On Thu, 9 Dec, 2021 at 11:27 AM, Leonard Martin Struttmann lenstruttmann@gmail.com wrote:
To: openscad general discussion
Gene, try making the wall an integer multiple of your nozzle size. For example, if you are using a 0.4mm nozzle, make
wall=2.4; // an integer multiple of 0.4
Using a 0.28 layer height, Cura predicts 8 hours 23 minutes, 141 grams
Good point, forgot about that. But my Prusa MK3S seems rather fond of .20 layers. Much
better layer adhesion.Thank you Leonard.
Thank you Leonard, Stay well.
Cheers Gene
On Thu, 9 Dec, 2021 at 11:27 AM, Leonard Martin Struttmann <lenstruttmann@gmail.com> wrote:
Cheers Gene
