Re: [OpenSCAD] how to make the groove more width?
Sat, Jan 21, 2017 10:41 AM
Imagine you start with a cylinder and want to tilt that into the groove. Then
the factor has to grow when radius or twist increase or when the height gets
lesser.
runsun wrote
What ratio did you infer to ? Can't figure it out from your code.
View this message in context: http://forum.openscad.org/how-to-make-the-groove-more-width-tp20154p20184.html
Imagine you start with a cylinder and want to tilt that into the groove. Then the factor has to grow when radius or twist increase or when the height gets lesser. runsun wrote > What ratio did you infer to ? Can't figure it out from your code. -- View this message in context: http://forum.openscad.org/how-to-make-the-groove-more-width-tp20154p20184.html Sent from the OpenSCAD mailing list archive at Nabble.com.
