Is there a way to map <F7> from exporting STL(binary) to SVG?
John David
Sat, Jun 28, 2025 3:45 AM
I'm finally getting some minor success with OpenSCAD->SVG->laser cutter.
It would be nice if I could hit F7, and have it export to SVG instead of
using the drop-down menu each time...
Is there an easy way to do this?
EBo --
I'm finally getting some minor success with OpenSCAD->SVG->laser cutter. It would be nice if I could hit F7, and have it export to SVG instead of using the drop-down menu each time... Is there an easy way to do this? EBo --
LH
Lenore Horner
Sat, Jun 28, 2025 11:57 AM
Hi David,
I normally use OpenSCAD when designing for laser cutting.  I have my windows set up so there are Render, STL, and SVG buttons visible at all times.  Always have to render first, but then it's one click after that whether I'm 3D printing or laser cutting.
Lenore
On Jun 27, 2025, at 23:45, John David via Discuss discuss@lists.openscad.org wrote:
EBo --
Hi David, I normally use OpenSCAD when designing for laser cutting. I have my windows set up so there are Render, STL, and SVG buttons visible at all times. Always have to render first, but then it's one click after that whether I'm 3D printing or laser cutting. Lenore > On Jun 27, 2025, at 23:45, John David via Discuss <discuss@lists.openscad.org> wrote: > > I'm finally getting some minor success with OpenSCAD->SVG->laser cutter. It would be nice if I could hit F7, and have it export to SVG instead of using the drop-down menu each time... > > Is there an easy way to do this? > > EBo -- > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
John David
Sat, Jun 28, 2025 5:01 PM
<face-palm...> Sigh... I never noticed that icon/button before.  Silly me.
You solved it in one, and it just worked (tm).  Thank you!
BTW, with the 3D-print button, if I can get the rest of the workflow going
and talking to OctoPrint (et al., I might try to hack the 3D-print
functionality to either take the 2D SVG or DXFs...
EBo --
On Sat, Jun 28, 2025 at 7:57 AM Lenore Horner lenorehorner@sbcglobal.net
Hi David,
Lenore
EBo --
<face-palm...> Sigh... I never noticed that icon/button before. Silly me. You solved it in one, and it just worked (tm). Thank you! BTW, with the 3D-print button, if I can get the rest of the workflow going and talking to OctoPrint (et al., I might try to hack the 3D-print functionality to either take the 2D SVG or DXFs... EBo -- On Sat, Jun 28, 2025 at 7:57 AM Lenore Horner <lenorehorner@sbcglobal.net> wrote: > Hi David, > I normally use OpenSCAD when designing for laser cutting. I have my > windows set up so there are Render, STL, and SVG buttons visible at all > times. Always have to render first, but then it's one click after that > whether I'm 3D printing or laser cutting. > Lenore > > > > > On Jun 27, 2025, at 23:45, John David via Discuss < > discuss@lists.openscad.org> wrote: > > > > I'm finally getting some minor success with OpenSCAD->SVG->laser > cutter. It would be nice if I could hit F7, and have it export to SVG > instead of using the drop-down menu each time... > > > > Is there an easy way to do this? > > > > EBo -- > > _______________________________________________ > > OpenSCAD mailing list > > To unsubscribe send an email to discuss-leave@lists.openscad.org > >
