Loop precision (==floating point precision ?)
LB
L Boyd
Fri, Nov 20, 2015 12:15 AM
For loops terminate when the next value would be greater than the max. Adding
a little bit to the max allows for flaying point representation errors.
If you don't like that, use a vector with the values you want rather than a
range.
Larry
View this message in context: http://forum.openscad.org/Loop-precision-floating-point-precision-tp14642p14659.html
For loops terminate when the next value would be greater than the max. Adding a little bit to the max allows for flaying point representation errors. If you don't like that, use a vector with the values you want rather than a range. ----- Larry -- View this message in context: http://forum.openscad.org/Loop-precision-floating-point-precision-tp14642p14659.html Sent from the OpenSCAD mailing list archive at Nabble.com.
LB
L Boyd
Fri, Nov 20, 2015 12:17 AM
I meant floating point representation errors.
Larry
View this message in context: http://forum.openscad.org/Loop-precision-floating-point-precision-tp14642p14660.html
I meant floating point representation errors. ----- Larry -- View this message in context: http://forum.openscad.org/Loop-precision-floating-point-precision-tp14642p14660.html Sent from the OpenSCAD mailing list archive at Nabble.com.
