I am plying in my sandbox, trying to add a polygon example without a hole to
the user manual.
It works fine in OpenSCAD, but whenI try to show it with WikiBooks I run
into a problem.
when I try to show:
polygon(points=[[0,0],[100,0],[130,50],[30,50]], paths=[[0,1,2,3]]);
the result is this:
polygon(points=[[0,0],[100,0],[130,50],[30,50]], paths=0,1,2,3);
The following all display what is specified:
a=[[0,0],[100,0],[130,50],[30,50]];
b=[[0,1,2,3],[]];
b=[0,1,2,3];
but this, which is the correct syntax:
b=[[0,1,2,3]];
shows this:
b=0,1,2,3;
where the brackets are removed and the numbers highlighted in red.
View this message in context: http://forum.openscad.org/showing-vector-within-vector-in-user-manual-tp13885.html
b=[[0,1,2,3]];
shows this:
b=0,1,2,3;
That's because [[ is wiki markup.
Looking at https://www.mediawiki.org/wiki/Help:Formatting the following
might work:
<nowiki>b=[[0,1,2,3]];</nowiki>
The wiki also uses the following construct;
<source lang="javascript"> // generate a list with all values defined by a range list1 = [ for (i = [0 : 2 : 10]) i ]; echo(list1); // ECHO: [0, 2, 4, 6, 8, 10] </source>Newly minted Admin - PM me if you need anything, or if I've done something stupid...
View this message in context: http://forum.openscad.org/showing-vector-within-vector-in-user-manual-tp13885p13892.html
<nowiki>b=[[0,1,2,3]];</nowiki> does the job. tnx
View this message in context: http://forum.openscad.org/showing-vector-within-vector-in-user-manual-tp13885p13896.html
