base = 0;
> Text = 1;
> Hole = holes;
> echo(Text);
> Tags(1,0);
> Tags(0,1);
> Best regards,
Mon, Apr 24, 2023 1:41 PM
As I understand it, the definitions of Text are bounded by the {} that
contain them.
Variables are only defined within the {} that contain them.
On Mon, Apr 24, 2023 at 8:15 AM Bob Roos roosbob@wybatap.com wrote:
Hello OpenSCAD,
if (type==1) {
Base = 1;
Text = 0;
else {
Base = 0;
Text = 1;
Hole = holes;
echo(Text);
Tags(1,0);
Tags(0,1);
Best regards,
contain them.
On Mon, Apr 24, 2023 at 8:15 AM Bob Roos <roosbob@wybatap.com> wrote:
> Hello OpenSCAD,
> if (type==1) {
> Base = 1;
> Text = 0;
> else {
> Base = 0;
> Text = 1;
> Hole = holes;
> echo(Text);
> Tags(1,0);
> Tags(0,1);
> Best regards,
Mon, Apr 24, 2023 1:48 PM
I think that you could do this:
Base = (type==1)? 1 : 0;
Text = (type==1)? 0 : 1;
echo("type=",type,"Text=",Text);
Hole = holes;
echo(Text);
On Mon, Apr 24, 2023 at 8:41 AM Leonard Martin Struttmann <
contain them.
Hello OpenSCAD,
if (type==1) {
Base = 1;
Text = 0;
else {
Base = 0;
Text = 1;
Hole = holes;
echo(Text);
Tags(1,0);
Tags(0,1);
Best regards,
Hole = holes;
echo(Text);
> contain them.
>> Hello OpenSCAD,
>> if (type==1) {
>> Base = 1;
>> Text = 0;
>> else {
>> Base = 0;
>> Text = 1;
>> Hole = holes;
>> echo(Text);
>> Tags(1,0);
>> Tags(0,1);
>> Best regards,
Mon, Apr 24, 2023 1:53 PM
This doesn't work in openscad. The scope of the "Base" variable I've
tagged with "(*)" is the three lines of its block inside the if.
There is a second Base variable that also has three lines of scope, but
three different lines.
You meant:
module Tags (type, holes)
Base = type?1:0;
Text = type?0:1;
(I've made this mistake less than 2 weeks ago, so it is still fresh).
On Mon, Apr 24, 2023 at 09:14:33AM -0400, Bob Roos wrote:
Hello OpenSCAD,
if (type==1) {
Base = 1; (*)
Text = 0;
else {
Base = 0;
Text = 1;
Hole = holes;
echo(Text);
Tags(1,0);
Tags(0,1);
Best regards,
You meant:
Base = type?1:0;
Text = type?0:1;
> Hello OpenSCAD,
> if (type==1) {
> Base = 1; (*)
> Text = 0;
> else {
> Base = 0;
> Text = 1;
> Hole = holes;
> echo(Text);
> Tags(1,0);
> Tags(0,1);
> Best regards,
BR
Bob Roos
Mon, Apr 24, 2023 2:49 PM
Hi Rogier,
Yes, that is exactly what I meant to do. :) I did not know about that form of testing a boolean.
Thank you
You meant:
Base = type?1:0;
Text = type?0:1;
Hello OpenSCAD,
if (type==1) {
Base = 1; (*)
Text = 0;
else {
Base = 0;
Text = 1;
Hole = holes;
echo(Text);
Tags(1,0);
Tags(0,1);
Best regards,
Hi Rogier,
Thank you
> You meant:
> Base = type?1:0;
> Text = type?0:1;
> Roger.
>> Hello OpenSCAD,
>> if (type==1) {
>> Base = 1; (*)
>> Text = 0;
>> else {
>> Base = 0;
>> Text = 1;
>> Hole = holes;
>> echo(Text);
>> Tags(1,0);
>> Tags(0,1);
>> Best regards,
have Fun,
