Mon, Oct 23, 2023 1:54 AM
Using a month, maybe 2 old AppImage 2023.09.10.ai16125 of the
development version, is there an edit>prefs setting that will restore
preview speed?
I'm working a a pretty complex thing, that F6's in just over 1 second,
but F5's in about 1:133 minutes. The lag is very distracting.
Thanks.
Cheers, Gene Heskett.
preview speed?
Thanks.
- Louis D. Brandeis
Mon, Oct 23, 2023 2:05 AM
That’s a pretty huge difference.
Is rendering relatively swift after doing F5, or is the frame rate also low?
Did you enable any experimental features?
If you could share an, as small as possible, example exhibiting this symptom, we could try to look into it.
On Oct 22, 2023, at 21:54, gene heskett gheskett@shentel.net wrote:
Using a month, maybe 2 old AppImage 2023.09.10.ai16125 of the development version, is there an edit>prefs setting that will restore preview speed?
I'm working a a pretty complex thing, that F6's in just over 1 second, but F5's in about 1:133 minutes. The lag is very distracting.
Thanks.
> Thanks.
> - Louis D. Brandeis
Mon, Oct 23, 2023 3:08 AM
I don't have a "small" example, the file is one of my earlier works, and
actually makes a couple dozen different parts depending on whats
uncommented at the bottom of a 631 line file. The actual code in use for
this part is probably some north of 200 lines just for the part I'm
working on. It is also a potentially commercial product I have visions
of selling 10 or 20 of. Eventually. If I don't miss roll call first. At
89 and a chest full of hardware I wasn't born with, that is also a
possibility. Let me see if I can strip out the most complex part into
another file over the next 2 or 3 days and still make it work.
Thank you Marius.
Thank you Marius.
- Louis D. Brandeis
Mon, Oct 23, 2023 4:53 PM
On 10/22/23 23:08, gene heskett wrote:
It also took nearly 14 hours for this to echo back from the list.
Something is aglay.
also low?
Thank you Marius.
Something is aglay.
>> also low?
> Thank you Marius.
- Louis D. Brandeis
Mon, Oct 23, 2023 5:04 PM
Something is aglay.
This however, was back in 10 minutes. Maybe its fixed?
> Something is aglay.
- Louis D. Brandeis
