Re: [OpenSCAD] Severe lag when rotating model in viewing area
mmccool
Thu, Dec 22, 2016 7:41 AM
I don't think this is an Intel graphics issue; it is just worse under lower
performing graphics cards (eg in laptops, or systems with only processor
graphics).  I have an NVIDIA GPU in my laptop and see the same problem
(although I have a fairly high-end laptop).  If you test with a fast desktop
GPU or a simple model it may not show up.  The model I am using also has a
lot of CSG operations (which in preview mode involve multiple passes to
render...).
I think what is happening is that the queue of commands to change the view
generated when dragging the mouse is growing faster than the graphics system
can render.  Then even after the mouse is released, the queue drains only
as fast as the system can render.  Note the problem also occurs with
panning, not just rotation (and panning is even more annoying as the model
drifts out of view and you have to hunt around, carefully because of the
lag, to bring it back).
With this issue the system is only barely usable as you have to reposition
the model with very short "bursts".  Also, this is not a pure performance
issue: I have used exactly the same model and the same GPU to work with
models under OpenSCAD in the past with no problem.
This is, simply put, a recently introduced user interface bug.  What the
system should do is "jump" to the last movement command given in the queue
each time it does a render, flushing the event/command queue of any pending
requests, to keep it from growing uncontrollably.
View this message in context: http://forum.openscad.org/Severe-lag-when-rotating-model-in-viewing-area-tp18679p19681.html
I don't think this is an Intel graphics issue; it is just worse under lower performing graphics cards (eg in laptops, or systems with only processor graphics). I have an NVIDIA GPU in my laptop and see the same problem (although I have a fairly high-end laptop). If you test with a fast desktop GPU or a simple model it may not show up. The model I am using also has a lot of CSG operations (which in preview mode involve multiple passes to render...). I think what is happening is that the queue of commands to change the view generated when dragging the mouse is growing faster than the graphics system can render. Then even after the mouse is released, the queue drains only as fast as the system can render. Note the problem also occurs with panning, not just rotation (and panning is even more annoying as the model drifts out of view and you have to hunt around, carefully because of the lag, to bring it back). With this issue the system is only barely usable as you have to reposition the model with very short "bursts". Also, this is not a pure performance issue: I have used exactly the same model and the same GPU to work with models under OpenSCAD in the past with no problem. This is, simply put, a recently introduced user interface bug. What the system should do is "jump" to the last movement command given in the queue each time it does a render, flushing the event/command queue of any pending requests, to keep it from growing uncontrollably. -- View this message in context: http://forum.openscad.org/Severe-lag-when-rotating-model-in-viewing-area-tp18679p19681.html Sent from the OpenSCAD mailing list archive at Nabble.com.
mmccool
Thu, Dec 22, 2016 7:43 AM
I should mention I'm using version 2015.03-1.  I'll try upgrading to a more
recent development version to see if the issue has been resolved.
View this message in context: http://forum.openscad.org/Severe-lag-when-rotating-model-in-viewing-area-tp18679p19682.html
I should mention I'm using version 2015.03-1. I'll try upgrading to a more recent development version to see if the issue has been resolved. -- View this message in context: http://forum.openscad.org/Severe-lag-when-rotating-model-in-viewing-area-tp18679p19682.html Sent from the OpenSCAD mailing list archive at Nabble.com.
mmccool
Thu, Dec 22, 2016 7:59 AM
I upgraded to 2015.03-2 (from the ppa) and the problem is gone.
Unfortunately this version also fails to work with Intel graphics (which I
also have on my Skylake laptop) under Ubuntu 16.04.  I tried
openscad-nightly as well.  The problem is (still) fixed there, but that
version also does not load properly with Intel graphics (it gets farther
along, but fails to find certain OpenGL extensions).
View this message in context: http://forum.openscad.org/Severe-lag-when-rotating-model-in-viewing-area-tp18679p19683.html
I upgraded to 2015.03-2 (from the ppa) and the problem is gone. Unfortunately this version also fails to work with Intel graphics (which I also have on my Skylake laptop) under Ubuntu 16.04. I tried openscad-nightly as well. The problem is (still) fixed there, but that version also does not load properly with Intel graphics (it gets farther along, but fails to find certain OpenGL extensions). -- View this message in context: http://forum.openscad.org/Severe-lag-when-rotating-model-in-viewing-area-tp18679p19683.html Sent from the OpenSCAD mailing list archive at Nabble.com.
