Is there any library which has a 3D version of offset(), or is one planned to
appear eventually in OpenSCAD?
It would help me a lot, offset is great for creating soft, almost organic
shapes, rounding corners and smoothing transitions between parts, and I
really use it a lot in 2D. It would be amazing if I could use it in 3D as
well.
Minkowski() helps a bit, but only with outside corners, it doesn't smooth
inside corners, and it's extremely slow, so one has to be very careful about
how one use it.
Suggestions?
I have one here: https://github.com/nophead/NopSCADlib#Round but it is
geologically slow for anything complex because it uses 3 minkowskis.
to
well.
about
how one use it.
Suggestions?
And here: https://github.com/nophead/NopSCADlib#Offset
planned to
well.
about
how one use it.
Suggestions?
I wrote an offset_sweep that makes a polyhedron from a stack of offsets of a
2d shape (with the offset varying along the extrusion). I find this really
useful for making shapes with rounded inner corners, and rounded edges, but
it doesn't have the full generality you can get from doing offset in 3d.
You can, of course, round interior corners with minkowski by differencing
your part from a cube first. But it's going to be glacial. (Or OpenSCAD
may crash.)
This wiki shows examples of some ways you can use it if you scroll past the
documentation.
https://github.com/revarbat/BOSL2/wiki/rounding.scad#offset_sweep
Of course, this approach assumes you have a point list, not 2d geometry.
There is a version of this that works on geometry---but only if the geometry
is convex, because it uses hulls of pairs of offsets to form layers that are
unioned together. (It may also be slow with lots of layers due to so many
unions.)
Recently I discovered that somebody is working on something like my
offset_sweep to appear in OpenSCAD. I'm not sure what the status of that
is---whether it's actually about to appear or whether it's going to sit in a
branch for ever.
to
well.
about
how one use it.
Suggestions?
Discuss@.openscad
The BOSL2 library has a round3d() module, but I’m reasonably certain it’s using an algorithm nearly the same as nophead has. Painfully slow.
-Revar
may crash.)
documentation.
unions.)
branch for ever.
to
well.
about
how one use it.
Suggestions?
Discuss@.openscad
